FMIC Swap Leak
07-23-2013, 11:41 PM | #1 |
335i Owner
56
Rep 839
Drives: BMW 335i 4 Door
FMIC Swap Leak
I had my FMIC swapped yesterday at the shop, a 7" VRSF. I came home yesterday and didn't even drive the car. Left today and saw a small leak.. Any idea? I'm bringing it back to the shop tomorrow, is this safe to drive, the shop is 20 miles away.
E90 - 2007 BMW 335i Sedan
45K miles 7" VRSF FMIC | BMS DCI | AR Catless DPs | KW v2 Coilovers | M3 Front Control Arms |
07-24-2013, 01:36 AM | #3 |
335i Owner
56
Rep 839
Well maybe I don't have a boost leak... Whatever they did is causing my car to leak... it didn't have a leak before I brought it there..
07-24-2013, 12:21 PM | #5 |
Rep 554
Drives: E92 335i 6MT
Describe the fluid for us
07-24-2013, 12:50 PM | #6 |
1250
Rep 1,502
I retract my statement about the car being safe to drive. If air is leaking from your car and forming a puddle, something is seriously wrong.
2011.5 E90 M3 DCT ZCP Slicktop
07-24-2013, 01:05 PM | #7 |
335i Owner
56
Rep 839
I took my car to the shop today, they put it up on a lift and seems like everything was dry, must have been my AC as that was dripping and it dried, really looked like coolant but, then again it had no smell.. It does seem as I am leaking hydraulic fluid from my front control arms (gonna swap bearings), I'm going to monitor and see how everything goes...
Oil was more toward minimum then full so I decided to change my oil at 3K miles since I bought the car... So far I have done: 6 plugs 2 Coils Oil Change Dual Cone Intake I need to swap my injector in cylinder 6, I'm gonna do walnut blasting... Should I just swap the brake and coolant fluid too for $240 for both while I do all this? I figure I might as well get everything done now rather then later and now my car is running healthy. I'm at 32k miles bought at 29k
07-24-2013, 02:16 PM | #9 |
335i Owner
56
Rep 839
It looked like coolant, I drove the car 20 miles to the shop, they took a look and nothing looked wrong on the FMIC side. No leaks underneath and they said it looked like the A/C dripping and showed me, made sense. The liquid was colorless but did look like it had a blueish tint. I rubbed my hand and it was dirty then I thought it was oil but didn't have any smell... Car is throwing no codes and no CEL and leak seems to be gone...
07-24-2013, 05:13 PM | #11 | |
Rep 1,434
2022 x5 m50i - Dravit grey
2005 evo 8 (current) built 2.3 488/409 mustang dyno Old stable mates - 87 325i, 88 m3, 90 m3, 97 m3 4dr, 04 325xi, 91 gmc Syclone, 08 335xi, and 13 x3 35i msp 2014 x5 50i msport |
07-24-2013, 05:20 PM | #12 |
3441
Rep 79,211
07-24-2013, 05:51 PM | #13 |
335i Owner
56
Rep 839
Thanks for all the help guys, I'm monitoring it closely.
07-25-2013, 03:10 PM | #14 | |
Big Poppa
9
Rep 140
Drives: F15 3.5i AW/Mocha
Sandy did a Job on LI roads!
F10 535xi AW/Mocha
07-25-2013, 03:17 PM | #15 |
10
Rep 134
Check your coolant level in the reservoir... Last thing you want is to lose too much coolant and overheat your block.
Fill it to max and see how much, if at all, it drops. |
07-25-2013, 05:39 PM | #16 |
335i Owner
56
Rep 839
Eh these roads always sucked lol.
Cheers
07-25-2013, 10:45 PM | #18 |
Rep 49
I have the same kind of leaks before. The liquid is clear and smell like alcohol.And it turns out my AC is leaking the refrigerant. Dealer fix it under warranty.
