Style 95 Wheel owners step in
04-14-2014, 04:33 PM | #1 |
217
Rep 1,909
So I got the fenders rolled and 225/ 255 Michelin PSSs mounted ... Car has gained a lot of handling but I'm concerned
1- Suspension is now LESS stiffer from stock ? Did u guys notice this ? 2- I can take turns at much higher speeds than stock but seems like a little bit of turbo lag is kicking in ... Car is completely stock 3- Rears are .02% different & front 0.56% from stock - It cant get any darn closer than this, are they heavier ? they seem the same weight as stock sport Last edited by 007_e350; 04-15-2014 at 09:37 AM.. |
04-15-2014, 09:46 AM | #3 |
Rep 1,093
Not familiar with the wheels. Did you get an alignment? Are you using camber plates?
07 335XI (A008006) 6AT ~94K miles JB4 G5 ISO VSRF DP's
09 135I M (VK80379) 6MT. Race Project car. 1) Install Cobb/piggyback? and Motiv 600 Kit[HTA3076R w/ tial .82] 2) JRZ or Moton suspension. 3) Build high flow intake manifold with multi-port fuel and relocate OFH 4) Build full cage 5) Complete staged twin setup with HTA4205R [w/Tial 1.16] 6) Complete dry sump system |
04-15-2014, 10:03 AM | #4 |
217
Rep 1,909
04-15-2014, 10:29 AM | #5 |
Rep 1,093
If you think alignment is good because the car doesn't pull. You have some shit to learn. Trying to help you out. Toe has a huge effect on handling. Good luck with solving your issue.
04-15-2014, 12:06 PM | #6 |
Rep 1,037
When you say the suspension is "less stiffer than stock" do you mean the car rides smoother? As in less bumpy? If you didn't change your suspension then there is no way your suspension is "less stiffer". But ditching the stock runflat tires will almost always make the car ride smoother if that's what you're feeling. Hope that helps.
04-15-2014, 12:35 PM | #7 |
BimmerPost Supporting Vendor
1334
Rep 1,701
Drives: Slot Machines.. Keep Taking $
Look stretched... sick bro. very cool. Need more pics.
04-15-2014, 05:32 PM | #8 | |
217
Rep 1,909
it could be PSS ride quality thats making it 'softer', the track width is considerably wider form stock (ET 24), ill try to take more pics |
04-15-2014, 05:33 PM | #9 |
217
Rep 1,909
04-15-2014, 05:45 PM | #10 |
3441
Rep 79,211
How about the obvious question, tire pressure? I would have done at least 245 out front and 265 out back. (Then again IDK the 7 series rim offset so perhaps that why you went conservative).
04-15-2014, 05:57 PM | #11 |
Rep 627
You can do 265's rear easy, not sure about the 245's front tho. I get minor rubbing with 235 fronts on e92. About the weight, style 95's are actually pretty heavy, over 30lbs ea I believe.
_
04-16-2014, 12:37 PM | #12 | |
Rep 980
Drives: '08 BSM 335i e92
Style 162 front weigh 29.7lbs each so that's 59.4 for both Style 162 rears weigh 30.4lbs each, so that's 60.8 for both. Total weight of all 4 style 162s is 120.2lbs Now lets look at style 95s Fronts weigh 32.6lbs each (65.2lbs for both) a total of 5.8lbs extra Rears weigh 36.2lbs each (72.4lbs for both) a total of 11.6lbs extra So total weight of all 4 style 95s is 137.6lbs (total of 17.4lbs extra So, they are significantly heavier.... and that's just the wheels. You also upgraded from an 18" tire to a 19" tire, wider widths as well. So there will be even MORE added weight in the tires. But let's just stick to the wheels for now. 17.4lbs is unsprung weight. A good rule of thumb to calculate unsprung weight is to say that 1lb of unsprung weight is approximately equivalent to 10lbs of weight in your trunk.... so just based off of WHEELS alone, you basically added 174lbs in your trunk. So it's like you're carrying around another person with you, just in the weight of the wheels alone. Let's round that up to 200 lbs with tires. So wheels and tires you're looking at probably the equivalent of 200 pounds extra weight. Well over 30lbs, actually closer to pushing 40 in the rears, and that's JUST for the wheels.
'08 BSM E92 335i 6MT/MHD stg 2+/VRSF 7" FMIC/VRSF CP/HKS BOV/VRSF catless DPs/BMS DCI/muffler delete/BC Extreme lows/OEM style 167s/BMS high side OCC/Mishimoto low side OCC/etc
04-16-2014, 02:27 PM | #14 | |
217
Rep 1,909
06-16-2014, 10:16 AM | #15 |
17
Rep 48
I just bought some style 95's and didn't even think about how much heavier they would be. This is great information and definitely something to consider.
