MP3 solutions for E90 HK/China Version
12-12-2005, 11:45 AM | #1 |
Rep 50
Drives: 325i Titan Silver
I had my E90 weeks ago, I have the CD, DVD drive on front panel and a 6 disc changer in the trunk, I can't play any MP3, any recommedations?
12-12-2005, 07:09 PM | #2 |
Rep 47
Do you have any kind of Navigation system installed ? Either Pro Navi or Bus Navi ?
If you have Pro-Navi there is a known problem with Cars built before October 2005 (which yours probably was if it was imported into China). It is supposed to be fixed with a software update which is due in December called CIP20 although i dont think anyone has seen it yet. Ask your dealer for the fix and dont let them tell you they never heard of the problem. BMW know all about it. There are two other threads on this subject here http://www.e90post.com/forums/showthread.php?t=6271 http://www.e90post.com/forums/showthread.php?t=6481 Suggest you post on these to save adding a 3rd |
12-13-2005, 12:36 AM | #4 |
Rep 50
It was definitely pre-september build as all the parts are imported into China and assembled here. I am not sure whether it is a Pro Navi, how to check it? On the front panel it has single CD on top and DVD on bottom plus a 6 disc changer in the trunk. The i-Drive has a TV module which GPS was not available here in China, I think by adding in the naviation DVD it should be able to do navigation. Please advice.
12-13-2005, 03:18 AM | #5 |
Rep 47
Sounds like the same spec that gets shipped with the 325i in Singapore except we dont get TV but do get GPS. I guess the China maps might take a while to finish - its a big place :-)
The pro-navi has a bigger screen than bus navi - you can probably find the dimensions on the web somewhere. If your MP3 doesnt work in the front CD, DVD and rear boot changer then i'd say you have the pro-navi module and you need the software upgrade. |
12-13-2005, 05:20 AM | #6 |
Rep 203
Look under your bonnet. The build date is on the underside, roughly where the BMW logo is on the bonnet. If your Build date is September or earlier ... no MP3.
It sounds like you have Pro Navi. The Pro Nav screen is basically split into two. Two thirds of the screen is the left side, and the other third is on the right.
325i auto | Saph Blk | PDC | Sunroof | Prof Nav | BiXenon | SS | Logic7
12-13-2005, 09:14 AM | #7 |
Rep 50
Yes costa, I have got the screen u described. Left side for TV and right side for Computer/Journey computer display. China factory build date was Sept 20 2005, so i am not sure the actual build date i will need to check it out again.
cdxp, you have the same probs? You can play mp3 as well? |
12-13-2005, 09:39 PM | #9 |
Rep 50
They said is not out yet.
12-29-2005, 11:08 AM | #10 |
Rep 50
Guys, bad news... The f**king CIP20 for China isn't works! I still cant play MP3! Hated them....... :mad:
This is the email they reply after i escalated the ridiculous issue to BMW Germany:- Dear Mr Loo, Thank you for your latest e-mail. We have forwarded your details once more to the relevant department for assessment. Kind Regards, BMW Customer Service Team |
