N52 325i oil change question
01-26-2014, 06:46 AM | #1 |
Rep 716
I recently bought a 325i and I have noticed the when checking the oil level it is only 2 bar above minimum. I have some oil I used to top up my old car "helix 5w30 fully synthetic" would it be ok if I topped up my oil with this ?
The car oil was only changed about 2k miles ago however I do plan on changing it again myself but I'm just wondering what the best way todo it with the electronic level detector. Do I get someone to sit in the car and tell me when ?
BMW 325i M sport - Custom stainless exhaust ( 335i set up ) - Piano black interior trim - Gloss black kidney grills - Ferric grey 18" MV3 alloys -
01-26-2014, 06:52 AM | #2 |
17315
Rep 18,737
No. Wait until the car tells you it is a full liter low then add a full liter of oil. The e-dipstick does not provide an instantaneous reading of the oil level. If you try it the way you are thinking you will probably over fill the engine with oil. Read the owners manual, it tells you how and when to properly add the oil.
01-26-2014, 11:23 AM | #3 |
200
Rep 1,834
Drives: '05 E90 330i Manual
Best is to wait until the car asks for 1 quart or 1 litre of oil. As said above, it does not show an instantaneous reading and it only reads on increments, so safest it to simply add the specified amount when asked to. It is also quite important to stick to the same oil that the car has currently when topping up. Some oils are fully synthetic and others are hydra-cracked mineral based oil.
01-26-2014, 12:16 PM | #4 |
Rep 1,160
Wait till it tells you to add oil
Monaco Blue 330xi - Terra Interior/6-MT/Sport/Premium/Cold/CSL's/M3 Spoiler Lip/Black Kidney's
01-26-2014, 01:12 PM | #5 | |
Rep 716
I wish the car just had a dipstick !!
01-26-2014, 01:43 PM | #7 |
Rep 716
Thanks for the replies. Chances are I will be changing the oil before it tells me to top up anyway as from what I have read these engines don't seem to burn oil very quickly.
What is the best method of getting the correct level when filling up after draining the old oil out ?
01-26-2014, 05:07 PM | #8 | |
17315
Rep 18,737
01-26-2014, 05:08 PM | #9 | |
Rep 1,160
01-26-2014, 05:16 PM | #10 |
Rep 716
Should I remove the oil filler cap when draining the oil and also should I do It while the engine is hot ? Would the oil level sensor recognise if you over fill it over the "MAX" level ?
01-26-2014, 05:19 PM | #11 |
17315
Rep 18,737
01-26-2014, 05:56 PM | #12 |
Rep 716
I just put it through the converter on my phone but it's giving me 2 different answers. hmmm I'm confused now.
01-26-2014, 05:58 PM | #13 |
200
Rep 1,834
The electronic dipstick measures in increments of 25% in mine being a non iDrive model, so in iDrive models the number of increments may differ, but still much the same problem in terms of not being able to "fine adjust" as you would with a proper dipstick.
Best is to drain the oil from hot with the car as level as possible (with the oil filler cap and oil filter cap open), although I do reckon that even if only the nose if lifted, all the old oil will eventually drain - I usually let the oil drain and leave it for 10 to 15 minutes. On my car the drain plug is very much towards the rear of the sump anyway, so the oil can still only go down... Yep, for those like me that are on the metric system, 7 quarts translates to 6.5 litres of oil (also the metric specified quantity according to the operating manual). What I do is start by adding the full 6 litres first and then run the engine, then go for a drive and once I get a 50% reading (mine tends to first show 25%, then later on it shows 50%) I return and add the remaining 500ml. If you do for some reason over-fill the engine with oil it will show that it is over max, and will probably warn you too, but best to check. According to the operating manual, on a non iDrive model if it shows an OK below the level and the level us up to the line on the right side you are fine, but if the level goes over the line and it shows MAX below then you have over-filled the engine! |
