2006 E90 Spark Plug Socket Size
03-04-2014, 05:39 AM | #1 |
Rep 401
I'm changing my plugs and one coil this weekend and wanted to confirm that the 12 point thin walled socket isn't needed for an '06.
Can I just use a regular 5/8 socket? |
03-04-2014, 05:07 PM | #3 |
Rep 401
I thought I read somewhere that the N52 doesnt need the 12 point deep socket. But I cant find/remember where.
I plan on changing them this weekend would love to not have to buy anything additional! Can anyone else chime in? |
03-04-2014, 06:41 PM | #4 |
douchebaggo
186
Rep 972
My '06 330i does not need 12pt socket. I used a regular 6pt spark plug socket. But you will need a shorter extension for cylinder #5 because of the strut bar being in the way. I believe I used a 6" but don't quote me on that.
03-04-2014, 08:11 PM | #5 |
Rep 401
Good to know, thanks. I read about the last two being hard to get to, and some people loosening the strut bar to get to them. I have a shorter extension and figured I'd give that a go first, and if I'm still having trouble I'll mess with the strut bar.
03-06-2014, 08:55 AM | #6 |
17315
Rep 18,737
Just remove the strut bar. There is no magic to it.
03-06-2014, 10:59 AM | #7 |
16
Rep 301
You just need a regular 6pt socket. You can get the plug/coil out without removing the brace bar, but it does make it easier to take the bar off - and it's only 2 bolts.
03-06-2014, 12:20 PM | #8 |
Rep 401
Thanks guys. Doing it this weekend, heres to hoping I don't mess anything up!
03-06-2014, 03:48 PM | #9 |
17315
Rep 18,737
So just so you know, the strut bar attaches to the firewall with a E-torx bolt with a head size of E16 or E18. If you don't have that socket, I suggest taking the car to a auto parts store that sells tools and remove the cover (the round cover on the cowling) and ask the store to allow you to test fit the correct E-Torx socket for the bolt. I don't have the socket, but a 9/16 12-point socket works almost as good. You only have to loosen the bolt, not totally remove it; the ends of the strut bars that attach to the firewall are slottted.
03-06-2014, 06:52 PM | #10 | |
Rep 2,202
Retrofits: 322, 609, 6FL, 6NR, 6VC, 2TB..
Upgrades: Bilstein B8 Eibach Spring kit |
03-06-2014, 08:02 PM | #11 |
17315
Rep 18,737
03-07-2014, 12:19 AM | #12 |
Rep 2,202
Thank you sir!
03-07-2014, 12:54 AM | #13 |
Rep 3,854
Drives: 330i, 135i
I did mine last year. Easy process. I did not have to remove strut bar. Cheers!
03-21-2014, 12:44 PM | #18 |
Rep 3,854
Drives: 330i, 135i
03-21-2014, 05:45 PM | #19 |
Rep 401
03-21-2014, 06:36 PM | #20 |
Rep 19
