Help !! Key fob doesn't open/close doors.
03-20-2014, 05:20 PM | #1 |
260
Rep 2,042
Okay so key fob doesn't lock/open doors.Dash button locks and unlocks doors.I Checked all fuses mainly #56 and #57, and #30 not blown.Also 2,5, 19.
Any advise is appreciated. Thanks! |
03-20-2014, 06:44 PM | #2 |
Enthusiast
45
Rep 278
maybe a stupid suggestion but it could be the battery.
Mine has comfort access so the battery is replaceable and not charged when it's in the car, I read somewhere that without comfort access the car actually charges the key fob battery. |
03-20-2014, 08:21 PM | #3 |
260
Rep 2,042
I dnt think is battery cause i had problem with cigarette lighter and shift knob light and the fuses were blown.
03-20-2014, 09:03 PM | #4 |
President
38
Rep 127
I think he meant the battery in the key fob , with comfort acess you can actually change the battery on your key fob but if you don't have comfort acess like me, then the battery in your key fob charges as the car is started( I think ) lol . So I think he meant the battery in your key fob
03-20-2014, 09:05 PM | #5 | |
Enthusiast
45
Rep 278
03-20-2014, 09:08 PM | #6 |
Bayerische Motoren Werke
23
Rep 251
Drives: recklessly
If you have comfort access (you can unlock/lock by touching the door handle), then look at the back of your fob. There should be a battery door. Pry it open with your finger nail (the plastic is soft; don't use any metal tools) and take the battery to Target and buy a replacement in the camera department.
03-21-2014, 01:46 PM | #7 |
260
Rep 2,042
Now I have bigger problem. When i checked OBD fuses yesterday everything was fine till todays morning. I couldn't start engine. After that shows my no abs, traction, brake, air bags off. Should I clear errors with computer ??
03-21-2014, 02:26 PM | #8 |
Rep 9
Drives: Montego Blue 335i AT
You may have multiple issues. Where are you located in Jersey? I may be able to help if you need a car battery or troubleshooting. Sounds like your car battery may not have enough voltage. Do you have a volt meter? Check the voltage on the car battery.
Meth, JB4 G4, and DCI's
03-21-2014, 05:41 PM | #9 |
260
Rep 2,042
[QUOTE=robertsawh82;15644011]You may have multiple issues. Where are you located in Jersey? I may be able to help if you need a car battery or troubleshooting. Sounds like your car battery may not have enough voltage. Do you have a volt meter? Check the voltage on the car battery.[/QUOTE
I'm in Clifton. Tomorrow I'll check battery and codes, then I should know some more. ;/ |
