Studio RSR
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Tracking, Autocrossing, Dragstrip, Driving Techniques > What's your 1/4 mile drag radial set up????
      10-28-2007, 09:37 PM   #1
1clean335i
Perf BMW mag issue 147, 159
1clean335i's Avatar
Vietnam
414
Drives: Project Estoril
Please post up guys!
Im trying to decide on a pair of wheels for the track to match up with some drag radials. Right now im debating about going with a 17x9 +35 wheel with 275/40/17 bf goodrich drag radial tire...
'13 Estoril Blue 335i M-sport
*Don't PM me!* Message me here- http://www.facebook.com/ProjectEstoril
      10-29-2007, 12:23 PM   #2
oddjob2021
ASR Turbos+LSD+Meth= :D
oddjob2021's Avatar
73
Drives: E92 335i
2007 E92 335i  [0.00]
a 275 mm rear sounds like a 17x9.5 to me.... not 9
2007 335i Coupe
Mods: Check the Garage
      10-29-2007, 01:27 PM   #3
1clean335i
1clean335i's Avatar
Vietnam
414
+1. I agree and thats what I have for the Lexus (Supra TT wheels) for track. But I cant find a 17x9.5 lightweight wheel with a bmw bolt pattern..
      10-29-2007, 06:05 PM   #4
oddjob2021
oddjob2021's Avatar
73
Drives: E92 335i
strange honestly try 18's then, i dont think a +1 inch diameter will make as bad as a difference as getting 20 mm wider
2007 335i Coupe
      10-29-2007, 06:24 PM   #5
Chowbow
pew pew
166
Drives: 三三五i
Is it really impossible to fit 16s over the rear calipers? I didn't think the rear brakes were that big... Don't the 328s/325s come with 16s stock? Do they use the same brakes?
I'd really try to find a 16x9 rim and mount the DRs on that. If not a 275 then a 245, it should still hook hard... I've seen street cars cut 1.6s on 245 DRs.
I'm going to try and find a 16" and 17" wheel from a camaro or firebird or vette and see if it works. They use the same bolt pattern.
CSL replicas are now CSL counterfeits. Jesus saves, like Valentine1.
      10-29-2007, 07:46 PM   #6
1clean335i
1clean335i's Avatar
Vietnam
414
Really? The C5 vette wheels would be cool if the offset is right. Im not sure if 16's will fit or now but I know 17's will
      10-29-2007, 08:45 PM   #7
sofla335i
Drives: Sparkling Graphite 335i 6spd
The offset on C5 wheels is way off, and the bolt pattern isn't exactly the same, off by about .65mm or something like that. The specs on the 275's say they will fit on 9" wheels.
      10-29-2007, 11:04 PM   #8
oddjob2021
oddjob2021's Avatar
73
Drives: E92 335i
a 335 has much bigger rotors than the 328,330,325 cars. 13.7 front and i think 13.2 rear then add the caliper's height and 16's wont fit =(
2007 335i Coupe
      10-30-2007, 01:03 PM   #9
Chowbow
pew pew
166
Drives: 三三五i
Dang, OK, nevermind then.
      10-30-2007, 03:28 PM   #10
Evo8MRto335I
Evo8MRto335I's Avatar
Spain
40
Drives: can't list them all
17x8.5" will do it. 9.5" is overkill.
      10-30-2007, 03:29 PM   #11
Evo8MRto335I
Spain
40
Go kosei K1 from tire rack, they are 16.8lbs and only cost $165. Get the BF Goodrich T/A II, they are bettr than the T/A. With the configuration that I gave you you will save 13-14lbs per tire/rim. If you go with a smaller tire(265 or 255) you could save another 2-3 lbs per tire.
      10-30-2007, 07:28 PM   #12
oddjob2021
oddjob2021's Avatar
73
Drives: E92 335i
i searched tire rack but couldnt find the k1's only k3 which is only a 225mm width... any advice? im seriously considering a rear DR set up for tracking...
http://www.tirerack.com/wheels/resul...All&sort=Brand
2007 335i Coupe
      10-31-2007, 10:49 PM   #13
Evo8MRto335I
Spain
40
Uhmm... that is weird, I posted the source on this post:
http://www.e90post.com/forums/showthread.php?t=87825
OK, never mind, I know why, you were looking at 18" and the k1s are 17". The k3s are 18"
      11-01-2007, 10:29 AM   #14
1clean335i
1clean335i's Avatar
Vietnam
414
Thank you! I read in your thread that you ened up getting the Kosei's.... Any pics of them on your car? Also how did the 275's fit on them? I am probably going to go the same route as you now
      11-02-2007, 12:42 AM   #15
sambonator
Samtaro!
sambonator's Avatar
Drives: 2014 F32 N55 Alpinweiß
I ended up getting BBS RC's 18x8.5 37mm offset all around... for both drag and autox applications. I'm going with Kumho V710's 245/35-18's... hope they stick For sure it'll be better than my current setup, which is all show no go.
      11-02-2007, 01:55 AM   #16
Chowbow
pew pew
166
Drives: 三三五i
Honestly the Kumhos aren't a very good drag tire, and 18" isn't the best for it either. Nothing really beats a real drag radial or drag slick. The composition and properties of drag vs. autox and RR tires are very different. Regardless, it will still be stickier than stock tires on the strip, and a lot stickier on the autoX.
      11-02-2007, 02:01 AM   #17
sambonator
Samtaro!
sambonator's Avatar
Yes I know its going to be a compromise... but oh well didn't want to spend another ... $6-700 or so for a pair of Kosei K1's and Drag radials
      11-02-2007, 02:10 AM   #18
Chowbow
pew pew
166
Drives: 三三五i
I agree. I will probably skip on a drag setup as well and just go with an autoX setup which I would double up as drag use.
      11-10-2007, 04:09 AM   #19
Trill335
انا خارج الكلبه
Trill335's Avatar
9
Drives: E92 335
I have 18x10inch BBS CH's in M3 fitment on 275 BFG Dragradials.
No issues on my 335 Coupe with sports package (stock suspension).
