coolant flush
01-29-2014, 05:04 AM | #2 |
No 55mph
1622
Rep 8,476
Never knew a dealer of any manufacturer to use distilled water - however, if I replace my own coolant I always do.
Whatever you do - NEVER use Distilled/De-ionized water...
F32 435ix//MGM//M Sport-Prem-Tech-Driver Assist-Lighting-Cold Weather-Dyn Handling Pkgs//M4 Black Lthr Int w/M4 Alum Blade Trim//HK w/Bavsound Stg3//763M//M4 Euro LCI Tails//M4 Mirrors w/CF Covers//AWCarbon CF F/R Spoilers-Side Splitters-Diffuser 6WB/ID6 HU+HUD/IND M4 Alcantara Armrest//PURE S2 Turbo//AA FMIC+DP//ER CP+TIC//3.5bar TMAP/TS DV//AWE Tuning Exh w/Blk Tips//Turner MS CF Intake//BM3 Cary Jordan Tune//MPerf Diff//PrecRW Ignition Kit
01-29-2014, 09:57 AM | #4 | |
Rep 403
Drives: 2007 BMW 328i
You should serious consider doing it yourself if you plan to keep the car if for a long time. |
01-29-2014, 10:21 AM | #6 |
Rep 2,189
Doesn't surprise me at this point.
Pretty sad when a weekend wrench turner can do a better job with the details then a high dollar an hour dealership that's been in the biz for awhile. |
01-29-2014, 11:54 AM | #7 | |
Rep 944
01-29-2014, 12:13 PM | #8 | |
No 55mph
1622
Rep 8,476
Distilled water & De-ionized water are two different animals Distilled Water Typically what is easily found in 1gal jugs in grocery stores. You want to run Distilled water in your radiator (and batteries if you have the lead/acid liquid type that can be filled) because it is essentially tap water with all the solid impurities/minerals removed. While some ions related to the solid impurities will be removed in the distillation process; it is still ionized (charged). If not removed, the minerals can:
De-ionized Water Or 'non-conductive' water, is also a purification process, but not typically found on the shelf at your local grocery store. It involves a different process wherein typically the water is passed thru 1 or 2 columns that are filled with resin beads that remove ions (cations/anions) from the water. While Distilled/De-ionized water is purer than just Distilled water, DI water is not optimum to run in cooling systems. Because the DI water lacks ions, it wants to 'get the ions back' essentially pulling/disolving/leaching the ions from any adjacent surfaces (such as the metals in your cooling sysyem) - this removal of ions from metal causes corrosion - actually 'eating' the metal. Metals typically affected include aluminum, copper, & even some grades of stainless steel. Best way of selecting water to use in your cooling system would be by testing/knowing it's PH value (which is actually related to the ions present in the water). Optimum water to use would have a PH of 7 - which is considered 'neutral'. But selecting water in this way is normally not what the everyday person would do... In the industry I am in - we employ many different types of cooling systems to remove heat from ultra hi temp reactors/furnaces (400 to 2100 Deg C). At one point, employees were mistakenly filling the cooling reservoirs with DI water from the hi grade system in the Lab - thinking that was best because it was the 'purest'. It only took months to go by before we started noticing numerous leaks at O-ringed interfaces between metal components of the cooling system. When torn down & inspected - the aluminum & stainless surfaces were heavily corroded & eaten away. Chemists advised not to use DI water for the reasons I stated above - after switching to ONLY Distilled water (and all new metal components) - there has never been another problem...
01-29-2014, 07:16 PM | #9 | |
Rep 3,066
