406.9KVIEWS
119REPLIES
197APPRECIATES
62ACTIVE PEOPLE
20 hours agoLAST POST
09-28-2025
Nothin popped more than my Imola Red with beige interior & BBS wheels but the chrome style 5’s were nice also.
10-20-2025
audio updates with Jack at Allboros Customs.
The components to the stereo upgrades were great, however some items were missing to make the system sound great. After speaking with Jack we were able to obtain our objective of getting a solid system running lossless.
Components
Helix V TWELVE DSP MK2
The Conductor / by Helix
Remove the system and start fresh, new wiring and making sure the components are fitting correctly in the doors etc.
The Bav Audio 5 inch woofers were all disconnected as they were the weak link in the system.
54865315092_14a49c56fd_c.jpgBMW 740i stereo upgrade by Detailers Domain, on Flickr
54830715756_772a1d1f43_c.jpgUntitled by Detailers Domain, on Flickr
54866162501_7e16272fe3_c.jpgBMW 740i stereo upgrade by Detailers Domain, on Flickr
54829110099_804ce2d34c_c.jpg by Detailers Domain, on Flickr
54829195240_a092b7f022_c.jpg by Detailers Domain, on Flickr
54829123873_8c5f18c0e9_c.jpg by Detailers Domain, on Flickr
54830730571_20ea4a5186_c.jpg by Detailers Domain, on Flickr
54830989138_33a58a590c_c.jpg by Detailers Domain, on Flickr
54827893317_911deacb99_c.jpg by Detailers Domain, on Flickr
54827893322_d38e3e734b_c.jpg by Detailers Domain, on Flickr
54827881667_d6c9414bdf_c.jpg by Detailers Domain, on Flickr
54828733426_ba8fdcca6b_c.jpg by Detailers Domain, on Flickr
54828733361_46b26501a5_c.jpg by Detailers Domain, on Flickr
54828733341_69d3e41ea7_c.jpg by Detailers Domain, on Flickr
54827404223_8a139d8db4_c.jpg by Detailers Domain, on Flickr
54827134436_3c4dd91275_c.jpg by Detailers Domain, on Flickr
54866464995_646efe3e25_c.jpgBMW 740i stereo upgrade by Detailers Domain, on Flickr
54827217534_1decdcf5ea_c.jpg by Detailers Domain, on Flickr
54866528460_9ce2dca906_c.jpgUntitled by Detailers Domain, on Flickr
54866465000_7a0f708ca6_c.jpgBMW 740i stereo upgrade by Detailers Domain, on Flickr
54866414914_3f4856a6ac_c.jpgBMW 740i stereo upgrade by Detailers Domain, on Flickr
54866497674_095456af30_c.jpgBMW 740i audio upgrade by Detailers Domain, on Flickr
54866495054_6105dd127a_c.jpgBMW 740i audio upgrade by Detailers Domain, on Flickr
54866545210_16e9fd7438_c.jpgBMW 740i audio upgrade by Detailers Domain, on Flickr
10-20-2025
Nice! I haven't see the "sub in the footwell" thing in a long time. I bet that sounds spectacular.
10-20-2025
Oil Change and filter change @98k ... leaky lower gaskets, tie rods and more suspension repairs coming.
Power steering was acting up, power steering fluid flush and filter removed
54866520828_f452a015b5_c.jpgBMW e38 engine bay by Detailers Domain, on Flickr
54866572610_07955f9785_c.jpgBMW 740i maintenance by Detailers Domain, on Flickr
54866572480_7f68340dda_c.jpgBMW 740i maintenance by Detailers Domain, on Flickr
54866514848_3db07233bf_c.jpgBMW 740i maintenance by Detailers Domain, on Flickr
54865423332_e8e32cfabb_c.jpgBMW 740i maintenance by Detailers Domain, on Flickr
Piaa Aero Vogue Wiper Blades for the 7 a more period correct set up - as good as the Icon's were they just didn't look right and the passenger side end didn't get the coverage during the sweeps. Very happy with the Piaa's. I had to trim the wiper blade a bit back as it was hitting the window seal.
Bosch Icon
54865466027_6cc682f10d_c.jpgBMW e38 740 / Piaa Aero Vogue Wiper Blades by Detailers Domain, on Flickr
54866557063_db584f0e87_c.jpgBMW e38 740 / Piaa Aero Vogue Wiper Blades by Detailers Domain, on Flickr
Piaa Aero Vogue Wiper Blades on
54854805164_bf0c8280aa_c.jpgPiaa Aero Vogue Wiper Blades e38 BMW by Detailers Domain, on Flickr
54854561296_609c90631d_c.jpgPiaa Aero Vogue Wiper Blades e38 BMW by Detailers Domain, on Flickr
54866313171_7968e70403_c.jpgBMW e38 740 / Piaa Aero Vogue Wiper Blades by Detailers Domain, on Flickr
54866557078_4fbd5e8d4a_c.jpgBMW e38 740 / Piaa Aero Vogue Wiper Blades by Detailers Domain, on Flickr
54866615890_4c7bceba7e_c.jpgBMW e38 740 / Piaa Aero Vogue Wiper Blades by Detailers Domain, on Flickr
54866631850_8995847e74_c.jpgBMW E38 740 I WITH Piaa Aero Vogue Wiper Blades by Detailers Domain, on Flickr
Nextzett Krystal Klar - Windshield Wash Fluid Top Off
54825175731_25ed454393_c.jpgUntitled by Detailers Domain, on Flickr
Liquid Molly Jectron Fuel Injection Cleaner
54825168736_e983f6a648_c.jpg by Detailers Domain, on Flickr
10-20-2025
sound is incredible! I'm gonna try to get a better head unit solution this is really now the only weak link to the system the head unit.
also we may put some mids in the a pillars to complete the system.
