6.1KVIEWS
17REPLIES
5APPRECIATES
14ACTIVE PEOPLE
05-06-2026LAST POST
ChrisP2773 wroteYes you should be fine, as long as you're ok with a more aggressive look. Keep in mind that the fronts are 21" and the rears are 22" in diameter.Thank you for the information. So I should have no problem installing them on my X5? Thanks again, Chris
The only thing I'm not 100% sure about.... are the lugs. They are the same thread pattern, but the seats on the G05 are quite large. I'm not sure what the lug seats look like on an F95. If they are smaller, you may want to pick up an OEM set of lugs from an X5M at your local BMW dealer. I imagine someone can post a pic of X5M lugbolts though. If they look the same as your original ones.... you're good.
Anybody got the part numbers for a full set?
Looking at a used set of these for a summer wheel/tire set up for my wife's X5 40i.
ChrisP2773 wroteYep mine 809m fit perfectly. Been driving these wheels for a year now. 10.5J in the front, 11.5J in the back. I had to put 10mm spacers in the back to get the best fitment I want.Will the X5 (G05) M Competition 809M style wheels fit on a X5 4.0i? I have the 742M wheels currently.
Wukong_1989 wroteThank you!Yep mine 809m fit perfectly. Been driving these wheels for a year now. 10.5J in the front, 11.5J in the back. I had to put 10mm spacers in the back to get the best fitment I want.
bforbrian wroteOld thread but was doing some research and the rear 11.5" wheel has an ET:43 and not 37. Not looking to be a corrector just wanted to make sure correct info was out there.The 809M wheels are 21x10.5 +31 in the front and 22x11.5 +37, which means that compared to the 742M wheels, the fronts and rears will have 7mm less inner clearance, while protruding 19mm. This will work just fine.
Wukong_1989 wroteThose look great! Are they replica wheels are factory originals? Would they have fit ok without the 10mm spacers?Yep mine 809m fit perfectly. Been driving these wheels for a year now. 10.5J in the front, 11.5J in the back. I had to put 10mm spacers in the back to get the best fitment I want.
ChrisP2773 wroteDid you ever install these wheels?Thank you for the information. So I should have no problem installing them on my X5? Thanks again, Chris
