BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Tracking, Autocrossing, Dragstrip, Driving Techniques > Dragstrip Launch Technique
      11-14-2007, 10:57 PM   #1
Tuned335i
Drives: E92 335i
Everyone knows that launching on the strip is different than the street. My question for those of you with several 1/4 mile passes under your belt and the Steptronic tranny is, what have you found works best? I've watched the MaxBoost video and his 12.56 @ 108.x which seems to be a wet burnout and powerbraking just before launch. Of course he was running BFG drag radials...
So what have you guys been successful with?
Just roll up to the lights and launch?
Dry burnout?
Back up into the water to get the tires a little wet and do a burnout?
What's your procedure?
Torque - The One You Love...
      11-14-2007, 11:00 PM   #2
A418t81
294
Drives: Ever changing fleet
2013 335is  [0.00]
Obviously very different technique 6MT vs. auto, the auto of which I assume you are asking about?
23 iX M60, 24 GT3 RS Weissach, 22 Rivian R1T, 23 RS3, 13 E92 M3 Competition: Akra Evo, KW V3, etc
      11-14-2007, 11:13 PM   #3
Tuned335i
Drives: E92 335i
Crap, yeah sorry, I meant auto. I'll edit the original post. Thanks for catching that!
      11-14-2007, 11:19 PM   #4
///AFRO
Stage 1 Juice Box - Boosted'
///AFRO's Avatar
Armenia
180
Drives: 07 AW E92-335i TT
Dry burnout?
I think the Launch Control method is the safest one.
2007 335i -Coupe Alpine White
Mods: JB1 | Exposed Intercooler | Black Grills/Emblems | Golf-Tee Mod | Reflectors | 35% Tints
Next: Aero-Lip | H&R Race Srings | Dual Cone Intake | Straight-Pipes
Soon: 2006 ///M3 Coupe Imola Red - [CSL Project]
      11-15-2007, 07:09 AM   #5
RedGT3
RedGT3's Avatar
Drives: .2 GT3/M3cs
This is what you have to do.
1. Put the car on DS (make sure you are in first gear with paddles)
2. Avoid the water box (not really helpfull with RFT)
3. Brake hold the RPM's 1100-1200 (try different RPMs see what works best)
3. When you see the green let go the brake (followed by Gas)
4. Hold the gas pedal to the metal (let the car do the shifting)
5. Enjoy the ride.( get you time slip and let us know)
Hope this helps.
      11-15-2007, 11:19 AM   #6
DrewKo
DrewKo's Avatar
44
Drives: 335i Montego Blue Saddle Brown
2007 335i  [0.00]
my 60' posted at dragtimes.com was 1.868 on stock wheels and run flat tires-- i drove straight thru the water patch and stopped; turned off all computer interference (press and hold dtc button for 5 secs); burned out from there until just beyond the starting line; backed up so i would start where i just heated the track (that is one purpose of burning out stock tires); set gearing to 1st; brake boosted to btw. 1500-2200 rpm (can't recall precisely); then punched it on go with just a little feathering to avoid total 1st gear wheel spin, letting computer shift.
      11-15-2007, 12:14 PM   #7
5soko
5soko's Avatar
333
Drives: M5
put it in first via paddles, take all traction control off, and brak tq to 2k. this is my best launch tech.
      11-15-2007, 12:57 PM   #8
tizzletom
tizzlebag
Drives: 2017 M2
Hope this helps.
Great instructions!
2017 AW M2
2016 X5
2011 528i
      11-15-2007, 01:01 PM   #9
livnlegacy
Original Member
livnlegacy's Avatar
Drives: Alpine E36 M3, 02 325iT
o7 E90 335i  [0.00]
if you put it in first with the paddles, how then do you "let the comp shift" (since it's now in manual mode) without taking shifter out of DS and back into DS? will it shift for you at redline in manual mode?
      11-15-2007, 01:48 PM   #10
5soko
5soko's Avatar
333
Drives: M5
yes it will. but i like to shift before redline to stay on boost and powerband
      11-15-2007, 02:49 PM   #11
DrewKo
DrewKo's Avatar
44
2007 335i  [0.00]
In the auto, redline is where you want to shift in the first few gears...
      11-15-2007, 04:06 PM   #12
Tuned335i
Drives: E92 335i
Hope this helps.
Nice write up, thanks.
I am running non-runflat Michelin PS2s, P265-30R19 in the back. Any change to #2 above with non-runflats?
Also, do you hit the DSC/STC once like has been posted elsewhere?
I'll post the timeslip scans late Friday night 11/30.
Thanks again!
