Fiber optic hook up?
02-19-2014, 07:55 PM | #1 |
Rep 6,968
Drives: 2007 Black/Black 335i e90
Anyone know of a double din navigation head unit that has a fiber optic in and works with the BMW logic 7 amp
02-21-2014, 01:44 PM | #4 |
Rep 6,968
Are you saying to piggy back the OEM head unit to the new NAVI unit?
DIY?? Please Advise |
02-21-2014, 03:07 PM | #5 |
1918
Rep 13,117
The basic answer is there is no way to use the l7 amp
without the stock head unit . And there won't be till someone makes a reverse translation circuit that converts analog to the fiber optic output and either incorporates it into a head unit or as a stand alone device. Yes you can still build a system but there is no way as of yet to integrate the L7 amp into an new system using and aftermarket head unit. If you are replacing the amp you aren't integrating it into the system. |
02-21-2014, 03:21 PM | #6 | |
Rep 5,120
If that doesn't scare you away I can give you some more info on this. Do you have a certain headunit in mind? |
