FS: Brushed aluminum vinyl wrap for interior trim
02-24-2014, 11:10 PM | #1 |
23
Rep 321
Have some left from my recent install. Very nice material and super easy to work with. Much better grain and appearance than the 3m...I've sampled all the other brands. This is enough to do one full set pre lci e90 if you don't have issues. It's about 1ft by 7ft. The center section will have an unnoticeable seam if you take your time, or do vertical grain. I was able to diy this a few hours with a hairdryer never having worked with vinyl before, and it looks perfect.pics coming soon $25 shipped to conus |
02-25-2014, 05:52 PM | #4 |
23
Rep 321
02-26-2014, 01:59 PM | #8 |
23
Rep 321
Honestly it turned out pretty good for never worked with the stuff before. Only a few areas where the vinyl tore because I was not careful enough...cant notice it unless you are looking. The seam on the CC is also not noticeable unless inspecting it closely.
What I have left should be just enough for another car...if you are efficient in cutting. Its very stretchable with heat, probably 30% |
02-26-2014, 02:19 PM | #9 |
No 55mph
1622
Rep 8,476
So you have to use 3M Super 77 Spray to attach this film - it's not self adhesive backed?
F32 435ix//MGM//M Sport-Prem-Tech-Driver Assist-Lighting-Cold Weather-Dyn Handling Pkgs//M4 Black Lthr Int w/M4 Alum Blade Trim//HK w/Bavsound Stg3//763M//M4 Euro LCI Tails//M4 Mirrors w/CF Covers//AWCarbon CF F/R Spoilers-Side Splitters-Diffuser 6WB/ID6 HU+HUD/IND M4 Alcantara Armrest//PURE S2 Turbo//AA FMIC+DP//ER CP+TIC//3.5bar TMAP/TS DV//AWE Tuning Exh w/Blk Tips//Turner MS CF Intake//BM3 Cary Jordan Tune//MPerf Diff//PrecRW Ignition Kit
02-26-2014, 02:40 PM | #11 |
No 55mph
1622
Rep 8,476
OK, only reason I asked is on Destron's Garage install instructions for their wraps, they show having to use the 3M. For what I want to do (not interior trim) that would be no good...
If it truly is pressure sensitive adhesive backed with the air channels - I'll take it & give it a try. PM me your PayPal
02-26-2014, 02:46 PM | #12 |
23
Rep 321
Sent.
Some tips for install- Pull all your trim off first and align it on the vinyl so you get the most efficient use of the vinyl. If you end up being short ill pm you a link to get more for cheap. Use a hair dryer on the contour parts and stretch it. This takes practice and patience.. The vinyl is forgiving and lets you adjust several times. On the holes for vents and shifter,put a lot of heat on the opening and push the vinyl down so you can get some on the inside. Use exacto when you want to trim or cut. Be sure the trim is clean and your hands are free of any oils when handling so it doesnt affect the adhesive |
02-26-2014, 02:59 PM | #13 |
No 55mph
1622
Rep 8,476
10-4
Just sent ya over payment...
03-01-2014, 12:55 PM | #15 |
No 55mph
1622
Rep 8,476
Received the vinyl today - thanx for the quick ship
The brushed texture is great - it will work just fine for my application Good Seller
