Oil level after change at dealer
01-29-2014, 09:08 AM | #1 |
Rep 58
I brought my 328i coupe to the BMW dealer to have the camshaft bearing ledge replaced. Since I was concerned that they are opening up the cover and the oil is exposed, the SA told me he would change the oil for me as well under good will . Anyway, when I picked up the car, I noticed that the oil level is at the same level as it was when I brought the car in (see pic below).
Is this normal? When you change your oil at the dealer, is the oil level usually around the same place as it is with mine in the pic? Thanks for your input! |
01-29-2014, 09:22 AM | #3 |
Rep 58
01-29-2014, 09:24 AM | #4 |
Rep 1,355
call them and tell them. THey might just say they did it and say to come back in for a top off. No way of really knowing the truth. CHange it reguarly as if they didn't change it just to be safe
01-29-2014, 09:28 AM | #5 | |
Rep 58
When I had my Toyota Celica I never brought it to the dealer b/c I just don't trust they the tech's actually do it or do it right... I'm skeptical in nature. Anyway, for the BMW I was going to bring it to the dealer to have the oil change oil b/c they charge so little ($90)... For the extra $25 or so that I would have to pay someone to do it (versus what it would cost me) I was going to just let them do it. But, after this experience, I am reconsidering.... -_- |
01-30-2014, 08:48 AM | #6 |
200
Rep 1,834
Drives: '05 E90 330i Manual
It is supposed to be on the max mark, that is currently showing a 75% level. If they did the work yesterday and you only got the car back now it might (to a small degree) be that it still needs to register the full amount, it can sometimes take a while, but definitely not more than a day if you have been driving for a while.
I would ask them to explain why the oil level is like this since they changed the oil (as asked to), but to be honest, it comes down to trusting if they did this or not and if you are willing to do this. I probably would just DIY change the oil myself for the extra peace of mind. I lack faith in dealerships these days... |
01-30-2014, 08:58 AM | #7 |
Rep 1,355
i know exactly what you are saying when you say you expect more bc it is a BMW dealership. I totally agree with you but humans lie and make mistakes all the time.
I was pissed when my friend i used to work with at a professional auto garage got a job at audi. We did basic maintenance and troubleshooting and this kid was certified and double gasketed three cars in two months. Blew two motors because he walked away and forgot to put an oil filter on the car. ANd this kid is working on your BRAND NEW AUDI!!!!!!! |
01-30-2014, 09:11 AM | #8 |
Rep 675
01-30-2014, 09:17 AM | #9 |
200
Rep 1,834
Okay, what is 25% of 1 ltr? It's 250 ml, so what are you disagreeing with? Between min and max is 1 ltr difference, but since you are relying on an electronic dipstick that only works in increments of 25% it is not so easy to simply add 250 ml...
01-30-2014, 09:40 AM | #10 |
Rep 675
Your statement was that it's showing 75% level, which I interpreted as 75% of the entire oil capacity which is significant. Apologies for misinterpreting your post.
01-30-2014, 09:43 AM | #11 |
200
Rep 1,834
Well, obviously I meant 75% of the min to max level - I usually specify that detail... No problem BTW!
01-30-2014, 09:54 AM | #12 |
Rep 58
I talked to the SA via email and he said the following:
"That oil level is just right. Since it’s an electronic estimation system, it will actually vary a bit. The only time you want to add oil is when the indicator actually comes on for +1 qt. You want the oil level in between the 1/4 way mark and max." Guess I just have to trust. |
01-30-2014, 10:24 AM | #13 | |
200
Rep 1,834
If you are comfortable trusting them then that's fine. |
