143.3KVIEWS
41REPLIES
73APPRECIATES
7ACTIVE PEOPLE
5 hours agoLAST POST
08-27-2025
This thread contains links to the service bulletins submitted by BMW to NHTSA for each model, as well as a recent list across all models.
These lists will be updated daily with any new or changed bulletins.
By Model
BMW G05 (X5) Service Bulletin List
BMW G07 (X7) Service Bulletin List
BMW G20/G22 (3 & 4 series) Service Bulletin List
BMW G26 (i4) Service Bulletin List
BMW G42 (2 series) Service Bulletin List
BMW G45 (X3) Service Bulletin List
BMW G60 (i5 & 5 series) Service Bulletin List
BMW G70 (i7 & 7 series) Service Bulletin List
BMW G80/G82 (M3/M4) Service Bulletin List
BMW G87 (M2) Service Bulletin List
BMW G90 (M5) Service Bulletin List
BMW I20 (iX) Service Bulletin List
BMW U11/U10 (X1/X2) Service Bulletin List
Archive
https://itsanalogue.github.io/bmw-tsb/index.html
08-27-2025
Recent Bulletins
SIB 64 03 26 (2026-05-07)
BMW IX 2025
ENGINE
After starting up the vehicle, a distinct, constant, “humming” noise can be heard from the right area of the instrument panel.
MC-11032742-0001.pdf
SIB 01 14 25 (2026-05-07)
BMW X3 HYBRID 2021
BMW X5 HYBRID 2021,2022
(plus 1 other model)
ENGINE
The EVAP systems purge (vent) valve limited warranty for defects in materials and / or workmanship has been extended to 15 years / 150,000 miles as determined from the original first in-service / delivery date.
MC-11032734-0001.pdf
SIB 01 03 24 (2026-05-06)
BMW 330I 2019,2020,2021,2022,2023,2024
BMW X3 2018,2019,2020,2021,2022,2023,2024
BMW X4 2018,2019,2020,2021,2022,2023,2024
BMW X5 2019,2020,2021,2022,2023
BMW X7 2019,2020,2021,2022
BMW Z4 2019,2020,2021,2022,2023
BMW Z4 M40I 2024,2025
(plus 4 other models)
ENGINE
The EVAP systems purge (vent) valve limited warranty for defects in materials or workmanship has been extended to 15 years / 150,000 miles as determined from the original in-service date.
MC-11032731-0001.pdf
SIB 01 01 26 (2026-05-06)
BMW 230I 2022,2023,2024,2025
BMW 430I 2021,2022,2023,2024
BMW 840I 2020,2021,2022,2023,2024,2025
BMW M240I 2022,2023,2025
BMW M440I 2021,2022,2023,2024
ENGINE
MC-11032729-0001.pdf
SIB 65 20 25 (2026-05-05)
BMW 230I 2023,2024,2025,2026
BMW 330I 2023,2024,2025,2026
BMW 430I 2023,2024,2025,2026
BMW 530I 2025
BMW 740I 2025
BMW M3 2025
BMW M4 2025
BMW M5 2025
BMW X3 2025
BMW X5 2023,2024,2025,2026
BMW X6 2023,2024,2025,2026
BMW X7 2023,2024,2025,2026
BMW XM 2023,2024,2025
BMW XM LABEL 2026
ELECTRICAL SYSTEM
After replacing the Multifunctional Display (MFD), the Central Information Display (CID) is black. The backlight of the CID is illuminated, and touch function does register an audible sound.
