Rusty Coils and sludge in spark plug well?? Flood?
02-22-2014, 01:16 PM | #1 |
Libertarian
132
Rep 1,577
I changed my spark plugs the other day for the first time since buying this car in August 2013. I tried some non-oem plugs, and ended up putting the originals back in but that's another post. I noticed two things in this process which concern me a lot.
In #2, there was a thick sludge, looking like black river mud at the bottom curve of the bottom of the spark plug well. I wanted to clean it, but didn't want any of it to fall down into the engine. So I left it, figuring it was benign where it was sitting. This is a pic of #1, which has a little sludge, but not nearly as much as #2. I forgot to take a pic of #2 when I had it out, but I will when I finally get my new BOSCH plugs delivered... Sorry for the photo quality, but cameras don't like to focus on 3 planes. The coil from cylinder 1 looked ok, just had some brown powder like dirt on the rubber tube. #3 has some sludge in the well, although much less than #2. #4 had some chalky white residue at the bottom. I wasn't too concerned. #5 and 6 wells seemed clean. But, in #4, the coil looked like this: and the other side I am concerned. I can only think that this would occur if water had gotten into the engine, like in a flood situation. Can a coil rust like this under normal conditions? Or did something happen to my car before I bought it? Is there any particular part on the car that I could inspect that would be hard to clean if someone was trying to cover up a flood damaged car?
2011 335xi Coupe BSM (e92/N55/ZPP/ZCW, Alpina B3 Flash)
Bought 08/09/2013@53,340mi Current 3/13/2019@206,283mi Fail(s): tstat hous/water pump 89k, Chargepipe 106k, coolant tank 114k, FRM3 114k Maint: Walnut blast 101k, Trans/T-case Fluid 103k, OFHG 195k Last edited by GB-335xiCoupe; 02-22-2014 at 03:57 PM.. |
02-22-2014, 05:52 PM | #3 |
Rep 567
Drives: 2007 328i
where is it from???
Stay clean my friends |
02-22-2014, 06:31 PM | #4 |
Libertarian
132
Rep 1,577
Where is what from? The ignition coils are from my N55 engine. The car was previously owned in Chicago (one owner). CARFAX is clean. I'm thinking there's gotta be somewhere on this car I can look and see a clear indication of flood damage. Inside is clean though, and no signs I saw inside the trunk.
Bought 08/09/2013@53,340mi Current 3/13/2019@206,283mi Fail(s): tstat hous/water pump 89k, Chargepipe 106k, coolant tank 114k, FRM3 114k Maint: Walnut blast 101k, Trans/T-case Fluid 103k, OFHG 195k Last edited by GB-335xiCoupe; 02-22-2014 at 06:45 PM.. |
02-23-2014, 06:54 AM | #6 |
17315
Rep 18,737
When I first looked at this post I couldn't understand how any rust could form because the coils are plastic-bodied on the N52 and the head is aluminum. Looking at it again and realizing the engine is a N54, I guess the coil bodies are steel (hence the red iron oxide). The N54 head is aluminum, so I'd say it is a classic case of galvanic reaction causing the corrosion, not water. But what I can't understand is all the trouble BMW goes through to use aluminum bolts throughout the N52/54 engine, why would they choose the coil bodies to be steel? Are those OE coils?
02-23-2014, 07:24 AM | #7 | |
Libertarian
132
Rep 1,577
02-23-2014, 08:20 AM | #8 | |
17315
Rep 18,737
So it is either simply galvanic reaction of dissimilar metals or just plain old condensation causing the rust. |
02-23-2014, 03:43 PM | #9 | |
Rep 567
Drives: 2007 328i
02-24-2014, 07:40 PM | #10 |
50
Rep 388
rusty coils
I have seen the same thing ( rusty coils) on an X5 with N55, and it was caused by a smart engineers who have designed the " shelf " under the windshield ( and at the rear of the engine bay ). It is made out of three plastic sections if I recall correctly but the main thing is that as it is jointed at the middle... well the water ( rain or ice melting ) comes down right in the center valley directing the water right on the three coils at the back especially.
Now I know that there is a fix that BMW is doing, and they are replacing the middle section ( on recall ) and sealing the joints tight. So there is no more water dripping on the damn coils. Now reading this tread, I have to go and check out MY own N55 just to make sure I don't have the same crap happening to my coils on my 335i... Never-ending quest of fixing things that should not brake in the first place... Gotta to love BMW ! |
02-24-2014, 08:00 PM | #11 |
Libertarian
132
Rep 1,577
Yes, we love them anyway! We love to drive them. We love to work on them. It's a hobby.
Bought 08/09/2013@53,340mi Current 3/13/2019@206,283mi Fail(s): tstat hous/water pump 89k, Chargepipe 106k, coolant tank 114k, FRM3 114k Maint: Walnut blast 101k, Trans/T-case Fluid 103k, OFHG 195k |
