123.4KVIEWS
64REPLIES
76APPRECIATES
10ACTIVE PEOPLE
05-14-2026LAST POST
09-23-2023
I've had many E34's in the past and co worker wanted to buy my ex. E46 316Ti and this was sale at same time. Rust wise it was good for Finnish market so I had to crab it. Just basic M50B20 with not many extras, Air conditioning at least.
When I bought it:
AIL4fc8nl3dEovf6yGwysAN0NbrOTbNF0cTDQb1JYbg3HML-eCxTQ05VlQqiOd7OEGM3laYCCqhB4MeYXeXvnqX5M2iuJuuW5QzrWgTeEf5LDrso-IeHzOI=w1024
AIL4fc9ct4elj8QcliK_Liv_w00XA3iXwhS6P94TtlWe-mc0uANgGwAN1euv0ojKb0xfIoYhjnv-DjC1tqs5ZFJTago1oRdZbhUOogSyfghHTPt2uRT4jkI=w1024
AIL4fc_dwAXv_YPQC4s4c4NCjybAHVthKl3hz16wgOadQcOwfXfqBIeVcafv8YLf9oQ_D4ibkr7KrRnNHXIfH4qAR4budmJwzs8VS_HDMs8E-yWWxGHZyYI=w768AIL4fc8WJFmn-emOJg2oeg9ErmnAbxk8Hl6l8Q08zKib1qPwZc7gmqpbEIdbdqIKRqpTmKhPgWayP3EypV2rIT5aTtMlfPFa3aHW-BaYCzE99dHfMMAyuHE=w768
Some fault that was found just by looking:
AIL4fc-ucYNtU7e40dnsPGkdhT-6s3XTBGmKvDwyIDs4rZwLfkhtjSIX7weAtKGtBvQBn8uJFjD6HoDJ28FfdNANNWH8SZ5TyApWMoj1OHz2MRfGM5P8vDo=w768
AIL4fc97u5LPpM69IqqjFpMnTSP53I2HwqDabrEPrS66FPT1WVg2AWdjP5K6zxNn2dLnymp7hcjqn7HCwdH8ZeXRNhdoeAyFbMA8HSt6xb2c4d2vpOs7fZk=w768
AIL4fc9kc1E8PD3FGFyHPgut16JMjHXYzRHmAzKXWKoSiHDEySGSN8449N9BiHiR4zv53Yn4eiBuwIDBbXvy3clO_hKeo2CWVNjCwdsuOELIxRKRAqFVGMQ=w1024
Oil leak was mainly leaking oil filter housing but some ps lines are leaking also. Gonna order all new. Steering box is also leaking and wanna retrofit servotronic as wiring is already there.
I had these 351's laying around, so I put them on:
AIL4fc_mmJRMRKmWpwO6RhDr7j7Cmar8Hp-ojEQ7AX3TXj5ZSPS_4hVa2dAVPBx2liKVgSwqjaZjCD7fChuzMPDczslspjvCGC-YHMSrIcStI4-coSueIbc=w1024
Bought "some" parts for suspension + coilovers
AIL4fc-Q7YIzLFWY-4IqcNxLu84sV__WhUvTJl0Sp0melN-YPst-riHMw8FdTXhapNIaMph7_r9KTPQNHFpS8Fj4EOVQExDOGEu8G-qed-OanXGQbcbItwY=w1024
AIL4fc98-p-XZxmmgrkLnvMRGWMcQ83FDS7ixxPRrQTxVfv2Og9YL5S8YsjPC6wCJW3XurYf6HNCiU9ftOrQUUVRUo58-5tq9vADWZB7GtKHsNSMc-gOdRM=w1024
AIL4fc-jTM39FqkoPxJ0frNpmorZGAKrjEnannps0k4-7GYS_DSw3eICnIBphxhETNms5eySwNhjmHzlhPV23ToJ7Pcv7XXSrH4kwaEX1fqDWIQpK2OOK9Q=w1024
AIL4fc_1KUIfpInlDVHrjX-J01C2Ncsho72wjeOmhIi284pS3w-btOo-wrF3zIiwjhphX_ubYKZTz1L-A8yG2qZOY4Bq67mvq4W89LnfTcuU8r0FGH_iPzc=w1024
Subframe bushings replaced
AIL4fc-kZnCRFY4VAAN6vUJ3jiO8Zwvj6pJLnGvjP8RGWArUk_Khmvu3pL0mSlDkVt0MGsWBYMBJwcvHvNrtc6c1QT1X7bCjVrLRMXeX-1WqQqtpvnO_z1E=w512
AIL4fc-o3VD-8IXfmnPe1M9HLc8odnhnEdZuBj982oFpmh6RaSxfYxdXNx-auXKhI9rkxmcsLHqEDeWBilwHnaH7QIVH5iQrBvA7RJc0mXHOIicj1hFaZDc=w768
AIL4fc9lwQ3NowGMfu1cxaKG9ESXwTLFXboh-sMqUqfCxJVDtGvk0GfMAAQzghBxsQNSCedUyvrDcj33IiUrPpxRjcjGdgqrSyew9ZVmhDhVdLtHMq1i7QE=w512
AIL4fc9B-jP6GFqXB5fR4lGge6sSmQ6ejWhEPkn6CIlXpKu5fnaDQRULCwim_5ylXZzNDqMegKP9Ymply383uGzKTs6zxT9lT3qaLhDFLMK4vz241aZVDg8=w512
Bought sport steering wheel and cruise control to retrofit also
AIL4fc_7_nkgZJhLloJtopZC_kBs0A0PWRsUU546kzpoIn3bdZ15APl68UF3meJ2Awqv3YhxvQNPKJK9Qqj9gr5f_nZ6HHx439AybJWMKnMrPJ-yDByKoAs=w768
AIL4fc-0jkKDb3eNjAhLpCgHR0AQOdRtcm0qFGT9dx_rT7lFqLz-ozm3_otFLN1ONgAyy3ewyeLtt9oSohJgLqzzpi04__uq4bjxatFjpBCO1t_yRcKSCUE=w768
Test setup was with v8 bowden cable with some zipties. Cruise works.
