Turbo Tuner Chip
12-02-2007, 03:01 PM | #1 |
Rep 104
Turbo Tuner Chip
Anybody looking for the Turbo Tuner Chip? Used for 12000 kms works great and makes the 335i explode into life. I imported this from the States back in April and have tested it since, increased my HP from 306 to over 346(have the dyno to prove it).
Let me know if interested. Will |
12-03-2007, 05:58 AM | #2 | |
Rep 806
Let me see your grillz!!!
12-03-2007, 06:04 AM | #3 |
Rep 104
Just gonna go stock for a while, thinking about the procede.
Also the wife is complaining that I am driving too fast when I accelerate full throttle - women :-( Will Last edited by will335iad; 12-03-2007 at 05:10 PM.. |
12-04-2007, 01:44 AM | #5 |
Rep 104
The chip basically increases the turbo boost and changes the computer management system resulting in higher horsepower and torque figures increasing the performance of the engine, I blew 3 e39 M5's away with the chip one my own and two others which you can see here
and the other one here Here is more details about this incredible little widget The Turbo Tuner is a plug-and-play solution that significantly enhances performance. Typical gains are 40 horsepower and 50 ft-lbs of torque. It is designed to be an easy-to-use solution that end users can install themselves. The Turbo Tuner can be installed or uninstalled in seconds. It does not cause any trouble codes and its operation does not leave any trace that it was ever there. The Turbo Tuner is not an ECU re-flash solution. It is an embedded control solution that works seamlessly with the stock ECU. The turbo tuner provides real performance gains while it preserves the smooth and refined character of the car. The Turbo Tuner is built using surface mount technology and state-of-the-art, pick-and-place automated assembly equipment for the ultimate in quality assurance and reliability. The design features a soft limit circuit that avoids overboost. This protects the engine from boost spikes and preserves drivability. There is also a temperature compensation protection circuit that lowers boost at elevated under-hood temperatures. Will |
12-04-2007, 12:12 PM | #7 |
Rep 104
12-06-2007, 09:20 AM | #8 | |
Rep 591
12-07-2007, 06:15 AM | #10 |
Rep 104
12-07-2007, 06:16 AM | #11 | |
Rep 104
The best $600 plus shipping I ever spent on a car. Cheers Will |
