AUX input defective?
12-07-2005, 12:20 PM | #1 |
Rep 274
so i purchased a connector jack at radio shack that hooks up to the aux input for my ipod mini..but it does not recognize it...doe sit not recognize mini's or is there something im doing wrong?the only thing that shows when i go to AUX is 'tone'
12-07-2005, 01:08 PM | #2 |
Rep 996
I initially I thought I had the same problem. I have an iPod Shuffle and quickly discovered that the iPod shuffle cannot be receiving power and playing at the same time. Also, make sure your device has the audio cranked up fairly high. It could be that it's playing, but you just can't hear it.
2006 330i Monaco Blue | Grey | Walnut ...Manual | Sports | Premium | Cold | Nav | Comfort Access | PDC | Sirius | Sunshade ...M-Tec Steering Wheel | M-Tec Shifter | TLC ...Performance Center Delivery | Oct 14, 2005 |
12-07-2005, 03:35 PM | #5 |
Rep 41
I hooked up to my pocket PC to listen to mp3 from it. There is no problem. Yes, there are 3 places to control the volume.
1. your device 2. the aux input level 3. volume of the car's stereo. |
12-07-2005, 06:36 PM | #6 |
Rep 274
ok ill chekc those three things but im sure they were up..at any rate if those fail what should i do? by the way im only connecting the ipod to the car vias the aux input im not using the bigger input next to the aux input....does that effect it?
12-08-2005, 06:52 AM | #7 |
Rep 266
I have a 4th generation ipod and when i plug in the aux. cable from headphone jack to aux. input in car the ipod will turn the backlight on (i have that setting on in the ipod), but my car doesn't seem to recognize that anything is in the aux. input.
When you cycle thru the entertainment outputs (FM AM CD AUX) it doesn't go to AUX...CD is not highlighted cuz I haven't tried a CD yet. |
12-08-2005, 05:19 PM | #9 |
Rep 266
Ok...so I tried again and jacked up the volume on my ipod and that worked. I still had to turn up the volume on the AUX input. But I've read on here that hooking up the aux thru the dock connector has better sound. so I plan to buy one of thos charger's with an aux out on it. thanks for the help!
I still could not get the programmable wheel button "next entertainment source" to switch to AUX. It only goes from FM to AM and back again. Last edited by natalia; 12-08-2005 at 06:05 PM.. |
12-08-2005, 07:28 PM | #10 | |
Rep 996
12-08-2005, 08:59 PM | #11 | |
Rep 649
Drives: 2006 BMW 325i
I started a thread on this. It seems to be a iDrive vs non-iDrive issue, because people without the iDrive can cycle to the AUX input source.
http://www.e90post.com/forums/showthread.php?t=6632 Quote:
12-09-2005, 03:56 AM | #12 |
Rep 996
You can always use the voice command "AUX menu" (I think) to switch over instead of using the buttons.
12-09-2005, 07:56 AM | #13 | |
Rep 266
12-09-2005, 08:36 AM | #14 | |
Rep 996
