Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Mechanical Maintenance: Break-in / Oil & Fluids / Servicing / Warranty > best place to put a ballast for a hid kit
      10-29-2007, 07:13 PM   #1
jetblk328i
jetblk328i's Avatar
309
Drives: X3 M40i
in the engine bay, i dont wanna remove bumper or remove the wheel well...whats the best place....?
      10-29-2007, 08:53 PM   #2
NewBMWDriver
NewBMWDriver's Avatar
Drives: BMW 325i
you putting hid kit on halogen housing or you actually got the xenon housing?
06 325i - Standard
      10-29-2007, 08:55 PM   #3
jetblk328i
jetblk328i's Avatar
309
Drives: X3 M40i
well i think ill go with halogen housing then save up for all OEM
      10-29-2007, 09:05 PM   #4
NewBMWDriver
Drives: BMW 325i
let me know if it works out with the halogen housing and hit kit without warning. I'm thinking of doing the same but don't want to waste money on hid kits where it gives me warning. Still in college, so money is an issue right now.
06 325i - Standard
      10-29-2007, 09:06 PM   #5
jetblk328i
jetblk328i's Avatar
309
Drives: X3 M40i
will do, i think there is a way....
      10-31-2007, 02:41 PM   #6
HyperM3
Too many Alex's, from now on, call me Beaufort
Drives: See Sig
Its really not that hard to remove the fender lining. I just did it when I installed my LUX. Takes about 5 mins once you have the wheel off.
13 HD FatBob
17 A4 Glacier/Black 1st Edition/Pre+/Sport/EurocodeTMD/Racechip
16 S6 (gone),14 S6 (gone),14 S6 (gone),13 S6 (gone),10 S4 (gone)
07 335i(gone)
      10-31-2007, 09:11 PM   #7
NewBMWDriver
Drives: BMW 325i
Originally Posted by tinobw View Post
Doesn't matter its a halogen or xenon housing, it will no error warning if you install the module cable relay/resistor that comes with the kit. I install MTECH HID kit in adaptive xenon housing. Originally my car was halogen. No error at all!
How hard was it to do the wiring? or did it came pre-wire and all you have to do is connect things?
06 325i - Standard
      11-01-2007, 05:36 AM   #8
jetblk328i
jetblk328i's Avatar
309
Drives: X3 M40i
where is the back cover?any pics? thanks!
      11-01-2007, 10:56 AM   #9
tinobw
Drives: My Car
back cover
      11-01-2007, 03:21 PM   #10
jetblk328i
jetblk328i's Avatar
309
Drives: X3 M40i
serious? =( not a fan of drilling...
      11-01-2007, 04:54 PM   #11
NewBMWDriver
Drives: BMW 325i
My friend and I installed the hid kits on his e30 M3. It was easy, everything was pre-wired, all we had to do is drill a hole and connect the wires, and plus his car doesn't give any warning to anything so it was easy(Cheap). Drilling the hole on the back covers wasn't hard. We drilled it out and sealed it with hot glue. It's sealed very good. I'm just worrying about cutting any extra wires. If all I have to do (after i get the right hid kit without warnings) is drill 2 holes and connect the wire, I can do that.
06 325i - Standard
      11-01-2007, 05:00 PM   #12
jetblk328i
jetblk328i's Avatar
309
Drives: X3 M40i
yea thats all you have to do, i believe creative, jlevi, and UED are all selling these for 150 without errors.... hmm im not sure i want to drill, but i want hid kit.
      11-01-2007, 05:07 PM   #13
tinobw
Drives: My Car
thats all you need to do
      11-01-2007, 07:09 PM   #14
NewBMWDriver
Drives: BMW 325i
$150 for the error removal kit or for EVERYTHING?
06 325i - Standard
      11-01-2007, 07:50 PM   #15
scandluz22
Drives: 2006 330xi
2007 328XI  [0.00]
It's actually $149 + $20 for the resistors from Jlevi. With the resistors all you have to do is attach one end to the low beam positive and the other end to the ground and you should get no error. I just got my kit today and haven't hooked it up yet. I'll do it on Monday or Tuesday. The only difference with what you guys want to do and what I am doing (and what tino did) is that I am using OEM xenon housings.
"it remains the benchmark by which all competitors, including Lexus, must be measured."
      11-01-2007, 07:56 PM   #16
jetblk328i
jetblk328i's Avatar
309
Drives: X3 M40i
i believe that it may be 10-20 bucks more for error removal.
      11-01-2007, 10:03 PM   #17
NewBMWDriver
Drives: BMW 325i
Saw this on ebay: http://cgi.ebay.com/ebaymotors/MTEC-...spagenameZWDVW
Does that work correctly? Does that kit actually give out no error message?
06 325i - Standard
      11-01-2007, 10:09 PM   #18
tinobw
Drives: My Car
thats the one installed in my car
http://www.e90post.com/forums/showth...=84882&page=12
      11-01-2007, 10:28 PM   #19
NewBMWDriver
Drives: BMW 325i
o nice. The pictures look nice, what temp did you get? Do you have to do anything to replace from halogen to xenon after getting hid kit to work? I mean would you have to connect extra wire to the xenon housing?
06 325i - Standard
      11-01-2007, 11:27 PM   #20
tinobw
Drives: My Car
got 6000K. Yeah small rewired inside the xenon housing.
And a little modification on the spring clip which hold the bulb, http://www.e90post.com/forums/showpo...&postcount=241
