Walbro 455 LPFP questions
07-23-2013, 09:32 PM | #1 |
Rep 660
Where can I get the Walbro 455 pump for e85?
Anything that I need to get to install this pump on my 335i? Thanks for your time!!
PROcede REV3+OpenFlash "Custom DynoTune" //Vishnu PWM Meth kit//AIS Meth Tank//18" Forgestar F14//BridgeStone RE11//WaveTrac LSD n M3 Bushing//
KW V3 Coilovers//ETS 6.25" FMIC//MS Ceramic Coated 3" DPs//aFe DCI//M3 style body kits//HPF GEN2 Exhaust//Performance CF Trunk Lip//FFTEC walbro 450 inline pump kit// |
07-23-2013, 10:03 PM | #3 |
Rep 660
07-23-2013, 10:21 PM | #4 |
DIYER
614
Rep 5,521
Same pump, same part number
JB4 G5, Stage 3 LPFP, Stage 2 MOTIV PI, VM 6466 ST, Custom OCC W/ SS lines, ER FMIC, ER CP W/HKS BOV, M3 control arms, M3 guide rods, M3 upper links, M3 front & rear sway-bars, HPA rear toe arms, Wavetrac LSD, HPF Gen 2, DEFIV kit, KW clubsport, Delrin solid SF bushings, stoptech rotors, Rogue Tranny Mounts, 1M bumper, M3 CF hood, M3 fenders, M3 OEM sideskirts, Mtech rear bumper, CSL trunk, MORR VS8.2 rims 245/295
07-23-2013, 10:25 PM | #5 |
Rep 965
Drives: e92 m3
anyone know what else we need besides the pump?
e92 m3 dct
gintani stage 2+ full ethanol custom pulley and meth kw clubsport,ap racing radical,volk te37sl,akrapovic rear,recaro profi xl,voltphreaks battery |
07-23-2013, 10:59 PM | #7 |
Rep 660
455 mean it can pump 455L per hr..
07-23-2013, 11:08 PM | #8 |
Rep 660
us stock pump is 255LPH right? so 400LPH is over kill till we hit 800+WHP..
07-23-2013, 11:28 PM | #9 |
Rep 1,432
Many have had problems with the replacement. First, make sure you need an upgrade - look and see the LPFP pressure dropping. Second, consider an inline pump rather than an replacement. Third, if you still want to go ahead with the replacement, do it properly by studying and learning from others' mistakes.
07-24-2013, 12:14 AM | #11 |
DIYER
614
Rep 5,521
If you look at the part numbers they are the same for most 455 and 400 walbro pumps.
07-24-2013, 12:15 AM | #12 | |
DIYER
614
Rep 5,521
07-24-2013, 12:34 AM | #14 |
DIYER
614
Rep 5,521
07-24-2013, 02:02 PM | #15 |
Rep 162
Where can I find instructions on how to read logs from my JB4? Can't find it on N54tech. But I'll keep doing my research for those that might respond with, "keep researching."
FBO Instagram: RickyyyyyH |
07-24-2013, 05:28 PM | #16 |
Rep 748
Hey Rob, did you purchase a whole setup from ECS Tuning or the like to get the regulator line? Or is there somewhere you can buy it individually? I have been having issues with mine recently... had it come off 4-5 time in a matter of days. I had no problems after installing it initially with the Gates line in March, but I ended up having to replace the Gates line with a teflon line which has been holding up for the last week with no issues. If need be, I would like to have this regulator line available.
Also is it a PITA to get it on the "T" like the other in tank line is? I know when I pull my bucket I have to disconnect the two lines coming from the pump to the "T" because I can't pull off the in tank line from the "T". Here is the line I am using now: http://www.ebay.com/itm/190862745014...84.m1497.l2648 I intend to use these over the regular hose clamps if I pull it all apart again: http://www.amazon.com/gp/product/B00...?ie=UTF8&psc=1
2008 335I E92, AW, VFF700, 18" Forgestar F14, M3 front/side, M-tech rear, AMS IC, H&R Touring Cup Kit suspension, HID AE, ER Charge Pipe & Synapse BOV, CIC Retrofit, Quafie, DSS, Defiv Lockdown, SPEC 2+/Steel SMFW, Walbro 450
07-24-2013, 05:56 PM | #17 | |
DIYER
614
Rep 5,521
07-24-2013, 10:21 PM | #18 |
Rep 258
I also had my hose come off multiple times. Ive finally got things working by using Gates submersible fuel hose which so far has been amazing.
http://www.frsport.com/Gates-27093-5...0_p_15937.html I also had some kinking issues with my lines and ended up putting 90 degree elbows in so anywhere I had bends that could kink wouldnt.
2014 F82 (sold)
2016 F15 (sold) 2016 F80 ZCP (sold) 2018 M2 6MT (sold0 2017 F80 6MT |
07-25-2013, 11:04 AM | #19 |
Rep 1,201
No.
'08 E90 w/ just boltons
'09 Z4 sDrive35i w/ just boltons |
07-25-2013, 11:27 AM | #20 | |
Supreme Allied Commander
3845
Rep 54,376
Drives: F80 M3
-Mike |
07-25-2013, 11:53 AM | #21 |
Rep 885
You'll tell us your recommendation in a week? Awesome
DocRace 6266 E92. M8 comp coupe, X5m
07-25-2013, 11:57 AM | #22 |
3845
Rep 54,376
Drives: F80 M3
No, I will tell you what happened to my car in a week. You know e90 people, they will instantly start gossiping about what happened before I get a concrete answer. This pump should really only be installed 'in-line' because of the random drops in fuel pressure and the ramp-up for these pumps is 0 OR 99%, haha. It's not a bad pump, just in my opinion (and others), it should be used 'in-line' and not as a full oem replacement.
-Mike |
