It seems that Mobil 1 0w40 euro formula is not quite as good as BMW 5w30
02-04-2014, 06:32 PM | #1 |
Rep 1,465
I just switched from BMW 5w30 to Mobil 1 0w40 last october 2013. Not even 3 months later, within about 4500 miles, the oil consumption is much higher as I needed to add half a quart every month. After 6873 miles, I decided to remove the Mobil 1 oil. I usually change at 7500 miles on the BMW 5w30 but this time did it earlier. I typically only need to add about 1/2 quart of BMW 5w30 every 6000 miles (4-5 months time). But this time, I had to add 1/2 quart in under 3 months.
Immediately, I noticed that the Mobil 1 0w40 oil (european formula) is quite gunky and more thick as it came out. Usually, the BMW 5w30 was brown but came out more fluidly. The Mobil 1 flowed out a bit slower. I'm starting to think that this oil is too cheap and can not withstand the stresses of the n54 and I might go back to using BMW 5w30. Either that, or it's "Walmart" formula...... I got the oil at Walmart for $24.97 for 5 gallons. That works out to about $5 a quart. BMW oil is $7-8 a quart. Either that, or I may have to start changing this Mobil 1 oil more often at 5000 miles instead. Anyone of you observed this on Mobil 1? Yes, I am using Mobil 1 European Formula rated for LL-01 BMW spec. Yes I didn't go beyond 7000 miles. No, I don't beat on my car. It's 75% highway miles, and it never used to burn much oil until I switched over to 0w40. |
02-04-2014, 07:22 PM | #2 |
Rep 936
I just put mobil 1 0-40 euro formula in mine the other day. So glad I did, car seems to like it. My oil didn't feel gunky at all, it felt super fluid as I poured it. I ran bmw 5-30 and I wasn't a fan of it, felt real sluggish in the car and seemed to make it run rougher. I got the 5 quart jug and two quarts from Walmart as well. Maybe theres a difference for the n54 vs n52?
02-04-2014, 07:47 PM | #3 |
Rep 1,131
Actually your thread should read Mobil 1 0-40 is not as good as Castrol 5-30. BMW is rebranded Castrol.
That aside, I find it implausible that anyone can tell the difference between two relatively similar oils without lab analysis. |
02-04-2014, 07:55 PM | #4 |
Rep 6,092
ive been using mobil1 0w40 (euro formula) since ive bought the car several yrs ago and no issues like what you mentioned. 10k in between changes and i probably only have to add 3/4 qt during those 10k miles. 78k miles on the odometer and still going strong.
02-04-2014, 07:55 PM | #5 |
7406
Rep 10,215
There's actually a guy on here who did a lab analysis and found the results to be exactly what the OP stated. I believe the thread is somewhere in the maintenance section.
02-04-2014, 09:04 PM | #6 |
Rep 1,465
I'd love to see that data. I'm very positive that I know what I'm seeing and I've done 9 oil changes on this car with the BMW 5w30 Castrol and the first time draining the Mobil 1 0w40, I can already tell that this oil is coming out thicker than usual and more sluggish. Pouring the bottle in, yes the Mobil 1 0w40 is thinner, but coming out, it has definitely quite a difference in viscosity (oil thickness).
02-04-2014, 09:28 PM | #7 |
Rep 1,311
I just use it to hold me over to the next oil change. Once my engine calls for a quart, I know an oil change is due soon.
02-04-2014, 09:29 PM | #8 |
Rep 87
I think you need to consider the weight of the oils. 0w compared to 5w and 40 compared to 30. When cold, mobil1 will be thinner and when hot, mobil1 will be thicker.
If I'm wrong, I'm sure someone will correct me. Last edited by BluesDriver; 02-04-2014 at 09:38 PM.. |
02-04-2014, 09:47 PM | #9 |
Rep 143
160k miles running on M1 0w40 every 4-5k. Oil drop 1/4 quart in 4.5k with cobb aggressive (needs 1 quart every 18k miles). M1 is pretty good in my book, don't worry too much OP.
