Coolant Change Problems
11-01-2007, 10:01 AM | #1 |
Rep 648
Got the oil and brake fluid done. But where is the radiator drain plug? I searched the DIY section but nothing came up. How have you guys changed the coolant fluid?
11-01-2007, 10:06 AM | #2 |
Rep 475
Good question but to simply add Water Wetter I was planning to use a turkey baster to suck coolant out from the under hood tank. Then replace what I take out with Water Wetter.
11-01-2007, 10:21 PM | #3 |
Rep 648
That will produce the least amount of temp drop. It would be much better to replace the entire mix with Water Wetter and water with only a small amout of coolant to prevent the heater core from freezing.
11-01-2007, 11:38 PM | #4 |
اوليسيس
196
Rep 4,678
there are instructions on this board somewhere but you need to search, i can't remember where i saw it. what i do remember is that the coolant drain plug has something to do with the intercooler, you have to dismount something, i want to say the IC itself, but i'm not sure.
