2Addicts
2Addicts
2Addicts | BMW 2-Series forum Technical Topics Cosmetic and Lighting Modifications IND Painted Reflector Installation Procedure
      04-07-2014, 03:03 PM   #1
Ryan@IND
Ryan@IND's Avatar
Drives: ACR
Painted reflectors are among the first additions made by any owner of a modern BMW. The unsightly orange reflectors installed in cars bound for North America instantly break the smooth lines of BMW bumpers.
IND provides painted reflectors as a cost effective solution. We use OE BMW reflectors for a factory fit, and the same paint process we would use to repaint an entire car. Each reflector is sanded, prepped for paint, primed, then painted.
Many enthusiasts enjoy installing their own painted reflectors, so we’ve created this installation DIY to help.
Tools needed:
• 8mm socket and ratchet
Step 1:
The first step is to gain access to the fender liner. This can be achieved by turning the wheel full lock toward the inside of the side you are working on. As a result of this action you have a clear view of the fender liner as well as the fasteners
Step 2:
Now that the fender liner is visible take the socket and remove 3-4 of the fasters so that you can safely access the reflector.
Step 3:
The F22 reflectors are not secured with double-sided tape, but rather snapped into place. There are two tabs on the backside of the reflector and the safest way to remove the factory piece is to depress the tab inward and simultaneously push the reflector. Once you have one end loosened you can repeat with the other tab.
Step 4:
Installation is as simple as push the reflectors into place. This is performed from the outside of the bumper
Step 5:
Now that your reflectors are installed it is time to button everything up. Simply replace the fasteners on the fender liner and repeat with the other side.
IND DISTRIBUTION | 866-963-4520 • INSTAGRAMFACEBOOKFLICKR
Appreciate 4
Joe2402923.50
      04-07-2014, 05:08 PM   #2
GOLFFRR
GOLFFRR's Avatar
10810
Drives: GOLFFRR cart
BEFORE YOU BUY YOUR NEXT BMW, EMAIL OUR GUY KOTE FIRST!
Kote M Sales:Kotem@bmwofcamarillo.com Cell:805-368-9101
vipfinance@bmwofcamarillo.com for warranties!
      04-07-2014, 05:20 PM   #3
h0pe
Drives: M235i
looks super easy
      04-08-2014, 12:29 PM   #4
G8r3Series
G8r3Series's Avatar
16
Drives: ///M3
How about removing the rear reflectors? Will you have an installation procedure posted for that as well?
      05-07-2014, 09:57 PM   #5
Pray for Mojo
430
Drives: 2014 M235i & 2018 X3 M40i
Originally Posted by h0pe View Post
looks super easy
It's not easy if you have the parking sensor there. I just tried to do it but it's difficult to pop the bottom tabs out. I'm going to remove the wheel and the fender liner completely to get proper access.
      05-12-2014, 10:41 PM   #6
pikcachu
pikcachu's Avatar
1399
Drives: M235i (F22 Red angel)
bottom clip is kind of a PITA but once you have the top out...you can yank it out
      05-14-2014, 09:02 PM   #7
MUFCbmwbear
MUFCbmwbear's Avatar
Drives: 24 M2 & 20 M340xi
IND installed Glacier Silver
20 M340xi White Mocha
17 340i/M235i/E92 M3/135i All 6spd
Chicago-Lake County-Milwaukee-Shorewood
      05-16-2014, 08:30 PM   #8
eatsmeetswes
Drives: 228i
Before and after! Total install was less than 10 minutes!
      06-24-2014, 12:51 PM   #9
Mantii
Mantii's Avatar
Drives: F80 M3/E46 M3
I tried doing this myself yesterday. I can get to the top clip and may be able to get it to release with some force. But there is no way I can get to the bottom clip and to let it go. I'm afraid to pull on it and have it break the plastic that is actually holding the reflectors.
      06-24-2014, 01:59 PM   #10
BEM-S4
BEM-S4's Avatar
Drives: Dinan M235, Dinan Sport Wagon
Just pull the tab on the front as far rearward as possible and pull down on the loose top. It will sort of wedge its way out. The bumper is rather flexible it will stretch. That worked for me anyway if you screw yours up I'm taking no blame
Worst case I was going to epoxy mine in bc you can't see what's behind it but it worked fine.
2022 Macan S
2016 F31 328i xDrive Sport Wagon
2006 E46 330ci ZHP Convertible
      06-24-2014, 02:18 PM   #11
ska///235i
***** noob
ska///235i's Avatar
Drives: 325xi>M235i>428GCx Mspor
2006 325xi  [0.00]
Yea ones the top is off, you use the top as a handle and pull the bottom off
Dont just yack it out but slowly pull it out
2006 325xi (Sold)
2014 M235I (Current)
2015 428xi Gran Coupe (STB)
      06-24-2014, 02:31 PM   #12
BEM-S4
BEM-S4's Avatar
Yeah that's a better way of saying it. Assuming you are on the passenger side, with the top out use left hand to pull the foremost tab on the bottom as far rearward as possible, then pull the top down with your right hand while rotating longitudinally towards the rear to wedge the depressed front tab out first. If that makes any sense at all. It's a little panic inducing but overall not that bad.
      06-24-2014, 02:43 PM   #13
ska///235i
***** noob
ska///235i's Avatar
2006 325xi  [0.00]
Oh and for the top, if you can get your hands behind the bumper...use a mini plier to release the clip
2006 325xi (Sold)
      06-27-2014, 07:40 AM   #14
five3three
Drives: m2c
Has anyone who has the parking sensors done this? The parking sensor sits right next to the reflector where you are supposed to reach in from the wheel well. I ordered a set of the IND's but have yet to attempt.
      06-27-2014, 10:18 AM   #15
pikcachu
pikcachu's Avatar
1399
I did it and had no issues
      06-27-2014, 08:58 PM   #16
five3three
Drives: m2c
Thanks. I just did mine as well and it was straight forward.
Thanks to IND for a great color matched part! (MG for me)
Name:  2014-06-27 22.41.54.jpg
      07-06-2014, 09:03 PM   #17
asn
Drives: Current S2000 & MDX Future X6
Dumb question - Do the reflectors still reflect if you paint them, or tint them?
      07-06-2014, 09:05 PM   #18
BEM-S4
BEM-S4's Avatar
Attachment 1050445
Looks good just need to lose the orange bulb now... Then we'll be twins.
2022 Macan S
      07-06-2014, 10:01 PM   #19
pikcachu
pikcachu's Avatar
1399
If you paint them they won't reflect anything i will just look like the bumper...
If you tint them it depends if the film is reflective or not but most likely won't reflect at all
      07-08-2014, 08:54 AM   #20
bimmerbuff
Slightly Less Obsessed
bimmerbuff's Avatar
Drives: Between BMWs
This is probably a dumb question, but was there a law that mandated these reflectors be installed?
I was looking around yesterday at other cars and see more rear reflectors than front ones, but there doesn't seem to be any rhyme or reason as to which cars have front reflectors.
      07-08-2014, 09:33 AM   #21
BEM-S4
BEM-S4's Avatar
A lot of cars have them buried within the headlamp assembly. For those looking to remove we're very lucky that's not the case for ours.
2022 Macan S
      07-08-2014, 05:54 PM   #22
asn
So, without knowing the laws, it would probably be safest to install clear or smoked reflectors in the front and back, assuming I can find them.
2addicts
