Engine malfunction reduced power
01-20-2014, 06:24 AM | #1 |
Rep 6
Hi everyone, first post here...need some advice.
After driving a Mazda 3 for the last 3 years I decided to sell it and I bought a 2011 335i sedan M package w/ xdrive. Space grey on saddle brown. Car had 74k on it. I purchased it from a private dealer in my area (Toronto) and had a pre purchase inspection done at a local BMW dealership. Also had them check the computer to see if anything was erased. Total spent $340 to check it. Result: aside from rear tires, car was mint. Anyways.. I enjoyed it not even for two full days... And the engine malfunction light came on and went into reduced power mode which I see you guys call "limp" mode. So I went to my private dealer freaking out (Sunday)(yesterday) and he plugged into it and it said cam shaft position sensor. Have no idea what that means but I haven't found much information on it. So I'm thinking it's something to do with HPFP, or turbo related. Anyways the car is still under warranty with BMW. Can anyone shed some light on engine malfunctions, and camshaft positions sensors? Last edited by sjones88; 01-20-2014 at 09:10 AM.. |
01-20-2014, 11:00 AM | #2 |
Rep 1,052
Might be same as Eccentric Shaft Sensor or VANOS System (you have two of those I believe) but I don't have 335 so I can't be 100% sure.
I believe there are DIY fixes for both of those on the forums here.
'08 328i | TiAg | 6MT | CDV Mod | RevMotoring Silicon Intake Tube | AG M310 | Cold | Premium | HiFi | V1 Hardwire | AirPlay - FiiO DAC
'15 Golf SE Sport | Pure White |
01-20-2014, 03:17 PM | #3 |
Rep 6
Vanos sytem
So… BMW called me back, said it's the vanos system.. they ordered the part and I get the car back tomorrow. Is this a common problem? And… once fixed, is it likely to happen again?
01-21-2014, 06:35 PM | #4 |
Rep 2,015
DO It Man
Can you do you own work?
Vanos Solenoids.....not as scary as it sound. 2 of them. 1 intake and 1 Exhaust It is very easy, if you can do this, then you can change your own Spark Plugs and Coils. Go for it. tools will be a 1 time cost for life. DN |
01-23-2014, 03:35 PM | #6 | |
Rep 66
Took the car in stealership, the SA told me it's somewhat a common problem but BMW never issued a recall on it because they blame the gas in US comparing to the higher octane gas in Europe. Anyhow it's being replaced under warranty. I would say do your oil change often and try not to follow that ridiculous 15k miles oil change interval BMW recommends if you planning to keep the car for a long time. And there's plenty of DIY on here on how to replace the solenoids, how to clean them and what not, if you're willing to get dirty. Good Luck and Have Fun! |
02-04-2014, 08:34 AM | #7 |
Rep 1
Engine Malfunction! Reduced Power.
My 2011 335IS coded with the "Engine Malfunction! Reduced Power" light, and went into limp mode as others have described. Once BMW dealer ran a computerized vehicle diagnosis test, it was discovered to be a cracked charge air line to the throttle. Once air line was replaced, the car was back to normal.
