RIP Water Pump
03-09-2014, 08:54 AM | #1 |
Борис
31
Rep 505
RIP Water Pump
Well, it happened. The dreaded Water Pump gave out on me yesterday.
Was driving in town and all of a sudden heard a very loud whirring noise. Thought it was the truck next to me, until I pulled into a parking lot and realized that it was my radiator fan working on max speed. Checked my codes through the AP, sure enough, I had the Water Pump Speed Deviation and then the Water Pump shut down. Great. I drove home, all highway, low rpm, parked it. This morning I did the water pump status check (ignition on, heat on max, gas pedal to the floor) and i heard the water pump struggling. Cleared the code through the AP (p2e82) and tried again, the code came right back. Is there a better deal out there for the Waterpump + Thermostat combo than on Tischer for $475? Thanks
07 SG 335i GONE!
COBB - Burger Motorsports -Ultimate Racing - Evolution Racewerks - TiAL- AMS In Winter Mode - Dunlop Wintersport 3D/Sport Edition Wheels |
03-09-2014, 12:53 PM | #2 |
Rep 294
ebay seems to have the OEM (pierburg) water pump for about 330 shipped. I'm not sure what the OEM thermostat is, so still searching, but that can be had for around 60 shipped on ebay too. So that's about 400.
03-10-2014, 08:24 AM | #3 |
Rep 1,010
I am in the same boat as you my friend.. car is being towed today by AAA
2008 335xi Jet Black//Coral Red VTT Stage 1+// Procede V5//VRSF DPs//AMS FMIC//KW V1//M3 Sways & Sub Bushings// Alpina AT flash Apex EC-7//Michelin PSS//Dinan CAI |
03-10-2014, 02:57 PM | #4 |
Борис
31
Rep 505
Ended up picking up the Water Pump + Thermostat from Tischer BMW for $475. No frills, comes with the hardware, its what I need.
now onto this dismal DIY...
07 SG 335i GONE!
03-10-2014, 03:47 PM | #5 |
Rep 294
03-11-2014, 02:11 PM | #6 |
Rep 665
The Pierburg pump is for the N52. The latest N54 pump is made by Continental.
2010 535i M Sport - Platinum Gray/Dakota Black/Anthracite Bamboo
2016 Jaguar F-Type S AWD - Polar White/Cirrus |
03-11-2014, 02:15 PM | #7 |
7478
Rep 10,120
My died 2 Saturdays ago at 30k miles. I was lucky though because I caught it before it drew its last breath. That day I noticed that the radiator fan would run at full speed right after starting the car. I then checked for codes and there was one stating that the water pump could not activate. I still have warranty so I had the dealer replace it that Monday.
03-11-2014, 02:33 PM | #8 | |
Rep 665
One word of warning since I found out the hard way. Disconnect the battery. I was surprised to discover that the waterpump connector is live even when they key isn't in. I shorted it out accidently with a screwdriver while trying to move the connector into place. After getting everything back together I found the DME wouldn't talk to the water pump even though all four pins to the connector had the proper voltages (12v between pins 1 & 4, 7.8v between pins 2 & 4) and the 30A water pump fuse was fine. I ended up flatbedding the car to my local indy after spending hours searching for the problem. It turns out the short blew a 50A fuse in one of the DME circuits and that little mistake set me back $240, cutting the savings I made by doing the work myself in half.
03-11-2014, 04:01 PM | #9 |
Rep 294
03-11-2014, 08:43 PM | #10 | |
17315
Rep 18,737
03-12-2014, 05:05 AM | #11 |
Rep 665
I believe both Wahler and Behr make the OEM tstat, both of which map to the same BMW part number.
03-12-2014, 05:19 AM | #12 |
Rep 665
I looked it up and you're correct, BMW says not to put "antiseize agent" on the quick connect o-rings. I guess the BavAuto DIY is wrong in that regard unless o-ring silcone grease lubricant isn't what BMW is referring to when they mention "antiseize agent". It's probably better to be safe and either don't lubricate the o-ring at all or use a little coolant if it's difficult to get the connector on.
03-12-2014, 05:25 AM | #13 | |
17315
Rep 18,737
03-12-2014, 06:58 AM | #14 |
Rep 665
03-12-2014, 05:06 PM | #15 |
19
Rep 379
It is not that bad, just take your time. I did it in 3 hours and I am not a great mechanic.
********** 2008 BMW 335i TT******
03-15-2014, 05:40 PM | #16 |
Борис
31
Rep 505
OK, I am running into an issue here and its really making me angry.
The hard black connector that has a retaining clip on it (which i took off) is stuck to the thermostat. I have tried EVERYTHING, to get it off. Any tips? Its basically the only thing that is holding me up right now...
07 SG 335i GONE!
03-16-2014, 06:40 AM | #17 |
Rep 665
Hopefully you managed to remove it last night, but if not, remove the retaining clip completely and then rock the connector side to side while gently prying with a large flat-bladed screwdriver. It will help if you keep the thermostat bolted to the waterpump. If that still doesn't work, try a little penetrating oil -- just make sure you clean out the connector completely afterwards, including around the o-ring.
03-16-2014, 01:38 PM | #18 | |
Борис
31
Rep 505
07 SG 335i GONE!
03-16-2014, 01:59 PM | #19 |
Борис
31
Rep 505
OK JUST GOT IT OFF.
FYI, What a piece of shit.
07 SG 335i GONE!
03-16-2014, 03:02 PM | #20 |
Борис
31
Rep 505
Little did i know there was one on the thermostat too.
jesus.. i just dont see why they couldnt have just done all rubber connections. these "quick" connects are hardly what their named for....
07 SG 335i GONE!
03-17-2014, 02:17 AM | #21 |
Rep 53
The BMW Part Store has what seems to be the cheapest price for oem. $357 for pump, $83 for thermostat and $1.02 for the new bolts... total with shipping is $448.01
http://www.thebmwpartstore.com/oempa...602123%20.html |
03-17-2014, 10:39 AM | #22 | |
421
Rep 1,643
2007 E92 335i MT
Tags |
water pump |
