12-23-2014, 10:31 AM | #2 | |
Rep 111
Does anyone have any idea on this? I'm curious as well as i noticed the other day behind a friend's car's reflection that switching to high beams to not turn the other interior unit on, only the outer unit. |
12-23-2014, 11:01 AM | #3 |
Rep 6,936
Drives: 2018 M2 AW DCT
The inner unit is only used as a day time running light. High and low beam both come from the outer unit. BMWs have been that way for several years.
12-23-2014, 12:34 PM | #4 |
12
Rep 304
Drives: M235i Alpine White
No daytime running lights are the Angel eyes
12-23-2014, 12:45 PM | #5 |
Rep 2,361
12-27-2014, 03:24 AM | #7 |
Rep 138
the inner two projectors defiantly dont turn on for anything on my car. Im wondering is there anything at all behind those lens ? is it actually a projector or just a dummy lens
12-27-2014, 04:35 AM | #8 |
European Editor
10539
Rep 22,992
It could be like on the e82's.... The inner headlight lamp will light up when the headlight switch is in AUTO position and...
* you turn the steering wheel(in that direction of that light)... * you put the car in reverse BOTH inner lamps will light up * DRL (IF you have setup the system in the BC) for more helpful videos check out BMW NA's site of videos... http://www.bmwusa.com/Standard/Conte...modelcode=1022 .
12-27-2014, 04:51 AM | #9 | |
Rep 138
Does not turn on in reverse The DRL is the corona rings But this is just for a NA Spec car, wonder if its different for different markets |
12-27-2014, 05:02 AM | #10 |
European Editor
10539
Rep 22,992
Your headlight switch is in AUTO right> ? It makes a difference.
12-31-2014, 08:49 PM | #12 |
Little Deuce Coupe
391
Rep 635
Drives: SO M2C
I'm in the process of ordering, so while reviewing the brochure I ran across this description of what they should do.
01-01-2015, 03:14 AM | #13 | |
Rep 138
01-01-2015, 12:16 PM | #14 | |
Rep 5,262
looks like it comes disabled on the 2... Cornering wizard FEM_BODY 3110 ASP_ABA_AKTIVIERUNG aktiv Activate cornering assistant might do some coding and give it a try see if the light comes on with the blinker |
01-01-2015, 01:55 PM | #15 |
Moderator
29376
Rep 13,097
For the record: the difference between Adaptive Headlights and Cornering Lights:
"Adaptive Headlights The Adaptive Headlights cast their beam in the direction of the curve and ensure better visibility and more safety during night drives on winding roads. Sensors measure speed, steering angle and yaw (degree of rotation around the vertical axis). Based on this information, small electric motors turn the headlights left or right so the beam falls on the road ahead, guiding you into the bend. Headlight beam throw control (a model-specific function) means the front headlights are raised at high speeds and lowered at slower speeds, which results in a wider beam for inner-city driving. The adaptive headlight range control (a model-specific function) takes into consideration the vertical curve of the road. The headlight beam throw control is lowered when driving over a knoll and raised when the vehicle is in a dip. The result: every single curve is illuminated and the oncoming traffic isn’t dazzled unnecessarily. Driving at night is even safer, particularly when visibility is poor. Adaptive Headlights are only active when the vehicle is pulling away. They stay switched off when the BMW is in reverse and when the steering wheel is turned to the left while the vehicle is stationary (e.g. when pulling out of a parallel parking space to avoid dazzling oncoming traffic). Adaptive Headlights are complemented by cornering lights. These are automatically activated at speeds of up to 70 km/h and improve visibility in the immediate vicinity of the vehicle, which is useful when driving along hairpin bends, turning or parking." (http://www.bmw.com/com/en/insights/t...eadlights.html) "Cornering lights Cornering lights provide additional illumination of the area to the side of the vehicle, making night-time parking and turning safer. Cornering lights compliment the functionality of Adaptive Headlights. While Adaptive Headlights provide superior illumination of curves when driving at normal speeds, cornering lights give you better lighting when carrying out low-speed manoeuvres: parking, turning into a driveway, u-turns and taking extremely winding roads, for example. To provide this additional light, the fog lamps are fitted with integrated swivelling reflectors; alternatively, the headlights are equipped with an additional lamp. When the indicator is activated at speeds below 40 km/h, these lights illuminate an area to the side of the vehicle, up to 80° of the direction of travel. After the corner is taken, the cornering lights dim and extinguish automatically. Cornering lights also facilitate safe reversing: when reverse gear is selected, both the left and right lights illuminate the area around the vehicle." (http://www.bmw.com/com/en/insights/t...ng_lights.html)
///M is art ↔ Artemis
01-01-2015, 02:12 PM | #16 |
Moderator
29376
Rep 13,097
The lens inside the inner corona of the M235i picture shown by OP (first post) seems to be different.
Here's the headlight cluster of my 1M (featuring Adaptive Headlights and cornering lights).
01-01-2015, 06:42 PM | #17 | ||
Rep 138
01-02-2015, 10:46 PM | #19 | |
Rep 111
01-02-2015, 11:07 PM | #20 |
Rep 138
I think the heat sinks might be for the LED's in the corona rings, just guessing though. Havent seen a HID light that needs external heatsinks
01-03-2015, 05:38 AM | #21 | ||
European Editor
10539
Rep 22,992
http://www.realoem.com/bmw/showparts...=63&fg=05&hl=4
01-03-2015, 05:51 AM | #22 | |
Rep 138
