Problem with Procede !!! Need help now!!!
10-21-2007, 08:22 PM | #4 |
Critical Care Anesthesiologist
482
Rep 8,828
Drives: SMB F83
Undo all the wiring, start up the car, and see if you still have the codes. If not, more likely than not, you fuk'ed up some of the connections.
kev { divinum est sedate dolorem }
"your friendly neighborhood critical care anesthesiologist" |
10-21-2007, 08:24 PM | #6 |
Rep 6,107
10-21-2007, 08:32 PM | #7 |
658
Rep 10,587
sounds like you got some wiring incorrect as already posted. Go back to stock and make sure all is well, then start over and take your time.
Sorry to hear about the frustration though.....goodluck.
10-21-2007, 08:50 PM | #10 |
482
Rep 8,828
Drives: SMB F83
Good luck man. You're probably too tired and messed up the count in some of the wires.
10-21-2007, 09:11 PM | #12 |
Rep 1,271
Where did you put the ground wire? I helped a buddy install his and his car did exactly as you describe and he finally traced the problem to a bad ground - moved the ground back to where he originally had it and the car ran fine.
10-21-2007, 09:32 PM | #14 |
Rep 6,107
i din't put the ground wire yet
10-21-2007, 09:33 PM | #15 |
558
Rep 6,169
Did you bypass the solenoid, and make sure the ground wire is on there good...
If those are good, then likely you got a wire crossed up somewhere...
MKIV 6spd 1000hp Club |
10-21-2007, 09:33 PM | #16 | |
558
Rep 6,169
Okay, ground the wire, then fire it up...that should cure it
10-21-2007, 09:40 PM | #17 |
Moderator
133
Rep 6,775
Drives: TiAg E92 335
I hope it was just the ground so it works out for ya. I know how frustrating installs can be when they don't go smoothly.
-Michael.
Berlina Black S2000 CR is now in the garage l 19" Rial Daytona Race l KW V2 l Eisenhaus Race Exhaust l |
10-21-2007, 09:43 PM | #19 |
Rep 774
Drives: E90 335i & E60 550i
+1. You need the ground.
Pure S2 Turbos | Vargas Outlets | RB Inlets | OEM SS Kit & Performance Steering Wheel| LCI Rear Conversion | Euro Xenons | RD Sport Quad Exhaust | Spearco Intercooler | Cobb V3 | MORR VS7 | KW V3 | H&R Sways | Mtech Bodykit | Vorsteiner CF Hood, CSL Trunk & Front Lip | Quaife LSD | Rotora BBK | GruppeM Intake | Forge UK DV | AR Design Catted DP's
10-21-2007, 09:50 PM | #21 | |
558
Rep 6,169
That's just to test out your connections...but skip that, ground the wire, bypass the solenoid, and check all your connections and then fire it up...
10-21-2007, 09:54 PM | #22 |
Rep 774
Were you trying to start the car with the bypass plugs or with the procede connected?
