OpenFlash Tablet: In-Dash Boost Gauge and On-Board Datalogging
07-24-2013, 03:04 AM | #1 |
1737
Rep 17,960
Drives: A Lot
Garage List 2018 Ducati Panigal ... [0.00]
2016 Mazda CX5 [0.00] 2017 Aprilia Tuono ... [0.00] 2019 BMW M2 Competi ... [0.00] 2015 BMW M5 Competi ... [10.00] 2016 Ducati XDiavel S [0.00] 2016 AMG GT S [0.00] 2011 Ferrari 458 It ... [0.00] 2017 Charger Hellcat [0.00] 2015 KTM Super Duke ... [0.00] 2016 KTM RC390 [0.00] |
The Rombinhood team is just wrapping up final details. They hope to have this update available to all in time for the weekend. I think this is the first MSD80/81 flash tune with Dash Activations.
07-24-2013, 03:36 AM | #2 |
Rep 1,392
Awesome work! Fast progress keeping my tinkering needs under control. Has it been possible through the procede or now the open flash to hijack the digital center screen? A meth flow or peak and hold boost gauge would look sweet in there.
Have a single turbo and/or tired of burning up O2 sensors? Ask me about the new ADV O2 sensor retro kits!
335i 2010 e92 M-sport Mods: VM Top mount 6466, Aquamist HSF4 w/custom direct port. VRSF IC + Exhaust 335i 2009 e90 665RWHP VFF900 ST RIP . |
07-24-2013, 03:42 AM | #3 |
1737
Rep 17,960
Drives: A Lot
Yes, the OpenFlash Tablet can hijack anything on the dash, including the center screen. It's using the same code as the Procede for the in-dash boost gauge. It's relatively easy to add the other dash functions as well. However, meth flow signal will be hard since there is no signal input on the Tablet that will accept a flow sensor signal. We might have to get more creative with it
07-24-2013, 04:04 AM | #5 |
Rep 1,392
Shiv that's great to hear. Now my head keeps coming up with all these dumb ideas for the center display. I don't know crap about that type of coding otherwise I'd try to help. But a peak and hold boost gauge would be awesome or even a boost gauge. 20+psi makes gas gauge useless for me. Digital AFR would be a good one too or IAT . Ahh i gotta stop!
07-24-2013, 04:08 AM | #6 |
Rep 1,392
Sorry one more!! . Knock alert. Either digital knock read out or have them go full box color like when you start your car with the procede. Ok I'm done this time i swear
07-24-2013, 04:59 AM | #7 |
Guest
Rep n/a
Drives:
I rented a new mustang recently, all these amazing digital gauges are built into the car already, AFR, cylinder head temp, inlet air temp, transmission temp, a track mode with accelerometer..... my 330i doesn't even have a temp gauge, what the hell was BMW thinking, replacing it with a useless mechanical instant mpg.
07-24-2013, 08:25 AM | #9 |
Rep 2,014
Is on-the-fly map switching still being developed also? I remember someone mentioning that as long as the device is plugged in, it is possible.
WedgePerformance E40 MHD | Performance Exhaust Mod | BMS DP | Vibrant 1790 | BMS Intake | VRSF CP | xHP Stage 3 Michelin PSS | M3 Control Arms LUX v4 LEDs | Shadowline Grills | Lip Spoiler |
07-24-2013, 08:39 AM | #10 |
Rep 178
this might come off like a stupid question but i would like to confirm. the gauge hijaking is specifically for the gauge cluster correct? i ask because i have the bmw performance steering wheel if i hijacked my oil temp gauge i dont want the same crazy readings on my steering wheel.
07-24-2013, 08:40 AM | #11 | |
Rep 7,377
07-24-2013, 08:41 AM | #12 |
Mr. Nice Says Hello
636
Rep 16,662
Drives: BMW M3 | X5 xdrive 35i MSport
any word on if this will work on a m3?
07-24-2013, 09:19 AM | #14 |
Rep 6,478
Charge temps and Lambda would be AWESOME in-dash. Good work here.
E88 N54 Alpinweiss/Coral Red/Motiv HTA 3586r Tial .82AR/Other stuff...652WHP
F30 N55 XDrive EBII |
07-24-2013, 09:23 AM | #15 | |
Rep 216
Ill give it another shot and send u a pm. |
07-24-2013, 09:29 AM | #16 |
469
Rep 4,392
@ Shiv
Ok my last question, others told yes it does but I just want confirmation, sorry if I missed it being mentioned somewhere else. Can I use this tablet as a "stand alone" data logger and diagnostic tool with out having to flash any software and without the PROCede ? I am pretty sure it saves the logs in CSV Multipoint rows |
07-24-2013, 09:41 AM | #17 |
Rep 6,631
why hijack the dash gauges when you can mount the unit and get multiple channels at once? id assume you need the unit connected to hijack the gauges anyway, so its kind of redundant.
E90 LCI N54 6AT
07-24-2013, 11:25 AM | #18 | |
Rep 26
Coming from procede 2b, I really miss boost on fuel, but I'm loving the stage-0 OTS! |
07-24-2013, 11:30 AM | #19 |
3441
Rep 79,211
I thought the gauges could be hi-jacked without the tablet being plugged in? I dont know but it would be quite silly to have to leave the unit plugged in to hi-jack gauges.
07-24-2013, 11:54 AM | #20 | |
1737
Rep 17,960
Drives: A Lot
For a data like boost, which is monitored so frequently, it's more useful to have it displayed on the dash than on the Tablet screen. And boost, in particular, is always better to read on an analog gauge (needle) than on a digital readout since it gives the user a better sense of what is going on with respect to boost stability. At this point, it's easy to add on the other Procede in-dash displays (AFR, IAT, Ign Advance, etc,.). |
07-24-2013, 11:55 AM | #21 | ||
1737
Rep 17,960
Drives: A Lot
We have m3 support right now. So the Tablet can already read and right to the DME. At least for the older software versions. Recently BMW introduced some anti-tamper DME code which needs to be worked around. I think Rombinhood and his team will be supporting MSS60 themselves with OTS maps and the XDF files. But I don't think they are at that point yet. Quote:
07-24-2013, 12:04 PM | #22 | |
Rep 135
Shiv can correct me if I'm wrong... |
