What to mod next, suggestions?
08-29-2013, 01:33 PM | #1 |
54
Rep 558
As you can see in my signature i have a 07 335i coupe SG. Im looking to do another mod this week or two but not sure what will benefit me more right now. What would you guys recommend as far as more power , which brand and cost of parts. The car has 57k on it at the moment. And for members with similar mods what numbers are you putting down on dyno?
I have the fallowing done to the car: JB4 firmware 27 map 5 +costume tune VRSF Catless Downpipes VRSF FMIC Dinan Cold air intake Diana Exhaust Alpina b3 Transmission flash Exterior modes: Rohanna RC10 19 wheels running 275/30/19 in rear. m3 sideskirts Aero lip creed Angle eyes Car is slightly lowered on springs. Here is some pictures Last edited by tjobeid; 10-31-2013 at 03:10 AM.. |
08-29-2013, 01:41 PM | #2 |
Rep 6,478
FMIC and additional octane, whether that's done via corn fuel and/or meth. Your call.
E88 N54 Alpinweiss/Coral Red/Motiv HTA 3586r Tial .82AR/Other stuff...652WHP
F30 N55 XDrive EBII |
08-29-2013, 01:47 PM | #3 |
Rep 229
Drives: 2013 335is E93
08-29-2013, 02:06 PM | #4 |
54
Rep 558
WE havealmost the same taste in cars. Specially with the wheels.
Im not too crazy about running meth. If i wanted to run more e85 what all would i need? I guess my next mod is FMIC but if i decide to do something for more power for example more e85 what all would i need? Im trying to break the 400WHP mark 400-450 id be happy. |
08-29-2013, 02:25 PM | #10 |
Rep 6,478
You can run E30 or so without issues, more than that you’ll need flash tuning for fueling purposes, and likely a LPFP upgrade to support the requested PSI. A FBO car running E30 should put you right around 400 wheel, as you up the ethanol you can tune for more timing and boost. The numbers we’re seeing on stock turbo cars running E85 are insane.
08-29-2013, 02:29 PM | #11 | |
54
Rep 558
08-29-2013, 02:49 PM | #12 | |
Rep 6,478
E30= 30% E85, 70% pump gas. So for a car with a 16 gallon tank, roughly 4.8 gallons of E85, the rest pump gas. That is a VERY rough way to calculate it, though being exact is more important when you’re trying to run E60 or more aggressive mixes. Do some searching around, the N54 community is really diving into ethanol. I’ll respond to your PM after work, a lot to discuss there.
08-29-2013, 03:19 PM | #13 | |
54
Rep 558
08-29-2013, 03:28 PM | #14 |
Rep 6,136
E70 is 70% ethanol. But remember 93 octane usually has at least 10% ethanol content, and the E85 you are pumping might be a bit less or more than 85% ethanol.
08-29-2013, 03:31 PM | #15 |
54
Rep 558
okay makes sense now. if i wanted to run something along the lines of e50. What will need to be upgraded and added? LPFP and BMW flash with the cobb?
08-29-2013, 03:33 PM | #16 |
181
Rep 1,681
08-29-2013, 03:34 PM | #17 |
Rep 6,136
Depends on the condition of your LPFP. I'd say any more than 50% ethanol on a healthy OEM pump is pushing it. Just log your LP pessure and see what your case is. You will want a BMS fueling flash with any ethanol mixture IMO.
08-29-2013, 03:35 PM | #18 |
54
Rep 558
the bms flash and i guess upgrade the fuel pump anyways since car is almost at 60k. anything else ?
08-29-2013, 03:45 PM | #19 | |
Rep 6,478
Edit: you have JB4, I’m a moron and didn’t notice that. Yes, you will need the BMS flash for fueling support.
08-29-2013, 06:05 PM | #21 | |
Rep 229
http://www.intercepteft.com/calc.html Suggestion: you should plastidip or wrap your window trim black. Great looking car btw =) |
08-29-2013, 10:41 PM | #22 | |
54
Rep 558
im going to try to run e35-e40 tomorrow see how it runs and do some logs. I used just e30 before and car felt good. wish i knew someone with the cable to do the BB-we must not speak of flash. |