02-04-2014, 10:12 PM | #10 | |
Rep 1,185
I checked the loss in the I-drive before i changed the oil and its barley moved. It was only 3/4th from full according to my Idrive. If your oil is gunky or thick its possible that our engine is having some kind of internal issue that has yet to show up. Its also possible that its your turbos since your turbos need the same oil. Another possibility is that you have a lot of gunk on your intake valves and during your last 7k miles some of that gunk broke of the valves and ended up being burnt then mixed into the oil. I can't say for sure what your problem is but for me I didn't notice any issues with this oil. Its been running strong and I even ran full e85 through it in the summer months and drove its semi hard as well. No track days, but i do love to floor it getting onto the freeway or take off at a light ect...
2015 BMW M4 F83
2009 335i X-Drive | GC 2.0 Turbos (sold) 2009 335i e93 (Sold) 2007 Bmw X5 (Sold) |
02-05-2014, 12:12 AM | #11 | |
138
Rep 2,731
FWIW, I had the bmw dealer oil changes the first 100K mi, the next 85,000mi have been diy and mobil one. I have had my valve cover off a couple times and the difference after mobil one was noticeable. |
Nor_Cal_335i7.00 |
02-05-2014, 12:30 AM | #12 |
Rep 712
See the article from Consumer Reports on oil consumption.
http://autos.yahoo.com/news/consumer...140000066.html
SOLD - 2007 BMW 335i Sedan, Montego Blue with Lemon seats, AluFelgen CS7 rims & Continental DW tires
CURRENT - 2018 Chrysler 300S, Crystal Granite Metallic. |
02-05-2014, 12:57 AM | #13 | |||
Gateropode
329
Rep 2,848
02-05-2014, 05:59 AM | #14 |
underground
63
Rep 331
Drives: alpine white 335 E92
Try redline oil. I really like it.
02-05-2014, 09:19 PM | #15 |
Rep 296
120k miles, changed every 10-15k on M1 0w-40 (except dealer changes). Had the valve cover off last week to replace the gasket, and inside looks pristine. Mobil 1 seems to be working fine IMHO.
2007 335i Sedan / Black Sapphire / Sport / Auto / FBO (Retired)
2013 535i Sedan / Black / MSport / Auto |
02-05-2014, 09:30 PM | #17 |
Rep 2,301
'07 335I here with 114K street and hard track miles. Mobil 1 0W40 all day, every day! One of the toughest oils I've ever used. The car does seem to drink the stuff, but I can't blame the oil for that. Any BMW over 50K miles will drink oil. It's just the facts of life.
'07 335I w/ Mods
'13 X1 Stock '11 X3 K&N |
02-05-2014, 09:37 PM | #18 |
Rep 2,136
This thread is a fail! Backyard engineering at its best.... "The Mobil 1 oil looked thicker so it's junk"
Have you considered temperature? Were you changing your oil while it was cold? |
02-05-2014, 11:49 PM | #19 | |
Rep 791
Drives: 2011 550xi
I'm a Liqui-Moly 5W-30 (top-tec 4200) guy, changes every 7000km, following the turbo car 1L oil = 1000km idealism.
2017 Nitro Blue Ford Focus RS 2008 Sparkling Grey Metallic 135i 6MT - JB4 G5 - MHD Race BEF - N54Tuning DP's - ER Chargepipe/w HKS SSQV - Coolingmist Progressive Meth - MMP Hot Side Inlets - AFE Exhaust - Seconday Cat Delete - AMS FMIC - BMS Catch Can - Rob Beck PCV - LUX 160 AE Last edited by Alohaaaaa; 02-05-2014 at 11:57 PM.. |
02-05-2014, 11:57 PM | #20 | |
Rep 1,157
and the oil coming out thicker and dirtier is because the more effective additive package is cleaning out your engine better and is full of contaminants from after using a less effective oil but I have never used m-1 in my bimmer. used it(full synth mobil) with much success in my air cooled ducati(high localized head temps...) and other bikes. always used catrol ll-01 in the bimmer |
02-05-2014, 11:58 PM | #22 | |
Rep 791
Drives: 2011 550xi
2017 Nitro Blue Ford Focus RS 2008 Sparkling Grey Metallic 135i 6MT - JB4 G5 - MHD Race BEF - N54Tuning DP's - ER Chargepipe/w HKS SSQV - Coolingmist Progressive Meth - MMP Hot Side Inlets - AFE Exhaust - Seconday Cat Delete - AMS FMIC - BMS Catch Can - Rob Beck PCV - LUX 160 AE |
