F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F34 3-Series GT (Gran Turismo) Forum > Disaster :(
proTUNING Freaks
      06-04-2014, 01:39 PM   #1
eshwarthai
Drives: 3 series gt 320d
Disaster :(
Just found out a rodent has chewed the wiring . Display says headlamp vertical control failure. Fog lamps not working and windscreen and headlamp washers not working. Should i change the whole wiring assembly? anyone know the part number? I will be going to the dealership but any suggestions are welcome
      06-04-2014, 01:44 PM   #2
bmwperson
Drives: 4wheels
BMW makes a crimp connector, they are dsub style folding connectors and you put heat shrink tube over it; they work really well. It's way cheaper and easier to replace.
1997 BMW M3 Single turbo 723whp GT42R
2000 BMW M5 - Daily
2014 BMW 335i xDrive 6spd loaded
      06-04-2014, 01:50 PM   #3
eshwarthai
So i don't need to replace the wiring? I don't really know how the crimp connector works . Care to brief a little more ?
      06-11-2014, 02:21 AM   #4
orangebang
Drives: 328i Xdrive GT
crimp connector usually means it's solderless.
So you strip the wire, and crimp it with a connector.
What I'm imagining is that there's some sort of molex plug somewhere connected to a wire harness. You cut the wires, and just replace the plug, and crimp the connections together, put shrink wrap on it, and there you go. Good as new.
      06-15-2014, 11:46 AM   #5
eshwarthai
Thanks a lot.
      06-15-2014, 02:35 PM   #6
bmwperson
Drives: 4wheels
Yep bmw crimp connectors are solderless, BMW actually recommends the use of them to repair damaged wiring over soldering as the wires can be overheated and cause insulation damage and subsequent possibility of fire.
There is parts of the BMW harness or even sub harnesses that are difficult to replace, main wire loom being one, engine harness its way easier to repair the harness as opposed to removing all the interior/engine accessories. BMW overall doesn't have too many connectors linking the subharnesses and the ones that are there appear to be there to ease assembly. For example the engine harness is treated as part of the engine assembly which is rolled as a complete unit during the assembly and connected to the main loom.
OP This should be a non-issue, your car will be fine I had this happen on my M3 when a branch sitting in the middle of the highway took off Post cat O2 connector and ripped up the harness. It was a 10minute job to repair it.
2000 BMW M5 - Daily
      06-19-2014, 02:17 AM   #7
eshwarthai
The BMW dealership says they don't do repair jobs, they only replace(i have to replace the whole bunch of wires, not just the one's damaged) and he said if i get it done outside i might void the electrical warranty . Let me go speak to them again
Thanks guys. I'm attaching my car picture
      06-19-2014, 02:29 AM   #8
eshwarthai
Imperial Blue 320d GT
      06-19-2014, 04:50 AM   #9
ORIGIN M.
3160
Drives: ///M
I'd move your trash containers as far a way as you can from you car or it will happen again
f30post