MC-11032744-0001.pdf
SIB 01 02 24 (2026-05-05)
BMW 340I 2019,2020
BMW X1 2023
BMW X2 2023
(plus 16 other models)
ENGINE
MC-11032730-0001.pdf
SIB 64 12 24 (2026-05-04)
BMW 230I 2022,2023,2024,2025,2026
BMW M8 2022,2023,2024,2025
BMW X3 2022,2023,2024
BMW X4 2022,2023,2024,2025
BMW X5 2023
BMW X6 2023
BMW X7 2023
STRUCTURE: BODY
1. Use of aftermarket accessory hang-on cellular phone holders and/or air fresheners can break the instrument panel air vent slats. Damage and/or issues caused by outside influences are not covered under the BMW limited warranties. Originally, the air vent slats were only repairable by replacing the entire front center dash vent assembly; which in some applications, also included the IHKA control module.
MC-11032743-0001.pdf
SIB 64 03 20 (2026-05-04)
BMW X5 2019,2020,2021,2022,2023,2024,2025
BMW X6 2020,2021,2023,2024,2025,2026
BMW X7 2019,2020,2021,2022,2023,2024,2025,2026
EQUIPMENT, STRUCTURE: BODY
The center console and front cup holder get noticeably too warm to the touch on long journeys with the interior "Heating on".
MC-11032741-0001.pdf
SIB 63 09 25 (2026-05-04)
BMW 230I 2025,2026
BMW X3 2025,2026
ELECTRICAL SYSTEM, EXTERIOR LIGHTING
After programming the vehicle via ISTA/RSU to 25-07-5xx, some of the interior ambient lighting strips (examples circled) may no longer function properly.
MC-11032740-0001.pdf
SIB 61 09 26 (2026-05-04)
BMW X5 2025
BMW X5 PLUG-IN HYBRID 2026
BMW XM 2025
BMW XM LABEL 2026
ELECTRICAL SYSTEM
An error in the Battery Management Electronics (SME) can lead to an interruption in communication, which can lead to the high-voltage system being turned off. The error is indicated by a Check Control message, and it is generally possible to continue driving until the vehicle is parked.
MC-11032739-0001.pdf
SIB 52 19 23 (2026-05-04)
BMW X7 2022,2023,2024,2025,2026
SEATS
In vehicles equipped with the second row 60% / 40% split seat, the flex cable assembly can come out of the seat rail mechanism (circled). This stops the forwards and backwards travel of the seat.
MC-11032738-0001.pdf
SIB 51 12 24 (2026-05-04)
STRUCTURE: BODY, UNKNOWN OR OTHER
There are two possible situations (rear left, right or both sides): A. The electric sunshade in the rear door does not function or sticks upon operation, and/or B. The electric sunshade is wavy.
MC-11032737-0001.pdf
SIB 41 01 26 (2026-04-29)
BMW XM 2025
STRUCTURE: BODY
Delivery Stop - Tail Panel Plug
MC-11031872-0001.pdf
SIB 31 05 26 (2026-04-29)
BMW 530I 2024
SUSPENSION
“Popping” noise from the front axle when cornering and driving on uneven road surfaces.
MC-11031871-0001.pdf
SIB 61 02 26 (2026-04-23)
BMW 740I 2024
ELECTRICAL SYSTEM
In rare occasions, control of certain vehicle security functions via the Central Information Display (CID) is restricted for a short period of time.
MC-11031567-0001.pdf
SIB 51 06 26 (2026-04-23)
BMW 430I 2022,2023,2024,2025,2026
BMW I4 2022,2023,2024
BMW I4 XDRIVE40 2025,2026
STRUCTURE: BODY
While driving on rough surfaces, a “tapping” noise can be heard from the tailgate area
MC-11031566-0001.pdf
SIB 32 03 26 (2026-04-23)
BMW 530I 2024,2025
BMW 740I 2024,2025
BMW IX 2024,2025
STEERING
“Groaning” noise from the EPS when the steering wheel is at the end stops.
MC-11031564-0001.pdf
SIB 31 04 26 (2026-04-23)
BMW 740I 2023,2024,2025,2026
BMW I7 2023,2024,2025
STEERING
SITUATION When turning the steering wheel fully to the steering end stops, a ”groaning” noise can be perceived at the respective steering stop. The noise occurs at higher ambient temperatures from approx. 68°F.
