got some weird codes - thoughts?
01-29-2014, 11:56 AM | #1 |
Team Zissou
3077
Rep 10,198
I checked for codes because my car had been giving me a "service due" warning every time I started up. These popped up:
2DC3 Monitoring, terminal 15 (fault currently not present) 2E8D Intelligent battery sensor, signal transmission (fault currently not present) 2EE6 Coolant-temperature sensor, measurement range (fault currently not present) Anything battery related scares me because of the battery cable issue I had a while ago. I'm going to be driving a few hundred miles in a couple days. Based on your experiences with these codes... what's the over/under my car is going to leave me stranded? |
01-29-2014, 05:26 PM | #2 |
38
Rep 634
You should be able to go into the idrive and look under service(or something like that) and it will display what service it thinks is due. The codes just sounds like historic codes that you could clear and see if they come back. Hope that helps, JP!
