inline fuel pump 392
08-15-2013, 04:40 PM | #1 |
Rep 221
Well guys I have been reading mostly old threads about the upgrade mostly from mike and shiv.
They any of them come up with a way to step up the voltage that supplies the lpfp? Adding Another load(fuel pump) to the circuit will just make two pumps run half assed. Can someone please enlighten me . Thanks . |
08-15-2013, 04:41 PM | #2 |
1740
Rep 17,960
Drives: A Lot
Garage List 2018 Ducati Panigal ... [0.00]
2016 Mazda CX5 [0.00] 2017 Aprilia Tuono ... [0.00] 2019 BMW M2 Competi ... [0.00] 2015 BMW M5 Competi ... [10.00] 2016 Ducati XDiavel S [0.00] 2016 AMG GT S [0.00] 2011 Ferrari 458 It ... [0.00] 2017 Charger Hellcat [0.00] 2015 KTM Super Duke ... [0.00] 2016 KTM RC390 [0.00] |
Funny how the "half assed" solutions are holding up very well while the other approaches don't have such a good success rate
08-15-2013, 05:10 PM | #3 |
Rep 221
I agree they work but correct me if I am wrong please - a motor running over or under its designed range will eventually crap out. In our case the lower voltage would just lead to the pump over heating because flow is what is used to cool it ?
08-15-2013, 05:12 PM | #4 |
1740
Rep 17,960
Drives: A Lot
I'm not sure I follow. What do you think is being over-run? The pump(s) or the pump controller?
08-15-2013, 05:17 PM | #5 |
Joint Chiefs of Staff
4920
Rep 115,999
I've heard of the Walbro 455 failing in both inline and intank formats but the most common problem when doing a pump upgrade seems to be using poor quality non-submersible fuel line that bursts. The most reliable setup I've seen is the cheap Walbro 255 installed inline. It provides plenty of pressure, costs $100, is easier to install compared to the Walbro intank, and is 1/5th the price of trying to install a Walbro 455 inline.
Mike |
08-15-2013, 05:20 PM | #6 | |
1740
Rep 17,960
Drives: A Lot
Shiv |
08-15-2013, 05:46 PM | #7 | |
4920
Rep 115,999
Mike |
08-15-2013, 05:51 PM | #8 | |
1740
Rep 17,960
Drives: A Lot
We actually do use the Bosch 044 and 392 pumps in some of our N54 applications. The ones that don't require ethanol compatibility. Shiv |
08-15-2013, 06:51 PM | #9 |
Rep 288
Just wanted to put something into perspective on my 93 supra all I did was add another factory fuel pump (2 stock ) twinturbo supra fuel pumps and I was pushing 9** on race gas with a 3 speed auto.
Has anyone tried just adding another stock pump??? (Y) to the output and using a relay to power it ? |
08-15-2013, 07:20 PM | #10 |
Rep 1,392
Anyone looking for the proper hose to use you need SAE30R is about $5-7/ft.
Have a single turbo and/or tired of burning up O2 sensors? Ask me about the new ADV O2 sensor retro kits!
335i 2010 e92 M-sport Mods: VM Top mount 6466, Aquamist HSF4 w/custom direct port. VRSF IC + Exhaust 335i 2009 e90 665RWHP VFF900 ST RIP . |
08-15-2013, 07:31 PM | #12 |
1740
Rep 17,960
Drives: A Lot
08-15-2013, 07:38 PM | #13 | |
Rep 1,392
08-15-2013, 07:38 PM | #14 | |
Rep 1,392
08-15-2013, 07:58 PM | #15 |
Rep 221
So I guess the answer to my question is that there is no way to increase the voltage supply - other than a $400 booster.
What is the current at 9-11.5v on the Venturi ? My buddies out here are running the deatschwerks dw300 inline fuel pump. Any insight on that . |
08-15-2013, 08:27 PM | #16 | |
Rep 551
Harry |
08-15-2013, 08:40 PM | #17 | |
119
Rep 1,525
walbro
08-15-2013, 09:48 PM | #19 |
1740
Rep 17,960
Drives: A Lot
Actually, the tuner you are referring to only started recommending submersible hose after they started to fail in the field. It doesn't seem like he understood that standard fuel injection like was only coated on the inside!
08-15-2013, 10:46 PM | #21 |
119
Rep 1,525
walbro
If you say so
08-15-2013, 10:53 PM | #22 |
119
Rep 1,525
"FYI the SAE30R9 is not submersible .. Other than the napa h209what are you guys using for the alcohol resistant hose ?"
Most people were using the gates hose fully submersible e85 hose. Some failed because of installer error and some because of the gates hose is crap. But no one could have known that gates hose was crap. The gates hose did crap out on me but after replacing it I've been running the in-tank replacement just fine for a while now on E70 so said "tuners" DIY works just fine in my book. I'm currently running FC332-04 hose i've checked on it from time to time and it's just fine. Last edited by 07tundra; 08-15-2013 at 10:59 PM.. |
