34.1KVIEWS
77REPLIES
53APPRECIATES
37ACTIVE PEOPLE
05-03-2026LAST POST
10-11-2023
Tejas1836 wrote
Oh I understand, I also would like an AS alternative, our rainy seasons here can be flash floods for weeks
Mine are on the way. I'll likely put the summers back on in the spring when the temp steady's out over 50F. The problem in KY is it will oscillate back and forth past that 45F mark for a month or two in both fall and spring. Trying to get the timing right between winters and summers will be impossible... plus the price point is unbelievable... as cheap as these are I'll take the chance and slowly ease my way into any pace to get a feel for handling/stability before I push anything. All the reviews I found were very positive on both the company and the performance of these tires.
10-11-2023
cycolac wrote
I did find them on onlinetires.com. They have the 315's, but 295's are out of stock - just pulled this:
SimpleTire via EBay has them available in that size.
https://www.ebay.com/itm/385611361351?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=i88wEx-RTYC&sssrc=4429486&ssuid=SJocrgjeSbC&var=&widget_ver=artemis&media=COPY
10-11-2023
Got some more time on these today on some familiar roads. Can confirm that the ride is more compliant. Took a fast sweeper off the highway and the tires definitely had a little more play than the PS4s which I guess is to be expected.
11-05-2023
Hi cycolac / GFit - I'm in NJ and thinking about getting these Arroyo tires. How are you liking these tires?
11-05-2023
I’ve got about 600 miles on them so far and no complaints. Temps were in low 30s this week and they handled great. Lots of driving in rain too and they feel solid. Snow is the next test whenever that comes.
11-05-2023
For displacing water, summer tire pattern will be superior to all season.
11-05-2023
Gfit wrote
Here you go
Definitely good found. Usually lesser known brands just isn’t using the latest technique in making the rubbers. And usually that doesn’t reflect when tire is at the first half of life. Toward 2nd half, they may degrade faster, such as less grip or louder. But at that price point, I don’t see why not, instead of changing at 10% left, change at 25% left, you are still ahead.
11-05-2023
They don’t show up as compatible for X5Ms because of their speed rating.
Another reason some tires may not show up is a different/lower load rating. Maybe.
Just a thought. Hope them tires work good. Sailun truck tires are made in Thailand also and they’re know to be be great tires.
11-06-2023
But that doesn't equate to traction. Tire siping gives the traction in the absence of hydroplaning.
11-06-2023
Not correct. Assuming you are on pavement, real differentiation is temperature range. Give summer tires are for warmer temp, the need to handle snow and ice is not needed, the pattern become large block and wide channel.
In the absence of hydroplane, summer tire will have better traction simply because water is not in the picture anymore, given assuming temperature isn't a concern. The exist of sip is for loose stuff, like gravel, or snow. You will never see people switch to all season tire is auto sport event in raining day.
11-07-2023
Just picked up a 2024 x5 w/ the same 22's as you. I as well am looking for the All Season. Pirelli makes one in that staggered size but out of stock everywhere. I think after this thread I will try those Arroyo's. I am always hesitant about the off brands, but probably worth it for the $$.
12-10-2023
Any updates, traction, noise, wear ?
12-10-2023
Look the same as the day I installed them, don’t really notice any tire noise and still taking corners at same speed as previous summers just maybe feel a little bit of wiggle deep in corner but after a month I don’t really notice that anymore either. No snow yet here but they do just fine in sub freezing temps
03-23-2024
Hey one more update? Its been another 4 months haha .. curious
03-25-2024
Going great. Made it through the freezing temps and some bits of snow. Can’t really see and wear yet. Very pleased with the tires and would get again.
03-25-2024
Thinking about these also. Road trips on 95 in the rain touch sketchy sometimes on stockers
03-25-2024
I ordered these as part of a wheel/tire package. Haven't received them yet as the HRE FF10s are backordered. Hoping they arrive early April. Will report back here with driving impressions for the Arroyo's. From what I've read and seen on youtube, they appear to be decent tires.
03-25-2024
I ordered a set of these tires as well. Received them last week, just need to go and get them installed. Looking forward to no longer feeling like I’m in the tire business with having multiple sets of tires for different seasons for many years not only for my X5M but previous cars as well.
05-02-2024
Anyone besides OP have a long-term update? Curious what people think in different areas of the country.
05-02-2024
Also curious the general consensus on going to all-seasons in general. I was trying to remember the "fatal flaw" I had read about with all-seasons and came across this test:
https://www.edmunds.com/car-reviews/features/tire-test-all-season-vs-snow-vs-summer.html
I don't claim to be an expert on how much you NEED summer rubber, but the wet pavement performance is definitely important, and significantly reduced with all-season tires. This is not something I would have thought based on common sense. Summer performance tires are for people who want to push their vehicle beyond some standard limits, and those limits are probably past what's safe on the road anyway, right? BUT, we probably all drive a lot in the rain....Curious what people think. Does it matter enough or not? I'm not sold either way, but if you have a performance vehicle and push it around a little, the most amount of grip you can get in any condition probably makes the most sense, and the all-seasons sometimes feel like the worst of both worlds instead of the best.
05-02-2024
Interesting read, thanks for posting.
05-02-2024
Besides the OP, not sure many on here have had them long enough to provide a long-term review.
I have no complaints/regrets after a month. Do not feel I lost any performance during my spirited drives with takeoffs or sharp bends. I don’t ever drive it hard in the rain so can’t speak on that, but haven’t noticed any lost stability on rainy days under normal driving. Installer had no issues with balancing and they have a good looking sidewall to them. How they handle in the snow will be the next test.
