14.6KVIEWS
17REPLIES
10APPRECIATES
11ACTIVE PEOPLE
09-30-2025LAST POST
06-29-2023
2020 X5 G05 xDrive40i Base brakes no Msport or Third row.
Front rotors from FCP Euro ZIM-150295620 x2 to take advantage of that lifetime warranty
Brake pads, Z23-2060 from Powerstop. FCP didn't have any ceramic options as I wanted ceramic for less dust and more gradual braking.
Sensors, SW-1690 x1 from Powerstop.
1)Jack up both front wheels on floor jacks.
2)Remove the caliper and and brake pads and rotors. I followed this link on YouTube
The OEM pads bmw used were Textar pads as shown in the picture. Do your research in what you want with your brakes, but semi metallic or ceramic are the most popular options for daily driving.
I'd recommend watching some Chris fix videos to learn some of the basics of brake change as well if you never done them.
3)I also used a wire brush to clean the hub after the rotor removal and the inside of the caliper where the four clips sit. I put some anti seize in the clips and anywhere there was metal to metal contact.
4)when replacing the pads back the left and right one are actually different. So align the pins to the two holes and it if it's off it'll be for the other side of the same caliper. Put ceramic brake grease on the ears and on the back of the pads.
5)put back everything in reverse and the metal pin that goes on the top, goes back in the same way it came out.
6)if you are doing the driver's side . Replace the wear sensor.
2 caliper bolts are torqued to 110 Nm
Wheels lug bolts are torqued to 140 Nm
SUPER CRUCIAL STEP
7) After everything is put back and torqued to spec. Go in the car and ENGAGE AND DISENGAGE the parking brake.
ABSOLUTELY DO NOT PRESS THE BRAKE PEDAL.
What I did was I put the car in service mode by pressing the Start button 3 times, then engage the park brake and disengage. Then I pressed and held the brake pedal for 1 minute.
8)Bed in process, I did 30 -- 30mph to 5mph hard stops and then rolled on Drive for 6 minutes without pressing the brakes.
After bed in process, the brake feel in comparison to OEM is much better in my opinion. Yes the initial bite is not as hard as the OEM but it's like 95% there. But because the initial bite is not hard , the stopping is gradual it still bites but the harder you press the faster is stops . Coming to a stop there is absolutely no stutter or grinding sound like oem semi metallic pads. If you ever tried akebonos euro pads, it's very similar but bites a little harder.
I've attached some pictures
Hopefully this helps someone as I haven't seen any posts for the non Msport
06-30-2023
I’ve thought about something when my 2021 stock parts are done. Let’s see some after pics !!
06-30-2023
Picture of after bedding process. Everything looks good so far. Brakes feel great as well.
07-24-2023
Great work on the brakes! How would you say brake dust is compared to OEM?
07-28-2023
Brake dust is very minimal after a few weeks of driving. The rear wheels which are still on OEM pads are building dust quicker than my front pads which do most of the braking.
09-22-2023
What was the part number for the rotor you used? I just attempted the same thing... but two things went wrong. One, I got the 36mm thick rotors that would not fit between the new pads (yes, pistons fully retracted)... so I guess I need the 30mm.
Second, didn't know about the brake reset item with the parking brake. I pressed the brake and everything went crazy. Stabilizer control disabled, brake malfunction, parking brake doesn't work. braking control is all weird.
Also, any idea on how to fix this error mess? Dealership the only way?
09-22-2023
Just saw your note about the rotors at the top... whoops. Do you know if those are 30 or 36mm?
10-30-2023
So I only did the front brakes as my rear brakes were still in good condition. And the part number I listed in the top is the correct part number for the rotors and pads of the regular base brakes (non M-sport).
The issue your describing comes from the rear brakes. When doing the rear brakes, there are specific steps that you need to take before retracting the caliper. I believe the order was park the car, do not engage the parking brake, then go into Bimmerlink (separate purchased app and need connector) then press the service mode to release the magnetic hold. then use a special caliper compressing tool that rotates and pushes back at the same time.
I'm not sure how to fix your issue when it already occurred. Maybe trying to clear the codes with Bimmerlink? but ultimately a run to the dealer if nothing else work.
Did you do all 4 brakes or just the rear?
10-30-2023
I did rear pads about a month ago. All you need to do is this:
1) engage and DISenage parking brake (little light off)
2) turn on service mode (3 clicks of start/stop)
3) use BimmerLink to turn on break service mode. You will hear motors unwind. You might get error message from BimmerLink but that’s ok as long as you heard the noise.
4) change pads like any other car compressing brake piston with any compression tool.
5) then use BimmerLink again to turn off break service mode.
6) engage/disengage parking break
It’s very simple.
Also in BimmerLink you “add” record of pads been serviced.
11-13-2023
Man I wish I saw this post before doing my front break pads smh I have 2019 X5 40i base brakes I saw the you tube video you attached but it ends after he decompress the pistons I had no clue of the “crucial step” of not pressing my brake before activating parking brakes now I have Christmas lights all on dash and brake malfunction warnings can someone please help me on resetting system I’d greatly appreciate it 🙏🏾
I’ve done brake pads on multiple cars before including my 650i never had this issue before
11-29-2023
No guarantee but you can try to download Bimmerlink and try clearing all the error codes to see if it helps. In the TIS, it just says it enters emergency program if the parking brake is not engaged and disengaged before pressing the the brake pedal. Not sure what emergency program is.
11-29-2023
Thanks for the response I reset/clear all the codes and that fixed everything
11-29-2023
Love Do it Yourselfer...many things I have fixed myself thanks to posts like this one. Well done
12-04-2023
I just changed the front pads in my wife's 2020 X5 yesterday. As info, I couldn't take off the parking brake or reset the brake service alert until I started the car and drove off. When trying to reset it said "Reset Unsuccessful". After I drove, I stopped, shut the car off, went into diagnostic mode, and reset the brake service alert.
Thank you,
12-25-2023
Nice I'm glad clearing the codes fixed your issue. Did you use Bimmerlink to clear the codes and errors?
04-12-2024
appreciate listing all the part numbers.
06-18-2025
Have a 2019 x5. Passenger side inner brake pad was worn completely while outer pad was great. I would try to unstick a guide pin on a normal caliper, but no idea how to go about this on the X5 caliper.
Any help is greatly appreciated! Thanks
09-30-2025
Following. Will need this in the future.