MC-11031562-0001.pdf
SIB 61 06 26 (2026-04-22)
BMW I4 2024
BMW I5 2024
BMW I7 2024
BMW IX 2024
ELECTRICAL SYSTEM
Charging sessions cannot be started or they are interrupted while using a Level 2 AC high-power charging station, or with a Level 3 DC charging station. Charging may start normally but can interrupt after some time. Level 2 (240 V) Flex Charger and Wall box may also be affected. The red or white LED is displayed on the high-voltage charging socket; however, no associated fault codes are stored.
MC-11031568-0001.pdf
SIB 32 09 25 (2026-04-20)
BMW X3 2025,2026
STEERING
Check Control message and a significant change in steering feel.
MC-11031565-0001.pdf
SIB 32 02 26 (2026-04-20)
BMW X3 2025,2026
STEERING
Check Control message and a minimally changed steering feel.
MC-11031563-0001.pdf
SIB 24 01 26 (2026-04-17)
BMW M5 2025,2026
ELECTRICAL SYSTEM
A possible “jerking” motion may arise when using the Parking Maneuver Assistant in purely electric mode in vehicles with 7 kW charging power and a programmed I-level starting from 25-03-500
MC-11031572-0001.pdf
ReleaseNotes_2603_US_BMW (2026-04-13)
BMW 330I 2026
ELECTRICAL SYSTEM, UNKNOWN OR OTHER
This communication contains the Release Notes for the BMW 2026-03 Remote Software Upgrade.
MC-11031600-0001.pdf
SIB 65 12 26 (2026-04-13)
BMW 230I 2025
BMW X1 2025
BMW X2 2025
BMW X3 2025
ELECTRICAL SYSTEM
After updating the vehicle to I-level …25-07-5XX, the spoken language of the navigation instructions changes from the set language for the voice assistant without the customer initiating the change.
MC-11031578-0001.pdf
SIB 12 05 26 (2026-04-10)
BMW 530I 2024
BMW 740I 2024
ELECTRICAL SYSTEM
A “knocking” sound from the fuel tank area can be heard in the passenger area. Occurrence information below. 1. The noise occurs when the engine is at idle 2. The noise occurs sporadically 3. The noise disappears when the fuel filler cap is opened 4. The noise also disappears when the tank ventilation valve is disconnected There is no relevant fault saved in the fault memory.
MC-11031571-0001.pdf
SIB 61 03 24 (2026-04-09)
BMW 750E 2024
BMW 750E XDRIVE 2026
BMW I4 M60 2026
BMW I5 2024
BMW I5 EDRIVE40 2026
BMW I7 2023,2024
BMW I7 EDRIVE50 2026
BMW IX 2021,2022,2023,2024
BMW IX XDRIVE45 2026
BMW M5 2025,2026
BMW M5 SPORTSWAGON 2025
BMW XM 2023,2024
BMW XM LABEL 2026
ELECTRICAL SYSTEM
Gen 5 BEV/PHEV vehicles may set the Combined Charging Unit (CCU) in programming abort due to no communication to the HV charge socket electronics.
MC-11031576-0001.pdf
SIB 31 03 24 (2026-04-08)
STEERING, SUSPENSION
When rolling forward or backwards with the steering at full lock (left or right) without the brake applied, a “groan”-type noise may be heard from the front axle. The noise is most noticeable after load reversal. The noise can be heard beginning at the 7 second time stamp.
MC-11031573-0001.pdf
SIB 65 09 26 (2026-04-06)
BMW 230I 2025
BMW X1 2025
BMW X2 2025
BMW X3 2025
ELECTRICAL SYSTEM
The customer reports that the Intelligent Personal Assistant (IPA) does not respond to the "Hey BMW" wake up word, or to the push-to-talk (aka voice activation) button on the steering wheel. Also, various voice commands are possibly not correctly executed.
