Auto Transmission failure warning
01-17-2014, 05:08 AM | #1 |
Rep 64
Driving around the CBD this afternoon (45deg) the transmission warning came on - advising to drive carefully to nearest service centre. The car only used 1st and 2nd gears around town with a very rough shift. It also was very slow to engage reverse. After I stopped and returned 10mins later the car started and all the problems resolved.
Should I be worried? Does it need to get looked at now that it works ok? Is it the high temp we're experiencing? |
01-17-2014, 05:44 AM | #2 |
Rep 853
I think the 320i uses auto uses a version of the GM 6l45r found in the x25, x30i etc engined cars.
It is a piece of garbage. I think you will find that the heat exchanger failed to let off enough heat to allow the ATF operate properly and the trans has entered a failsafe. ATF burns and like most oils will lose its ability to lubricate and allow the trans to shift properly. The Gl45r uses Dexron IV so it should be a lot cheaper to service. All you would need is the filter unit, O ring and about ~7ISH Litres of DX4 and it should be fine. |