AIL4fc-54X7xVCy0uUzMzcc5CTH_91guGakOkrwUvTsqAmqqVoSvSvwgk1iljzpoWL2HBfqgo44HwC_2ScRZPYtGprkVhi10EIWMvMAyE6gkdOPMvaSgEi8=w768
Ordered correct bowden cable and bracket to get clean install
AIL4fc8F31FU2RwDq79x8z0qIeW8B-l--zwlzZTOPoOxYWSNTN-ZoDDz8A1E-RscLc0y9kTQKhEKYLZhti8TdVIYrhMFbtitmLY0vy5l4L-wKURDMByUvPw=w1024
AIL4fc_zti_UYM3urhS-EYy38C8g7ATKUA5X9ysU52wFfhrmm2WeaZqbF82d84GsSMEgoURuDSYmo1HT50dIOwgxF6SG1MVXPf8pTqfCTkmekwB0SPGn0Jg=w768
Sorry for long first post. Still lot of plans with this one. Would like to get SC kit but they are quite expensive. Bigger engine is another option, but currently I don't have place to make such project so we will see. Soon it's time for winter hibernation and time to order some parts. AC is not working atm as it's empty and R12 system, gonna upgrade it to R134a.
Some To Do:
- Get some better wheels for next summer (done)
- Get ac working
- Bigger brakes
- White indicators (done)
- RE85?
- Drivers side door panel
- Needs polishing (done)
- Rocker panel rust issues are going to be fixed soon (done)
- Front fog light retrofit
- Gotta fix glove box (done)
- Power steering lines leaking
- Instrument cluster needs new display
12-09-2023
Found perfect wheels for it. Gotta order them when it's getting closer to summer.
ADCreHdC9qJzMZydyZJ-G0Nh-OzTxfXqymbvI1P7XV3IcX2RxjCGUw6nMh36MDSQ4PGcxbrpxTXj8Pnga30KH6EuFEUOlVQt3-MCKn9kroDn6UF9P0QJV-Q=w2400
8,5" and 10x18". I will most likely order 235/40 and 265/35 continental sportcontact 7's for them.
12-09-2023
M50b20NV the older NV engines you could run two intakes or two exhaust cams for a bit more lift and profile for an extra 7 hp in the 2.5L engines. Been years since I have seen a NV engine. Nice job of cleaning it up. How does it steer with such big wheels the E34's had the recirculating ball steering wheel.
12-09-2023
It was fine with 19" and all suspension parts new.
01-01-2024
ABLVV8762B2n2Q3IJJRTzi-DA4D47PpQ-9w37ET4ooKgdEwThAvvSFM9T4IrjmcKap65uuo7VlR_TsQ6p_J0wfqQzvucKKVGwo81sWEpI0g2e6GE8bunLgU=w1024
ABLVV87e_4xlixDU_DpngqJ8tRZi-AXSBzCzAw5Cg2EMYz3_if-SznO9hhovDLGlZVt8kudcfrr1twf9wQQCd9hSY11XJPPUGGRAfknLUWjvYQmfawmoWlI=w1024
Took out valve cover, gotta soda plast it and paint it.
01-22-2024
I accidentaly deleted them, but should be restored now. Just hit ctrl+f5 on computer.
