13.3KVIEWS
14REPLIES
14APPRECIATES
11ACTIVE PEOPLE
04-12-2026LAST POST
12-13-2022
Can anyone point me to instructions on how to change these? For the cabin, is it actually 2 filters?
Thx!
12-13-2022
gfeiner97 wrote
See attached. they are for G05 X5.
Thx!
12-13-2022
Happen to have instructions to change out engine air filters for G05 xdrive50i, by chance? I can’t find anything anywhere.😔
Thanks in advance!
12-14-2022
Thanks in advance!
Sorry. I only have stuff for the 40i.
12-14-2022
Have one for transmission pan/filter replacement?
I think it hasn't substantially changed for years but would like to check.
I plan to get a pressure canister this time. Makes it much easier to top off after filling, running engine, going through each gear and topping off again while car is running.
12-14-2022
Thanks in advance!
Should be the same.
If you need the actual BMW instructions, let me know. Pretty much the same but in text.
12-14-2022
weinerbarn wrote
Should be the same.
Thank you so much! I truly appreciate it. Should be a fun project for me. Haha
Cheers!
12-15-2022
See attached. When I saved this, I didn't see anything about a tranny filter. I'm wondering if the filter is integrated into the pan. Also, the instructions lack detail on the refill procedure other than just hooking the vehicle to the computer system to perform the refill.
12-16-2022
The transmission filter is part of the pan.
08-15-2023
Awesome, thank you! This is very helpful for a DYI K&N 33-3079 air filter on my G05 2023 X5 45e
01-15-2024
How do you like the filter? I have always had K&N - for convenience and cost savings, not for performance gain.
07-27-2025
is there a prefered brand? or is it worth getting a carbon activated one?
11-12-2025
Any step by step instructions to do engine filter replacement on V8?
Seems straightforward but you can never be too careful.
Much appreciated in advance.
04-12-2026
2 cabin air filters and 2 engine air filters...
