123.5KVIEWS
64REPLIES
76APPRECIATES
10ACTIVE PEOPLE
05-14-2026LAST POST
06-16-2024
Took the oil pan out and found problems... Guess it's time for a new engine.
AP1GczNFaGq8CH5tOmvSIJGGXrzR8LB9Rna_Siqq9soJpfQz7BfiMulwtsOAwp6QNw2OBAAAG_vwg0Lxgt65PBgCbJGEGnC11E5ma05ntm1NtGwjat8ckOI=w2400
06-20-2024
AP1GczObfu9Ebr8mJ57Is2_nPwCbMrVNxmq_egleacPLKhlg5QFilDe9tLLepqlM_ukAV9tNxtKMQNhz910qRtQe1ffFmN8-srmr1wdaR4I2V7CqklP7qMk=w1186
Got armrests back and they look very nice.
Im looking for e39 528ia to take engine and transmission for this.
06-20-2024
Damn...
06-28-2024
Bought 5hp18 from e39 and made a deal of m52b28.
06-29-2024
Sorry to see the engine issue, but glad to see you are not quitting. Keep going!
06-29-2024
I was planning to do swap anyways but not this summer... Did not wanna spend the money yet on engine, but as engine was found localy and cheap I had to buy it.
07-08-2024
I found same color trunk lid that looks really nice condition and seller says it's rust free. Very good find for 120bucks.
I will get the engine this weekend.
07-13-2024
M52 powered alpina trailer.:thumsup:
AP1GczOk8bbJev3PYt32A_10e-3Q7J9TYKZ8CySSrwmNWZwMn5YAJpydTsAol2NHIggKTexS23j8dDxANALzieKWxQNIE91BRbgLYggQ-MRGRhmqVgP50DM=w2400
07-13-2024
:lol:
07-26-2024
Not much have happened. Engine is somewhat stripped down and somewhat clean. Tried to change valve stem seals with compressed air but pretty much all cylinders had one or two valves leaking because of carbon build up. So it was nada. Now engine is at my home garage on engine stand. Gotta try the rope trick for valve stems. And order all the parts to get it ready for the swap.
I'm having hard time finding E38 728i m52 oil dip stick tube which should perfect for this. New one costs a bit too much for my taste.
AP1GczPdl2MhPhWa39xF-EzMiNM-eqLy78hLqSItbQ8TP--T9WSG-MA20vasoVw-tLFO9CbppENC7nmaS-1lsSy7mTHcGkWW7n6mREHD6Z0iiej_SgEoSHo=w2400
AP1GczOuKxGqp2tjmGY9DXb4_1racS-BoIezmMy7Orfn5ceH1VEd2V9B_sNBj3Uv3WOTO8nUT6IsG9pFPVneOygZ0ibOtWshEj67c5ktylHw8NJugvfNgPM=w2400
Back on the road summer 2199?
Been fixing E65 lately. First starter broke down and now electric fan. Without it ac did not work. So money that was itended for this when't in to "dailies"
07-27-2024
Ah, the joys of older BMWs...
07-27-2024
Well, it has over 400 000km already, so not bad. I also had to replace f10 windshield so more money in to daily cars.
07-31-2024
AP1GczP46gyNH9zvaS2XOqUsMLTnTsdUsRXhW8rCBXO7MNbA60yDIf03D-XKq-L71oE_w3uz4nfzPrFF3SeLeRPj2uNt3fzDo6kxBxSj7_AybpgP-5UA2lU=w2400
Let's see how it turns out after some wash and polish.
08-01-2024
AP1GczPZy8NE9uUoJ8S64FVCv4fAyFSUMgk79TRDGajoJvwSgLZ3auKMycSjBeG51rc4GqT06UvWLATePJS63G_htBFI2er_jFEe8-MKxcwtlDcMSOvIxMs=w2400
Turned out pretty nice.
09-22-2024
AP1GczMWgFbxlPr-H33bLc3tvEU-t8Z-aemc-FM245eowNjKKB1unUQArFid5JGdwoqMkt_v4GVI-sjILXvFA0gTIMN_bLAlAZ9HS-uLoyzj3MS7Lqly5Fc=w1024
Valve stem seals replaced on the B28. Next step is to do the rod bearings. Then put new timing guides in and timing cover with new gaskets back on. Then it is pretty much ready to start swapping the engine as many parts are needed from the old engine so cant really do more for B28.
I will also use cam trays and new lifters from M50. So... let's turn it around.
AP1GczOy-C7pdeRRGnFP21KZD1vJDxUFEIYKNtSL7Z5zULb05VpDnlLsJ1v9oQM3XUYQMwaeBDkVIIKau7Sr8ZegDd7cAcF6ySEARWQYueKnMGx_dG_etl4=w1024
09-23-2024
Opened two rods and looks ok to me for and old engine. Crank also looked good.
AP1GczO5CqxYe4PnGJkXf2W_O0ZHMvQAuyUA0XvaqCVDcf7fOaoMTqhy7EehbbPBmJ9AN-C1qOe2TksVZlPCBhrHi1RCHMZgdLUpsZ7-wOZSyDvRUTuWkoY=w2400
Gotta get plastigauge and install new bearings if clearences are ok.
04-15-2026
Trying to get this project going this summer. I took out the main bearings from upcoming engine. They look fine apart of two that has some more wear. So new one in order.
Also ordered F30 335i front brakes (someday have to do something about rear brakes too, easiest would be 540i rear brakes but they are hard to find and expensive) and Alpina Classic 18" replica wheels. 235/40R18 front and 265/35R18 rear.
Currently working on my friends E32 750iL to change engine, after that hopefully it's time to do this one.
04-25-2026
AP1GczM5b4MabIYwhqjs0LTyGzsZKF-Z7KNlzdLGQN1yc0SyMnW3inA2T-ZyTM3FqZNlBfSoEeJj-yO0CJdRovQHq8XRAM3MrIsAr33A49GzWcNMW4fJYXDG=w768
AP1GczM2PrD-KQAgAbz_HtYRzrdIQs8o2PimPgN_nXdVzPC8PM5HlN0HscO-dhFtMRFICNBgozBcKWsbCKODMbScI0FkSkelG0XRt4850mAKPQBt2PuXYU6f=w768
Test fitted new brakes and it is 10mm spacer all they need to get caliper to be in center with brake disc.
04-26-2026
It also seems that you can run 540i brake discs in rear with e8x/e9x (smaller engine versions have 300x20 discs) rear calipers. Bolt holes need minor modification.
You can get those calipers new with carrier for 25bucks, so much much cheaper than E34 540i calipers.
So it will get 300x20 discs rear.
05-03-2026
Took out the crank, cleaned everything and put new bearings in. Now I'm waiting for my electric torque wrench to arrive so I can start measuring bearing clearances.
AP1GczNIr_KMeUbow1glM5LLA95nSXlqBWRjekox89ovRv0Rp7EVnR3o78KaX5GYE0R9poLoqrtR8XSWtRmv_CEmlk789FzKjeWs4ij-SdM_sgLLL2oMZZQb=w768
Upper main bearings looked like new, but these are things "while you are in there"
AP1GczP9ykArwaKXez-cTZs-3XplfWe5KJM0yuLyOQCZnF9WtUBiAXM2phkLYsaksJpNjYCgvRj8MzyJvJjopx8m84FFU709hSZGrmsR5J3qgwdu3kEhIntX=w1186
05-14-2026
Measured main bearing clearence and all showed the same so all good.
