Procede rev3 + OpenFlash log
07-25-2013, 09:06 PM | #1 |
Rep 660
anyone can tell why my fuel trim bank one and bank two is way off? but the AFR are the same..
Uploaded with ImageShack.us same log Uploaded with ImageShack.us
PROcede REV3+OpenFlash "Custom DynoTune" //Vishnu PWM Meth kit//AIS Meth Tank//18" Forgestar F14//BridgeStone RE11//WaveTrac LSD n M3 Bushing//
KW V3 Coilovers//ETS 6.25" FMIC//MS Ceramic Coated 3" DPs//aFe DCI//M3 style body kits//HPF GEN2 Exhaust//Performance CF Trunk Lip//FFTEC walbro 450 inline pump kit// Last edited by Dark9T; 07-25-2013 at 09:13 PM.. |
07-25-2013, 09:11 PM | #2 |
1737
Rep 17,960
Drives: A Lot
Garage List 2018 Ducati Panigal ... [0.00]
2016 Mazda CX5 [0.00] 2017 Aprilia Tuono ... [0.00] 2019 BMW M2 Competi ... [0.00] 2015 BMW M5 Competi ... [10.00] 2016 Ducati XDiavel S [0.00] 2016 AMG GT S [0.00] 2011 Ferrari 458 It ... [0.00] 2017 Charger Hellcat [0.00] 2015 KTM Super Duke ... [0.00] 2016 KTM RC390 [0.00] |
Bank imbalances are usually caused by methanol not distributing properly. Which is why, for single turbo applications, we mount the nozzles in the FMIC end tank. This gives it a lot more time to atomize and create a homogenous charge. But for stock turbo applications, leaving it in the charge pipe (as upstream as possible) is fine. So is such a fuel trim imbalance. Nothing to worry about.
If you are not running methanol, imbalances can be caused by variances in injectors (esp when dealerships only do recalls on 1 bank and not the other) or wear and tear on o2 sensors (someones only one gets replaced the other wears at a different rate). edit. I'm blind. You are running methanol as shown in the log. So the first bit of my response applies to you I take that you logged a 3-4th gear 6AT run? Looks good. Last edited by OpenFlash; 07-25-2013 at 09:18 PM.. |
07-25-2013, 09:19 PM | #3 | |
Rep 660
KW V3 Coilovers//ETS 6.25" FMIC//MS Ceramic Coated 3" DPs//aFe DCI//M3 style body kits//HPF GEN2 Exhaust//Performance CF Trunk Lip//FFTEC walbro 450 inline pump kit// |
07-25-2013, 09:25 PM | #4 |
Rep 660
Shiv, my OpenFlash real time data not working properly, it wouldn't connect.
07-25-2013, 09:27 PM | #5 | |
1737
Rep 17,960
Drives: A Lot
You're timing is pretty solid. I wouldn't adjust it upwards without some sort of dyno tuning. With stock turbos, you'll find that there isn't much to gain (and a whole lot to lose) when advancing timing beyond a certain point. It's only when running E85 can you support big ignition advance numbers. Shiv |
07-25-2013, 09:28 PM | #6 |
1737
Rep 17,960
Drives: A Lot
07-25-2013, 09:31 PM | #7 | |
Rep 660
anyway i am gonna get a dyno tune from you guys soon..
07-25-2013, 10:03 PM | #8 |
1737
Rep 17,960
Drives: A Lot
07-25-2013, 10:33 PM | #9 |
Rep 2,841
If it's any comfort, here is one of my datalogs on meth.
I have been trying to eliminiate the fuel trim variance and moved my meth nozzles to the up-pipe coming out of the intercooler......but it didn't make any difference to the trims. I guess the next step would be to tap the intercooler end tank and move the nozzles there. Shiv.....given my fuel trims are equal when I don't spray - is it pretty certain that moving the nozzles to the endtank will help equalize the imbalance when I do spray? . . . |
07-25-2013, 11:30 PM | #10 | |
Rep 660
07-26-2013, 01:36 PM | #12 |
1737
Rep 17,960
Drives: A Lot
07-26-2013, 04:39 PM | #14 |
Rep 660
Car was running fine till today, was driving slow and got a limp mode with two code,
10722 Fuel injection rail, pressure sensosr signal and 10927 Fuel pump plausibility.. Please help!! |
07-26-2013, 04:50 PM | #15 |
1737
Rep 17,960
Drives: A Lot
07-26-2013, 08:23 PM | #17 |
Rep 660
Uploaded with ImageShack.us i just change back to the Aggressive v5 9_10 map, was using the E85 map but need some logs tonight and need to change my LPFP before do the e85 map again..
07-27-2013, 11:23 AM | #18 |
Rep 660
Uploaded with ImageShack.us this log is from map1 no math, some how my meth wont flow last night.. how to fix this fuel trim on bank2? my OL fueling was 50%.
07-27-2013, 11:53 AM | #19 |
1737
Rep 17,960
Drives: A Lot
If this happened while you were just driving slowly, you may be experiencing the early signs of HPFP failure. I wouldn't worry about it unless it happens again. Also, from now on, all Debug Byte 4 to your datalogs. That will show the fuel pressure signal that goes to the DME.
07-27-2013, 11:55 AM | #20 | |
1737
Rep 17,960
Drives: A Lot
07-27-2013, 12:00 PM | #21 | |
Rep 2,841
A 2% to 5% fuel trim deviation between banks is pretty normal when not spraying meth. Important point is that your AFR's look good between banks and that indicates the injectors are meeting their targets. One bank just needs a little more fuel to do so. |
