BMW dealer says change oil every 15k miles!?
02-27-2014, 03:41 PM | #1 |
116
Rep 380
Just got my first bmw 2 days ago, a 2011 328i coupe 6mt and I plan to change the oil, yet my dealer said it's "only" been 10k miles since the last change. Now I'm sketched out because I'm used to changing oil every 3-4k miles! Is 15k miles really normal, or even good for these bmw's? I'm new to BMW's, just trying to learn...lol I drive my car pretty hard and can't see the oil lasting that long. :0
02-27-2014, 04:32 PM | #2 |
Rep 3,194
Drives: E92 325i MSport Coupe
if you're intending to keep your car then don't listen to him. 6-7K change interval will do nicely.
E92 pre-LCI 325i - Ohlins R&T; H&R spacers; M3 strut brace; Swift thrust sheets; 3 x chassis braces; diff brace; N53 V-brace; 034 subframe inserts; BMS clutch stop; BMS CDV; RE g/box mounts; Delrin shift bushes; Saikoumichi OCC; Cyba scoops; BMW Perf Exhaust; HEL s/steel brake hoses; M3 rear spoiler; Recaro Sportster CSs; M3 white dash LEDs; LED Angels; LED side repeaters; BMW Perf black grille; CSL reps; SSDD carbon diffuser; Monster Wrap black roof/clear front
02-27-2014, 04:48 PM | #3 |
Rep 1,347
i would feel bad for anything over 3500-4000 miles. THere are studies that proves that the oil can last for over 10k miles but change it anyways.. Depends on the person.
IF you wait too long it can cause a lot of problems down the road. But totally upto you. Engine feels smoother after changes and oil breakdown could happen prematurely. |
02-28-2014, 11:30 AM | #5 |
Rep 922
omg where have you been in the entire car world the past 5 years
most (almost all) new cars don't require oil changes at 3-4k anymore. that's real old school BMW won't change it for you less than 15k, which is recommended by BMW/the manual. We (most on this forum I'd guess) recommend to change it within half that interval or even less. |
02-28-2014, 11:47 AM | #6 |
///M at Heart
90
Rep 1,954
Under warranty, the computer once didn't tell me to change it for 18,500 miles. yeah...
no. I've changed it every 7,500 like clockwork. 110k miles and counting.
| 3-IM | AA Headers | Eurocharged Stage-3 | BMW PI | |
02-28-2014, 12:30 PM | #7 |
Rep 2,770
While it likely will not do any harm to change it early I am a believer in the BMW OCI's now. If you use the proper LL-01 synthetic oil it can go for quite a long time. Plus these cars have an oil condition sensor that will monitor how the oil is wearing and adjust your oil change suggestion accordingly. I recently had a Blackstone oil analysis done on my car during it's 3rd oil change and all was fine with it.
http://www.e90post.com/forums/showthread.php?t=945030 |
02-28-2014, 06:19 PM | #8 |
116
Rep 380
Honestly for the average person who drives their car to work and back, it's probably fine. But I drive the car hard, with a mix of spirited driving, mountain runs, and track days. These consist of extended periods of time where the engine is at high rpm's of which I wouldn't want old/bad oil in the engine.
02-28-2014, 09:04 PM | #9 |
Rep 157
The OBC looks at a lot of things, but I don't think it does an oil analysis in its computation of change interval. I think that the dealer will change oil at one year intervals regardless of mileage/etc, at least that used to be the case, with "free" maintenance. I change at 7500, a conservative choice based on experience, legend, and distrust. The spec oil isn't necessarily the best, it's just spec, and a BMW engine hasn't failed to lube issues while under warranty (E46 M3 rod bearings the exception) since Moby Dick was a minnow. Good synthetic, proper viscosity, changed at reasonable intervals and you'll be fine.
02-28-2014, 11:30 PM | #10 | |
17315
Rep 18,737
02-28-2014, 11:37 PM | #11 | |
17315
Rep 18,737
I've had 3 BMWs well past warranty 256K, 241K, and 160K, and my engines, changing at BMW's CBS extended OCIs, have not failed yet. BTW, whales are not born as minnows, they are mammals, calves to be precise... |
03-01-2014, 09:23 AM | #13 |
17315
Rep 18,737
Well I've looked into my engine through the oil fill hole (top end), oil sensor hole (bottom end), and the VANOS solenoid holes (timing chain), and I've not found a bit of sludge anywhere.
03-01-2014, 09:30 AM | #14 | |
Rep 284
That was a used bought car too. Previous owner went by BMW maintenance schedule, I went by mu schedule at 7500. Spotless engine. |
03-01-2014, 10:05 AM | #15 |
Rep 3,194
03-01-2014, 05:12 PM | #16 | |
17315
Rep 18,737
I'm not trying to sell oil and filters to you, or oil change services. Just reporting facts. |
03-01-2014, 06:02 PM | #17 | |
Rep 2,783
If no codes are being thrown use Chevron Techron fuel injector cleaner (concentrate). It solves rpm fluctuating upon cold start-up. Also, for most BMW problems start off by scanning your car with the Peake Research Tool. It contains the actual BMW codes. If you want to register a newly installed battery for free (just buy a $10 cable) and google/download BMWLogger
03-02-2014, 05:11 AM | #18 |
Rep 58
I have a 2004 325I that i change the oil every 15,000 miles. I bought the car in late 2008 with 70,000 miles.. it now has 166,000 miles..runs great!!! I use mobil 1 0w40 (euro)
03-02-2014, 12:05 PM | #19 |
12:34
57
Rep 606
Curious to what repairs you have needed over the years. I gonna hit 200k in next week or so. Ive been changing my oil every 4k 5k max. Curious if you are still using original vanos solenoids.. all I have had to replace so far is one coil pack the waterpump and my front driveshaft.
03-02-2014, 12:20 PM | #20 |
BMW Enthusiast
119
Rep 280
i was from the 3K oil change era... (yes I'm old). since i got my E38 i do it half intervals from the bmw recommends and I'm at 203K. with no major issues (where is a piece a wood when i need one). so on my E46 same and I'm at 170K, now with my new to me E92 i got last july i already changed it 2x.
03-02-2014, 02:15 PM | #21 | |
17315
Rep 18,737
http://www.e90post.com/forums/showthread.php?t=788317 I've cleaned the VANOS solenoids twice first at 145K (when a trouble code appeared) and again at 200,000 (during my 200K tune up). I've decided a 50,000 mile interval for VANOS solenoid cleaning. This you'll find interesting too: http://www.e90post.com/forums/showthread.php?t=926864 Other than the AC pump dying at 85K, it's been the normal E90 stuff (WP, T-stat, etc.) |
03-02-2014, 03:33 PM | #22 |
Military Enforcer
Rep 93
I do mine close to 10K interval changes (no track days or any hard beating on the engine) and I've had some incredible reports on the used oil. I only changed it at 10K because at that point I'm changing almost every 6-7 months. My OCI tells me 16K though which I'm sure would still be fine.
Anyone changing their oil before 5K is literally just throwing money away.
Alpine White 2008 335i Dinan Stg II
USAF |