ABLVV85f0_KYcwxm-MDLkg8ZPBKvrrF3Ganu8tEd4HVkjK5BKiL7z722XGq_fRtft2Mx9QvNv8qrgJpwdqqAzX77J2P63U698qSNerGc1pxRYSRmx5Bu74I=w768
Got it painted but I think I'm gonna get vht wrinkle paint later and paint it again as not happy with the result.
01-31-2024
I ordered those wheels. Gotta think what tires I want, I can get continental for fair price as I work in tire shop, but I don't know if this car needs such tires so might go with Triangle or Aplus tires.
Still before summer I would like to get the ac working and rust issues fixed from rockers. And little bit emission problems. I will most probably transform this to run on RE85.
02-02-2024
Wheels arrived and already put tires on them. Wish the summer would be here already.
ABLVV87Frn_D22Bv-NR-IDjO06ht75mciHfmSxwCblmU65TXVXupIM2mvVuhumNCwuDJr6BzwJz-G1leyn-uRCoGg_EaGu2Xn_UfnuLfj-JXfG3_c_LUTlg=w768
02-03-2024
Those 351 wheels don't fit this vehicle. Looking forward to seeing the Alpinas on there.
02-05-2024
265/35R18 would no fit, so 225/40 and 255/35 in picture.
ABLVV846AyfBCqryLeuQ98pM_O_3MmDiSPBlhEOJN8txtlAASU3QxM9bv-QVYuNXj27ObO-8xRSuoi_zKJIbByN2IJrUwlPudEWGmEa1-l9spAG1Mg-kXfs=w1186
ABLVV86YvEnqqVMJKbhHciD_pXl3l1Xa72JMLgCgn_WUg1MtAn3-qxQmwXpprwi35LoW8zU7i7ODWIQY7UiF53rdnU-oZVz0KwtjPEn7MuYsc06ZIskUFQw=w1186
03-08-2024
AP1GczPp4GD9uh4iCok84AJC7P70ay4bEF7CkY2SLtXNXXRdCLpQloEf6fCEwluVZsqlU_XCGRVCOE2U4Dzyva38PMvmA4RAKr3WCU0JOCs-lVftxM0Gg_8=w1024
AP1GczPwINwlbpSof0o0_a7LNjZnifDu0bhL2yKSUaXD8DDRtCVI--LjQBSVZ5mU2Gfj09xH9MsS4Dj8o4u9ZDf9Ld1RJMa8Pp_3g6cFwRSzdLYMPsn60yA=w1024
Started testing polishing on trunk lid. With mirka polarshine 10 and microfiber disc and eccentric polisher. Seems decent. Lot of scratches but to be expected and I don't need it to be show quality. :D
03-19-2024
It is almost fully polished. I painted new mirrors, not best quality job, but better than old ones.
AP1GczNYiNABEgzEXLRv0ChDhoCEWdwQVbMqDmQPMCjpzCMh_r5PK-SaG5yP9duyugEh3CbfmQ9TjjoowP8Na2MTi5-GrI7p9ZFlO5jFG4gXbF8exlODS2A=w768
03-22-2024
Mirros ended being from car with memory seats, so can get them to work. I ended ordering facelift side mirrors.
03-23-2024
AP1GczOaaXpoe8w9UCI9lFlB8kXNaFt26EfzqfvGg3EKVyXEBe0lxQXPmsAPwlZrJ610pEAG9pnv2HgtX7O4Dbfl7GIozLJFrKfJ7cKmliyJ9qr3bp8ueZg=w1024
Ordered aftermarket side mouldings and installed one to see how they fit. Looks fine to me. I'm missing some pins for the clips so gotta wait them to arrive until I can change rest of them.
Also ordered white indicators all around, new ac condenser and right front fender, which I'm gonna try and paint it myself.
03-24-2024
Ceramic coating applied.
AP1GczPXGhOVuuYfLI2c3Xu-8KYhGqdZ_qT46XpLf1190puK4fxdePohCeLcekDQsNEEBqRvBM5PNN9kwYwsSelE1eCIkGHbm-K2JayDX8GbpNWBKO7dQvc=w2400
03-24-2024
Fabulous post.
03-29-2024
AP1GczOGI8PfRBlrIIzBNv4jQXH3c12N094bhMkAUpPkqmxsOHPKUDWl7EmOkZIBaIZUvmx3URorPALStKG2XLCNf_tgf8Ut0YmBPV_7LlbhTE4ROjeqSzA=w2400
Facelift mirrors installed. Looks better with black trim.
04-02-2024
Any hint how to aling lcd ribbon perfectly... This is best that I got with fully assembled cluster. I got all pixels for once, but soon as I assembled the cluster few of them was missing already. 229404km is correct reading.
04-02-2024
Seen a few of them done by m539restorations on YouTube - maybe some hints there?
04-03-2024
cleaned up great!
04-03-2024
wow, this bimmer in incredible, nice work OP!
04-03-2024
Wow looks great on these wheels
