Good reason why Valve Cleaning is important
02-27-2014, 09:48 AM | #1 |
Rep 848
Drives: '01 E39 540iA, '09 E90 M3
Found this on one of the 'other' sites. Interesting read.
http://www.german**********/showthread.php?51640-Just-how-much-does-direct-injection-carbon-buildup-hurt-B7-RS4-gains-42-wheel-horsepower-after-034Motorsport-carbon-cleaning&p=545872#post545872 Audi B7 RS4 gains 42 whp after cleaning. I think it's time on my car, just need to find somewhere that isn't the dealer to do it in West Michigan...
E90 M3 DCT LCI | E90 LCI N54 M-Sport(retired) | E90 Technical Docs download: http://j.mp/bmwe90docs *good read, very detailed.
02-27-2014, 09:56 AM | #2 |
Rep 457
There are plenty of pics in this forum too. I have an 09 with 55k and am getting hesitation and sputtering under moderate acceleration between 2500 and 4000 RPMs, but no codes. I just got the Walnut blasting approved under my CPO and getting it done in the next two weeks, really happy BMW approved it. I just recently had my plugs replaced, a coil, and an injector bank. Hoping this cures my car's ills.
//|Phil
Current: 2011 Audi S4 Gone: 2009 e90 335 |6MT |
02-27-2014, 10:06 AM | #3 |
3441
Rep 79,211
Link doesn't work (banned site) but no surprise on it making more power. I keep pushing guys to get it done by 35K but most people wait for problems before they do it. It's understandable to a certain extent but as a proper maintenance it's a little backwards. It's kind of like not changing your oil and just saying you will wait for it to burn off or the engine to seize. The dealers charge too much. I would find a reputable independent BMW shop that is proficient in it. You could save 100's that way.
02-27-2014, 10:11 AM | #4 |
Rep 2,301
I'm at 115K miles, 10/06 build date. I've never done this procedure, and the vehicle doesn't have any issues traceable to it. I'm not saying it's a bad thing to do, or that I don't have build up, but it seems that even though the engines are DI, proper maintenance can seriously ward off this problem.
'07 335I w/ Mods
'13 X1 Stock '11 X3 K&N |
02-27-2014, 10:14 AM | #5 | |
sudo su -
52
Rep 236
I'm not sure what you mean by proper maintenance -- what kind of maintenance do you have in mind that could prevent the build up? |
02-27-2014, 10:21 AM | #6 |
13
Rep 342
Drives: E90 Monaco Blue 335i xdrive
I got it done at Helix at 50k and I saw the before and after...It was pretty bad in there and I didn't have any stuttering or anything. Just preventative. I'd recommend it.
2010 E90 335i xdrive | Monaco Blue with Black Interior | All Packages except Sport :/ | Apex EC-7 | Active Autowerke Strut Bar | Roc Euro DCI | Roc Euro Hyperboost DVs | aFe Scoops | BMW Performance Exhaust | BMWCCA member
02-27-2014, 10:29 AM | #7 | |
41
Rep 1,257
02-27-2014, 10:35 AM | #8 |
Rep 2,301
You seem to aways answer my posts.
'07 335I w/ Mods
02-27-2014, 10:38 AM | #9 |
Rep 2,301
I use BMW approved oils, maintain strict drain intervals, occasional fuel injector cleaner (I know this doesn't affect deposits), and lastly, motor flush (surposedly not reccomended for turbo engines, but I've done it anyways. It works because my oil pan was super clean when we changed the gasket).
'07 335I w/ Mods
02-27-2014, 10:39 AM | #10 |
Rep 2,301
Then how do you explain the fact that I haven't done my cleaning, and my vehicle runs fine, without any issues after 8 years, and 115K miles of street and track use?
'07 335I w/ Mods
02-27-2014, 10:44 AM | #11 | |
421
Rep 1,643
2007 E92 335i MT
02-27-2014, 10:56 AM | #12 | |
sudo su -
52
Rep 236
I think most of us use BMW approved oils -- hell that's all my motor has ever seen. The oil I get is the exact same stuff that's delivered to the dealerships. As you said, I don't think fuel injector cleaner would change anything -- beyond keeping your injectors clean. Motor flushes seem to be controversial (understandable for turbo'd engines) -- but that aside, what would the benefit be in this context? Are you proposing it would prevent oil from misting into the intake system? |
02-27-2014, 11:01 AM | #13 |
2095
Rep 43,350
I'd be willing to bet you the cost of the cleaning that your valves are incredibly gunked and there will be a noticeable peak HP difference if you dyno before and after a cleaning.
02-27-2014, 11:09 AM | #14 |
Rep 49
Anyone know where in MA (besides the stealership) I can get a walnut blasting (sounds perverted) I'm at 116k and I'm sure it could use it I have dci, vrsf cp/hks bov, and Rev 3 installed, vrsf fmic and catless dp's sitting in my garage waiting for a good day to sswap em. Have a misfire issue I'm in the process of investigating (waiting on plug socket) and thinking this should be done as well.
02-27-2014, 11:20 AM | #15 | |
3441
Rep 79,211
http://www.e90post.com/forums/showth...valve+cleaning http://www.e90post.com/forums/showpo...0&postcount=71 |
02-27-2014, 11:30 AM | #16 | |
469
Rep 4,392
I myself don't get any of the symtoms, car is a DD, and I put more than 100 miles a day on it, most of it is highway mileage. Will have my intake checked soon to see if cleaning is needed. Edit: after breaking 2 chargepipes it was drenched with oil so I can only imagine |
02-27-2014, 11:58 AM | #17 | |
41
Rep 1,257
P.S. It's coincidence that I reply to some of your posts. |
02-27-2014, 11:59 AM | #18 | |
Rep 2,301
I've seen others too, at relevtively high mileage that were fine too. There are a ton of variables that would effect carbon build up, but most people on here are conviced that the intake valves must be absolutely caked up by a certain mileage.
'07 335I w/ Mods
02-27-2014, 12:02 PM | #19 | |
Rep 2,301
'07 335I w/ Mods
02-27-2014, 12:05 PM | #20 |
Rep 2,301
Jeff, I respect your opinion, but I don't care about 10-15hp at peak, here and there. I measure my vehicles performance by lap times, which have been consistent, thus I've never dyno'ed, and most likely never will.
'07 335I w/ Mods
02-27-2014, 12:07 PM | #21 |
Rep 2,301
A good 60+% of BMW owners follow the stealership maintenance schedules, which last time I was at the stealership, they go at least 12K miles between oil changes. That and their other laps practices Can show a difference in carbon build up between vehicles.
'07 335I w/ Mods
02-27-2014, 12:07 PM | #22 | |
41
Rep 1,257