10-20-2025
That shine is exceptional, youve done this to a fantastic standard!
10-21-2025
Front Suspension Maintenance and Upgrades continue
BMW Tie Rod Kit With Link - Meyle E38TIERODKIT-MY
OEM Part Number Associated with the Kit
3160404349, 1014578, 3160204351
Comes with center drag link and outer tie rod ends, the ideal solution for restoring your BMW's steering to factory condition
As your car's mileage increases, it is best to check the steering and suspension for excessive play due to wear. Additionally, if you are experiencing abnormal tire wear, or steering wheel vibration at speed you should also check these components for possible replacement.
Steering Tie Rod Assembly
The tie rods of your vehicle play a critical role as they're the link between the power steering rack and pinion and the wheel spindle. Tie rod ends contain ball joints that tend to wear out over time due to constant wear and tear. When the ball joints within the tie rod wear out, it allows for play within the wheels which can throw off your alignment and cause uneven tire wear. Its always encouraged to check your tie rod ends for play as well as tires for uneven wear at every service interval. When replacing worn tie rod ends its always recommend to replace them in pairs as well as to perform an alignment.
Steering Tie Rod Assembly Failure Symptoms
Uneven tire wear
Play in wheels
Pulling condition when driving
Sloppy steering
Turner Mono-ball Control Arm Upgrade Kit - Pre-installed - E38
Turner Motorsport
T#: 402092 | Part#: 022015TMS09KT
Product Details
BMW’s are known to have failure prone front thrust arm bushings. The flexible rubber bushings, even those found in M performance models, allow significant movement of the front wheels to maximize daily driving comfort, but also allow considerable alignment change. This results in a disconnected and numb road feel, standing between you and a confidence inspiring driving experience. Eventually the fluid filled rubber bushings fatigue and crack due to continual deflection and ozone degradation, and eventually the damping fluid leaks out resulting in complete failure.
For the enthusiast looking for superior performance and longevity with a crisp, confidence-inspiring driving experience, our sealed ball joint monoballs are the best solution available! Our experience with spherical front control arm ball joints goes back to those we designed and used in our IMSA E90 328i and E92 M3 race cars (GS class Champions in 2011). We wanted to offer as many BMW owners possible a similar level of handling, precision, and control for the track and street.
Utilizing a sealed OEM BMW ball joint for exceptional quality and durability, making them completely at home on both the street and track with no compromise. We have done extensive street, autocross, and track testing to ensure the ball joint used in this bushing design excels in each setting. The advantage of a sealed ball joint is that it eliminates all unwanted deflection while still allowing complete bind-free movement throughout suspension travel, resulting in exceptional control of wheel alignment. What you get is superior steering precision, turn-in response, direct braking feedback, and better handling.
In short, if you're seeking the ultimate in precise, predictable handling and control, with crisp braking response and a long service life that’s equally at home on the street or track - look no further. We have you covered.
We offer these control arms with the monoball bearings pre-installed for your convenience. Since BMW recommends the control arms be replaced for every other bushing change, we prefer to sell these as a pre-assembled set. The bushings are also available separately if you wish to source your own control arms.
Features:
Control Arm Bearing
CNC machined corrosion resistant 304 Stainless steel shell, bolt sleeves, & snap rings
Sealed spherical ball joint for long service life & maintained OE fitment
Suspension pre-load is no longer required when torquing the control arm hardware
Performance
Nearly instantaneous, crisp steering and braking response.
Maintenance free, long lasting performance.
Improved road feel without undesirable NVH.
Also the car has been leaking oil -
BMW Timing Cover Seal Strip - Genuine BMW 11141741127
BMW Timing Cover Seal Strip - Genuine BMW 11141741128
Once the parts get in we will be getting on this repair.
Add 10/24/25
Common problem: Rear View Mirrors failed - Ordered some Euro Spec BMW E38 Auto Dim Glass Mirror Heated and Dimming Aspheric Mirrors Set
(pre owned / crossing my fingers they looked good on photos)
Genuine BMW - 51168165112 (need to confirm)
04-23-2026
4/23/26
Will be upgrading the lights
URO Headlight Lens Gasket - BMW E38
T#: 589703 | Part#: 63128361290
Magneti Marelli Headlight Lens Cover - Left - E38
T#: 376368 | Part#: 63128381327
Magneti Marelli Headlight Lens Cover - Right - E38
Magneti Marelli
T#: 376369 | Part#: 63128381328
Once I have the refresh parts I will send off a set of lights to Lightwerkz
BMW e38 Light Upgrade at Lightwerkz
Seat Trim Pieces will be refreshed
URO Seat Switch Covering Set - Black - E38, E39
URO
T#: 37183634 | Part#: 52107058008
Acer Racing BMW Titanium Lug Bolts
BMW E Series Natural Titanium 20 pieces M12x1.5x28
BMW Parking Brake Handle - Genuine BMW 51458165258
05-05-2026
Arrived
Not the greatest looking packaging but I guess it's about what's inside
Lighter than the regular bolts
Standard lugs on the left / Ti Lugs on the Right
Before the Ti Lugs
TIi Lugs all in
20 hours ago
Really enjoying this build thread. Looking forward to more detailed updates!
~Alex
