JB4 Map 5 Question
07-27-2013, 03:20 PM | #1 |
35
Rep 317
JB4 Map 5 Question
I was curious... how can I consistently run 17psi on Map 5?? I already understand its an auto tuning map and adjust to its behaviors but is there any tricks? I have done several WOT pulls in 3rd gear and I used to be able to pull 17psi consistently throughout most the gear and slowly decline at higher RPMs but now I just spike to 15psi at most and see a decline after that.
I know that most will say to read codes and post. Which I will probably do later today... but does anyone of experience of certain ways to keep consistent numbers? Hopefully I don't have a boost leak but I will have to read codes on that to confirm as well. Thanks!
2007 E92 335i - JB4 / AR Catless DPs / ETS Chargepipe / HKS SSQV BOV / AFE Stage 2 DCI / MagnaFlow Exhaust / LUX V3 Angel Eyes / H&R Race Springs / Too Many Cosmetic Upgrades to List
07-27-2013, 03:58 PM | #3 |
Rep 925
For me, my IAT is the main thing that brings down my boost.
Assuming you have stock FMIC like I do, monitor your IAT.. after one 1/4 mile pull, my IAT hit 175 degrees in 90degree ambient temperature 0_0 |
07-27-2013, 04:29 PM | #5 | |
35
Rep 317
If I were to go to Map 6... is that something where I should send my logs to Terry and have him take a look to see if everything is ok to be running at 17psi? I don't want to do anything to throw my car off and ruin it. How do you monitor that? Its on the JB4 Perf. Tuner screen that reads the numbers correct? I just purchased a VRSF 7" FMIC and looking to install that this week, hopefully that helps a lot with the cooling effect and give me higher PSI under Map 5.
07-27-2013, 05:13 PM | #6 | |
Rep 2,409
Boost alone doesnt mean power. You can make power from timing as well. Don't be so set on 17psi... JB4 is made so that if you have proper grade fuel it will run more boost. Otherwise you will typically see 14 or 15psi. So you either have to run meth, e85 or race fuel to get the 17 psi you want. You will not get 17psi running 91octane with the Jb4. |
07-27-2013, 05:20 PM | #8 |
Rep 535
I don't see 17psi being very realistic without something like E85 or meth. On pump I saw about 15.5-16 on my boost gauge (tapped into the manifold) max if the conditions were right.
07-27-2013, 05:43 PM | #9 | ||
35
Rep 317
Yes I do. I will get logs soon...
07-27-2013, 06:16 PM | #10 | |
Rep 2,409
Once you get meth you'll be able to make more boost and depending on the mix you can hit 17psi. Yes you'd be using Map 3. |
07-28-2013, 02:00 AM | #11 |
35
Rep 317
Well here are my logs... I ran codes and it kept telling me there are no code readings.
Log 1 Log 2 Log 3
07-28-2013, 05:55 AM | #12 |
Rep 623
you def need more octane if your wanting to run 17psi lol. I skimmed through your logs you posted and your barely hitting 15psi of boost, maybe liess. You def need to send these logs into terry so he can hopefully find a solution for your issues
[SIZE="2"]Crimson Red E92 335i M-sport 6-speed with MHD custom stage 2+ flash only , 40% E85/93 mix,+ HRE P40S wheels, KW Clubsport, M3 sways,+BMW performance CF Mirrors, BMW Performance CF deck lid spoiler,+ CF interior trim, p3 vent boost gauge,+ LUX angel eyes (11.73@124mph on street tires)
07-28-2013, 06:58 AM | #13 |
Rep 44
Post up the raw data file or change the plots so it shows IAT. The best you can do is buy an intercooler so iat is as close to ambient as possible to suppress knock.
Other than that, there is only so much compression that 91/93 pump gas can handle and it's not 17psi usually. The solutions are: E85 Race gas Meth Lower compression ratio Without these, you can force JB4 to run 17psi, but you'll probably make less power than 14psi due to the bad timing. |
07-28-2013, 08:14 AM | #14 |
Rep 7,377
Get an IC and more octane. Ign looks already bad on liw boost so....
07-28-2013, 01:09 PM | #15 | |
35
Rep 317
How do you post up raw data file? Is that the Export Log (F7) key? And I have a FMIC sitting in my garage brand new... haven't had the time to install it yet. I definitely will be doing that this weekend. Also, I installed my BMS Meth Kit the other week with the FSB as well. So will it automatically adjust boost in Map 3 to a higher PSI?
07-28-2013, 01:11 PM | #16 |
35
Rep 317
Sucks that there is only 91 octane here in SoCal unless you drive out of your way for race fuel.
