2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Navigation, iDrive, Audio, Video, Bluetooth, Phone, Coding need help with software update.
      02-27-2014, 03:59 PM   #1
Black5
Drives: 2011 535i
Hi, On the BMW site I entered my vin# and downloaded the latest update using my Mac laptop. I then dragged the file into the USB drive.
When I stick the USB drive in the usb slot in my 535i. Idrive update does not see the file. I've tried using two different USB drive but no luck. Anyone know
what I'm doing wrong?
thanks
      02-27-2014, 07:12 PM   #2
pdrf10
A Man of Wisdumb...
pdrf10's Avatar
Drives: 2011 F10 550i M Sport
I vaguely recall a similar issue when updating my telecommunications software last year...
I believe I had to relocate the USB stick from the glovebox to the port in the center console (or vice versa) in order to get my car to recognize and install the update.
Hope this helps.
      02-27-2014, 08:10 PM   #3
MWPos
MWPos's Avatar
Drives: 2013 535i
2013 535i  [0.00]
Another thing to check is the formatting on the USB drive. Please check around to verify, but I think that it has to be FAT32 with default cluster size.
Regards,
MWPos
      02-27-2014, 08:29 PM   #4
Black5
Drives: 2011 535i
[. QUOTE=pdrf10;15519993]I vaguely recall a similar issue when updating my telecommunications software last year...
Hope this helps.[/QUOTE]
Yup I tried both usb slots. I also tried uploading music just to test the ports if they working and they are.
I appreciate the help tho.
      02-27-2014, 08:32 PM   #5
Black5
Drives: 2011 535i
I formatted the drive using my Mac laptop. Maybe I'll try using my Windows computer.
Thanks
      02-27-2014, 10:28 PM   #6
MWPos
MWPos's Avatar
Drives: 2013 535i
2013 535i  [0.00]
I got it! I now remember where I read that the formatting has to be FAT32. I read some instructions for updating the navigation map version and in THAT article the USB formatting was addressed:
"to a Fat32 Formatted...."
Regards,
MWPos
      02-28-2014, 12:40 AM   #7
Black5
Drives: 2011 535i
Oh I just remembered I was able to import mp3 music from that same USB drive so I would think the format now is correct idk
Im still gonna try format it off my windows computer and try again
      04-04-2014, 05:27 AM   #8
hj535i
Drives: 5351 Twin Turbot
Reformat the USB to FAT32 with Windows
I was having the same problem after I formatted the USB with my Mac, it worked fafter formatting it with a Windows PC. Also, make sure to use the glove compartment USB.
      05-05-2014, 03:40 AM   #9
Stifler
Drives: 2011 F10 525 218 HP
It can be done from the USB in the center console but the most important is that the file MUST NOT be in any folder just directly in the USB stick.
Good luck.
      05-05-2014, 10:21 AM   #10
raleedy
Drives: 2016 228i 6-speed
You can use the Mac to format your USB drive in FAT32. You may want to double-check whether the software you are trying to install is intended for your specific car, and has not already been installed. In either case, I believe the iDrive won't load it.
http://www.bmw.com/com/en/owners/nav...gion=&country=
http://www.bmw.com/com/en/owners/con...re_update.html
5post
