Help! Can't fix factory Xenon headlight. Troubleshooting?
01-18-2014, 09:16 PM | #1 |
Rep 177
My right low beam factory Xenon headlight began flickering on/off last week. It finally quit working all together. Upon searching E90post and others I found that the first step is switching the bulbs, the second is switching the balasts, then???
I have switched the bulbs and the ballasts and nothing makes the right headlight work. So it appears I have two good ballasts and two good bulbs. What else could it be? Thanks!!! |
01-19-2014, 07:10 PM | #3 |
Rep 177
Yes everything works on the left side. The swapped bulb, the ignitor, and I just now swapped the active headlights module. I assume the bulb, ignitor, and active headlight module all work because they always light the left side. I also check the fuses and connections the best I could at the headlight.
Any other suggestions? |
