e90 cooling issues
03-13-2014, 04:36 PM | #1 |
Rep 1
e90 cooling issues
Hey gang,
So I replaced my water pump and thermostat after getting the yellow warning light since my 07 has 77k miles. However, I have had low coolant warnings days later topping off with 50/50 solution followed by the bleeding procedure. So it appears the coolant is boiling out. Radiator fan appears to kick in around 105-108C. Could my new water pump be faulty or perhaps the radiator fan is faulty and turning on too late? Any help appreciated. |
03-13-2014, 06:20 PM | #2 |
Rep 89
You should be able to test the thermostat yourself- put it in a pan of water, heat up, watch it as it approaches about 175F (or whatever the stat spec is for your car- Im not 100% sure its 175), use a good glass alcohol/mercury thermometer, and it should open up at around 180-190 deg F. 105C sounds way to hot.
