OpenFlash Tablet Video Tutorial #1: How to Disable Diagnostic Codes
07-21-2013, 04:19 PM | #1 |
1737
Rep 17,960
Drives: A Lot
Garage List 2018 Ducati Panigal ... [0.00]
2016 Mazda CX5 [0.00] 2017 Aprilia Tuono ... [0.00] 2019 BMW M2 Competi ... [0.00] 2015 BMW M5 Competi ... [10.00] 2016 Ducati XDiavel S [0.00] 2016 AMG GT S [0.00] 2011 Ferrari 458 It ... [0.00] 2017 Charger Hellcat [0.00] 2015 KTM Super Duke ... [0.00] 2016 KTM RC390 [0.00] |
Hi guys,
We are very happy that community as adopted OpenFlash Tablet so readily and that everyone has found it easy to use and install. So from this point onwards, we are going to start posting tech threads that will show users how to do more than just pick an OTS map and flash it to the DME We are going to start off slowly with easy stuff first. In this case, we are going to show how to use Toggles to disable/enable diagnostic codes and functions. Last edited by OpenFlash; 07-21-2013 at 05:54 PM.. |
07-21-2013, 04:50 PM | #2 |
335i Owner
56
Rep 839
Drives: BMW 335i 4 Door
Thanks for the information and tutorial Shiv! Looking forward to more tutorials to come. You should show us how to tune :0
E90 - 2007 BMW 335i Sedan
45K miles 7" VRSF FMIC | BMS DCI | AR Catless DPs | KW v2 Coilovers | M3 Front Control Arms |
07-21-2013, 04:57 PM | #3 |
Rep 4,764
So who knows if you set the cat conversion bank1 and bank2 both to 00, if you can still get readiness?
Nice vid, looking forward to more installments. |
07-21-2013, 05:08 PM | #4 |
1737
Rep 17,960
Drives: A Lot
I don't think it sets readiness. It just disables the fault code. It looks like there may be a way to set readiness by possibly adjusting the "sensitivity" of that particular diagnostic (notice that the value is a 56 and some euro ROMs I've seen have it set higher). But that's for others to play around with on their off-road-ues only race cars.
07-21-2013, 05:23 PM | #6 | |
95
Rep 1,659
Depending on the model year you can have one or two "not ready". So - disable the cat codes which will prevent the CEL - and all other diagnostic tests will go ready - leaving one "not ready" - which doesn't fail your inspection...at least not in NY.... Edit - I am reading that "The US Environmental Protection Agency (EPA) guidelines allow up to two monitors to be in a “not ready” state for model year 1996 through 2000 vehicles and one monitor “not ready” for 2001 and newer model year vehicles." So - perhaps that is applicable to all ODB2 inspection states... Last edited by mwahlert; 07-21-2013 at 05:31 PM.. |
07-21-2013, 05:53 PM | #8 | |
16
Rep 335
Yes. First you upload the file to the tablet though. |
07-21-2013, 05:55 PM | #9 |
19
Rep 301
Love the video tutorial idea! Very easy to follow and understand.
Could you explain the pros and cons of disabling the lean spool mode? Also, what are the possible consequences of disabling misfire (detection?) on bank 1 and 2? Thanks Shiv. |
07-21-2013, 06:25 PM | #10 | |
Rep 748
Great video! FWIW "Disable Lean Spool" and the other "Disable FUNCTIONS" should probably be read as "Lean Spool" and "FUNCTIONS". If read literally (as I thought when I first read them) setting "00" for "Disable Lean Spool" would disable "Disable Lean Spool", essentially enabling lean spool. Is that clear? As the way it is written now it is a double negative.
2008 335I E92, AW, VFF700, 18" Forgestar F14, M3 front/side, M-tech rear, AMS IC, H&R Touring Cup Kit suspension, HID AE, ER Charge Pipe & Synapse BOV, CIC Retrofit, Quafie, DSS, Defiv Lockdown, SPEC 2+/Steel SMFW, Walbro 450
07-21-2013, 10:09 PM | #11 | |
Rep 2,841
Kind of like having a sexual harassment policy .......makes it sound like your are encouraging it. |
07-21-2013, 10:21 PM | #12 | |
1737
Rep 17,960
Drives: A Lot
Thanks! |
08-02-2013, 01:11 AM | #14 |
Rep 1,392
False alarm. Disregard my post.
Have a single turbo and/or tired of burning up O2 sensors? Ask me about the new ADV O2 sensor retro kits!
335i 2010 e92 M-sport Mods: VM Top mount 6466, Aquamist HSF4 w/custom direct port. VRSF IC + Exhaust 335i 2009 e90 665RWHP VFF900 ST RIP . |
08-02-2013, 02:11 AM | #15 |
Rep 196
Exhaust Fume Flap
Just wondering if anyone know what the disabling the exhaust fume flap does?
Is it basically the same as the golf tee mod when you set it to 0? |
08-02-2013, 02:15 AM | #16 | |
1737
Rep 17,960
Drives: A Lot
Shiv |
08-02-2013, 09:16 AM | #17 |
16
Rep 335
08-05-2013, 12:06 AM | #18 |
Rep 45
I am just getting into the BMW world and have been getting acclimatized to this new Openflash. To date I have only run the stag0 file and have been very pleased with the results over stock considering I only have DCs, Berk street cat back, and 93 octane.
I plan to load up the stag1 and wanted to know if the "Speed Limiter (Master)" under Limits is related to the 150 mph gov these cars have? I will disable this while I am doing a few other things. I plan to install my cp-e DPs and ETS 7" FMIC this coming weekend as well. I really like everything you are doing Shiv with this product and commend you and everyone else involved with the speed and support having to be put forth. I know it will fruit itself nicely as we all get up to speed with this product. I hope you guys also host these tutorials on your website directly as well since it can be tough to keep track of new threads created during the week here when other priorities govern me during the week and I play catch-up on the weekends. I would hate to miss updates to the product or valuable tutorials. Maybe a sticky to house them? One last note which I am sure is on the list but descriptions for each parameter eventually will also keep the many questions to a min..... Thanks again and I look forward to learning much more about this product into the future. |
08-05-2013, 01:23 AM | #19 | |
1737
Rep 17,960
Drives: A Lot
Yes, if you disable the speed limiter (master) parameter, you will remove the top speed governor Thanks for the kind words! As soon as we caught up with rom support (working on aussie and euro roms now), I'll start posting up more tutorials. But right now there are people in the world with OpenFlash Tablets and no tunes! That's terrible |
08-05-2013, 09:17 AM | #21 | |
Rep 71
01-21-2014, 11:48 PM | #22 |
Rep 5
Hey Shiv,
Just got my OpenFlash tablet, excited to try it out as soon as I sort out my vanos issues I have a few dashboard warning lights illuminated, and hopefully would like to disable them - will this be possible through disabling the respective diagnostic codes? As I have aftermarket wheels/brakes, I am looking at: a) TPMS b) Brake Pad Wear c) Windshield Fluid Level Thanks! |
