04-13-2014, 12:14 PM | #1 |
BooGooBird
17
Rep 79
Navigation map keeps rebooting
Hi guys, i have a 2012 F30 CIC with NA premium 2014-2 map updated version. Recently experiencing some problems with navigation, here is the story: everything was fine after updated map, with no problem on routing and rerouting. After coding bmw online and updated service, (not sure this is the reason cause navi problem or not) the navigation works fine when not routing, however, the map will frozen when destination set, both frozen on CIC and HUD, only the map and direction on HUD will frozen, you can still zoom in and out, or you can option right, and check last destination left, but nothing will change the map, and anything else is fine. after a while the CIC will reboots itself and will ask you resuming or stop routing, when resuming, it will repeat the loop where cic keeps rebooting; when stop routing, the map will show the position where the map was frozen instead of current position(because i am driving and testing the map), and it will be back to current position after while. Tried reverse bmw online coding, and seems not working. Does anybody had the same or simular issue?
Thanks |
04-13-2014, 12:50 PM | #2 | |
Rep 90
2014 BMW 335i XDrive M Performance Edition
2011 BMW 335i M Sport 2008 BMW 335i 2007 VW GTi 2000 Audi S4 |
04-13-2014, 03:00 PM | #3 | |
288
Rep 1,892
Did the 2014-2 maps ever work for you? I have not updated to that version yet, so I can't verify that they work properly. If VO coding your HU_CIC doesn't help, you might try reverting to the 2014-1 maps to see if that clears the issue. I also replied to your post on the coding thread. |
04-13-2014, 04:42 PM | #4 | |
BooGooBird
17
Rep 79
I saw your post i will give it a try this afternoon. Hope it will clear the problem. I lost my coding note so i wasnt sure if i coded that juction view or not. And i remember there is another code called bmap_juction_view? Could you please check yours if this is default by aktv or nich_aktv? And 2014-2 is working on my 2012 f30, it was working perfect until i coded something, so i pretty sure this has nothing to do with map version. I will see if turn off the juction view will clear the error. Pleas let me know your bmpa_juction_view is currently on aktv or nich_aktv Thanks much man |
04-13-2014, 04:53 PM | #5 | |
BooGooBird
17
Rep 79
I can only sync my messages from phone but not email. I have the most current version of bmw spftware i beileve it is file 1006. Do you think i have to do something on my phone? |
04-13-2014, 05:06 PM | #6 | |
288
Rep 1,892
04-13-2014, 05:14 PM | #7 | |
288
Rep 1,892
There's a good thread in the UK forum that talks about techniques to get it working. http://www.f30post.com/forums/showthread.php?t=895090 and this one too: http://www.f30post.com/forums/showthread.php?t=968891 The basic problem seems to be that IOS won't push notifications via BT unless they are marked as priority messages. SMS seems to be set this way automatically, but not e-mail. By closing the Mail app and/or changing the notification count in IOS for messages, IOS will then mark e-mail notifications as priority (feature or bug?) and the car will see them. |
