DIY: radio removal
12-16-2005, 10:43 AM | #1 |
Rep 12
DIY: radio removal
Hi,
to remove the radio (non-idrive), follow these instructions. To take out the radio, you will have to remove the element with the heater and a/c controls in it first. This is fastened with two clips on the sides: 1. take an old creditcard (or something similar) and bend one (short) side of it in a 90 degrees angle. 2. insert the card between the radio and the a/c-controls, bend side first. 3. move the card to the upper/side of the a/c-controls and pull it, making sure its bend side hooks behind the controls. 4. the a/c control unit should move forward a bit. Repeat step 3 for both left and right side. 5. you should now be able to pull the a/c controls forward. Then you can remove the radio: use a screwdriver to remove the two screws beneath the radio and pull the radio forward. Some pictures to clarify the way the A/c controles are snapped in: left side: Right side: Bottom of a/c control panel: Panel removed: Back side of panel: Where the panel came from (screws of radio are visible): Back side of the radio: |
12-16-2005, 11:11 AM | #3 |
Rep 1,002
Excellent writeup and very helpfull pictures for a question that is asked very often.
I wish I´d had the info in July when I first tried to take my radio out. Would have saved me a LOT of sweat. Thanks 12esc
No, not THAT kind of tierfreund!
12-24-2005, 08:47 AM | #5 |
Administrator
40828
Rep 21,240
Great DIY writeup, thanks for sharing! I've added this to the DIY list - http://www.e90post.com/forums/showthread.php?t=1721
01-16-2006, 08:09 AM | #7 |
Rep 4
mute on e90 ?
Hi , 12esc
I saw the the pictures from you ,how to take out the radio from my car E90 it is very helpfull thanks for it but like i can see you mounted a bluetooth carkit in it ,thats exactly what i want to do so i'm wondering is there a mute on the radio? and where can i find the ingnition power ( +15 )?. Thanks cotton |
12-14-2006, 09:19 AM | #8 |
Rep 51
Do you guys know what the consequences are when you leave to radio unplugged?
I quote a Japanese site translated by google: "Genuine audio relocates, corresponds to the update of the engine program Original genuine to reset, to the specification of audio also it is possible. It is linked to [ribasugia], alarm (the chime) sounds..." Does it sound important?
| 2007 E90 318i | sparkling graphite | styling 160 | blackline rear lights | chrome tailpipe | Pioneer Avic-X3 | ///M Short Shifter | ///M hand break | Future mods: 19" M5 replica wheels, Painted Front Splitters, Chrome Door Sills... |
12-14-2006, 09:27 AM | #9 |
Rep 6,563
thanks for sharing the diy with pics. But I am still lost on your description on how to use a credit card to get the control unit out. Do you have the credit card and could you snap a few picks of your credit card to give me a better pictures on how you use it? Thanks.
under construction! |
03-03-2007, 11:42 AM | #10 | |
Rep 108
My AC was very solid mounted. Solution: 1. Take an old credit card and make a gap between radio and A/C. You must see the metal hooks on the side. 2. Take a small screwdriver and press the metal through the gap. 3. When you press the hook it will realese the A/C controls I've unplugged my radio and I've lost only the time and radio stations. |
03-03-2007, 11:49 AM | #11 |
Moderator
132
Rep 6,775
Drives: TiAg E92 335
Nice write-up!
-Michael.
Berlina Black S2000 CR is now in the garage l 19" Rial Daytona Race l KW V2 l Eisenhaus Race Exhaust l |
01-22-2008, 02:14 AM | #12 | |
33
Rep 319
01-25-2008, 05:00 PM | #14 |
Rep 1,324
Gazza - Check out the DIY for "TVandNAV2go"
Was: 2008 335xi sedan 6MT Black Sapphire Metallic
Is: 2014 Tesla P85D (Blue Metallic) Wife's: 2013 Infiniti G37 S sedan 6MT, Black |
02-09-2008, 04:04 PM | #15 | |
33
Rep 319
04-23-2009, 09:24 PM | #16 |
Rep 1
10-28-2009, 04:13 AM | #18 |
Rep 64
very helpful diy..tnx…i needed it..hope I can find a diy for installing a new kool vue mirror in this forum because ive lost the manual for my newly bought mirrors..
12-05-2009, 07:53 PM | #21 |
Rep 455
Drives: '19 X3 M40i
I need some help with this... Tried a bent credit card mentioned above, tried plastic prying card, tried a custom-bent metal bracket. None have even budged the A/C unit. Tried prising out across the top, tried getting a grip from the sides near where the clips are shown in the photos above. Only thing that seems to want to come out is the plastic face panel (it seems to be permanently detached at a couple places now).
What is the technique for getting this (enter a year's worth of swear words here) thing out of the dashboard? I'm working under the assumption that the clips and the slot they're in is at an angle slightly downward, and that the panel should tip out from the top first.
2019 X3M40i DGM/black vernasca, 2T4, 2VF, ZPX, ZPP, ZDA, DWS06+, etc, etc. Since July'19.
2021 X540i MSport CBM/black merino, 337, ZMP, ZPP, ZPK, etc. Since Dec'20. 2006 330i SGM/black, ZSP, ZPP, 217, HuberOps, M Splits, K Lines, AS 3 on EC-7. Sep'08-July'19. |
12-06-2009, 03:45 AM | #22 |
Rep 190
This is how I did.
You will find on top of the AC contorl two gaps if you slitghtly push the plastic cover outwards. Insert a screwdriver inside them and press down an pull out at the same time each at a time. It should come out with a bit of force. |
