255 inline pump help
09-14-2013, 10:12 PM | #2 |
Rep 281
Drives: 2007 E92 335i
Soak in WD40 of PB Blaster for hours.... hammer around the entire edge and be patient.... it took a while to get mine off.
07 E92 335I | JB4 G5 ISO | BMS E85 Flash | DCI | BMS DPs | Helix FMIC | Alpina TCU Flash | Walbro GLS392 | E70 | 429rwhp/474rwtq
09-14-2013, 10:33 PM | #4 |
Rep 281
I saw somewhere there was a huge socket/wrench available. Maybe you'll need one of those to create enough torque to get it off.
09-14-2013, 10:47 PM | #5 | |
388
Rep 1,945
09-14-2013, 10:51 PM | #6 |
Rep 1,392
I used a huge pry bar and was able to get some leverage. The had to use a big hammer and order a new hat and ring
Have a single turbo and/or tired of burning up O2 sensors? Ask me about the new ADV O2 sensor retro kits!
335i 2010 e92 M-sport Mods: VM Top mount 6466, Aquamist HSF4 w/custom direct port. VRSF IC + Exhaust 335i 2009 e90 665RWHP VFF900 ST RIP . |
09-14-2013, 10:53 PM | #7 | |
Rep 1,185
Use a flat head with a big tip and hit it really hard with your rubber mallet. It took me about 5 good hits then it popped free. I also tried soaking in PB for 3 hours and nothing lol. Also make sure that your turning it counter clockwise.
2015 BMW M4 F83
2009 335i X-Drive | GC 2.0 Turbos (sold) 2009 335i e93 (Sold) 2007 Bmw X5 (Sold) |
09-14-2013, 11:52 PM | #8 | |
388
Rep 1,945
Thanks for the helps guy ill give everything suggested a try. |
09-15-2013, 02:59 AM | #9 |
119
Rep 1,525
Me and my son hammered at the sametime on opposite ends obviously going the same way and it cam off no problem. Prior to that it was just me and it was not moving at all!
09-15-2013, 05:07 AM | #10 |
Rep 1,392
The ring from trisher. And brand new fuel pump assy from eBay.
09-15-2013, 10:51 AM | #11 |
136
Rep 1,202
You are just not shocking it enough to get it loose. Soak it then get a pry bar, the end on those is wide enough to get good engagement on the teeth on the ring, don't use a screwdriver. Next hammer choice is key, rubber mallet is a terrible choice, not enough weight or shock when you strike the bar, a baby sledge is the best choice. Once you have the right tools, don't keep hammering the same spot, go from one side to the other and top and bottom, some are really really stuck and you might end up ruining the ring but it will come off. Hope that helps
