cobb stg2+ datalog help
07-29-2013, 10:30 AM | #1 |
Rep 239
first time datalogging w/ cobb. have some experience w/ jb4 and have done my research to hold my own.
map: stg2+ sport ST mods: ams fmic er cp + tial bov bms catless dps drop-in filter Note: Timing corrections: just changed plugs ... Main questions per the logs 1 and 2: 1. Load_act: am I too far from target? 2. AFRs: settle to ~12.05 WOT .... too lean? 3. Timing: curves look alright from what i can tell...am i wrong? 4. Boost: ~18 tapering to 12.5psi ... isnt this a little high for stg2+ sport (16 to 12.5?) 5. Timing corrections (Run2): 1 multi-cylinder timing correction in 3rd @ 2200-3400 .... should i be concerned? right at onset of run, so no? Also, regarding IAT...it was 85*/65%humidity during the runs. Considering I have AMS intercooler, should I be seeing temps this high? Thoughts? Attached are graphs in Virtual Dyno and Zasquatch as well as csv data. Any other analysis of my logs would be appreciated. Thanks in advance.
2009 n54 e90 / Sport Pkg (ZSP) / Premium Pkg (ZPP) / black sapphire metallic / Logic7 / AMS FMIC / BMS 3" DP / BMS OCC / Alpina TCU Flash / ER CP + ForgeDV / Cobb
Last edited by gatorheel; 07-29-2013 at 01:07 PM.. Reason: add: intercooler comment |
07-29-2013, 04:01 PM | #2 |
Rep 6,478
Its impossible to read this on my phone but
Thats right where you want it AFR wise. Def. Not lean. Timing looks OK Boost curve looks like a Stg2+ aggressive curve, but ive never run 2+ sport so the difference could just be more advance. Either way the taper is fine, just make sure you arent getting big boost overshoots. Cant comment on the other stuff until i actually see the numbers |