MC-11031577-0001.pdf
SIB 32 01 23 (2026-04-06)
BMW 230I 2023,2024
BMW 330E 2021,2022,2023
BMW ALPINA XB7 2022,2023
BMW I4 2022,2023
BMW M2 2024
BMW M3 2021,2022,2023,2024
BMW M340I 2020,2021,2022,2023
BMW M4 2021,2022,2023,2024
BMW M440I 2021,2022
BMW X6 2020,2021,2022,2024
BMW X6 M 2020
BMW XM 2024
BMW Z4 M40I 2024
(plus 2 other models)
When turning the steering wheel while stationary or when driving on uneven roads; cracking, creaking, or knocking noises may be heard.
MC-11031574-0001.pdf
SIB 12 04 26 (2026-03-27)
BMW X3 2026
ELECTRICAL SYSTEM
DELIVERY STOP: HARNESS ROUTING
MC-11030333-0001.pdf
InVeh-InApp-Comm (2026-03-25)
BMW 330I 2025
EXTERIOR LIGHTING, LANE DEPARTURE: WARNING
It was determined that the lane change warning in the exterior mirror may not light up bright enough. To correct this issue, the vehicle’s software needs to be updated.
MC-11030328-0001.pdf
BMW X3 2025
STRUCTURE: BODY
Under certain conditions when driving, the underbody baffles may not completely prevent water ingress. To correct this, the underbody baffles will be re-sealed.
MC-11030322-0001.pdf
BMW 430I 2025
STRUCTURE: BODY
There are body openings on the vehicle underbody, which are closed with paint plugs or adhesive pads. Your vehicle might not have been fitted with a paint plug on the vehicle underbody. Your vehicle will be checked for paint plugs on the underbody, and any missing paint plugs will be installed.
MC-11030321-0001.pdf
BMW X5 2025
BMW X6 2025
BMW X7 2025
SERVICE BRAKES
It was determined that your vehicle was fitted with a brake booster that potentially has a faulty hydraulic valve. This may result in a modified pedal feel and a sporadic red Check Control message. The brake booster should be replaced.
MC-11030319-0001.pdf
BMW X2 2025
ENGINE
It was determined that the oil return line for the turbo charger was installed with a bolt of the wrong size. The bolt for the oil return line needs to be replaced.
MC-11030318-0001.pdf
BMW 430I 2025
BMW M3 2025
ENGINE
It was determined that due to a manufacturing defect, there may be a peeling of the sliding layer of the main bearing shells. The peeling may cause engine damage to your vehicle in some cases. The main bearing shells will need to be replaced.
MC-11030317-0001.pdf
BMW 430I 2025
ELECTRICAL SYSTEM
It has been determined that the Telematics Control Unit for the vehicle’s backup antenna may not have been programmed correctly. If the main antenna is damaged, the backup antenna may not be available due to the faulty programming. To correct this issue, the vehicle will need to be reprogrammed.
MC-11030315-0001.pdf
SIB 61 05 26 (2026-03-20)
BMW 530I 2025
BMW 740I 2025
BMW M5 2025
VISIBILITY/WIPER
Customers might report that washer fluid is leaking from the lower reservoir area, especially around thewasher fluid pumps.
MC-11030307-0001.pdf
SIB 12 03 26 (2026-03-19)
BMW 530I 2024,2025,2026
BMW M5 2025
BMW X1 2023,2024,2025,2026
BMW X2 2023,2024,2025,2026
BMW X3 2023,2024
BMW X3 2025,2026
ELECTRICAL SYSTEM, ENGINE, UNKNOWN OR OTHER
PROGRAM CONTROL UNITS (OBD)
MC-11030305-0001.pdf
SIB 51 22 24 (2026-03-18)
BMW 330I 2024,2025
BMW 530I 2024,2025
BMW X1 2024,2025
BMW X2 2024,2025
BMW X3 2024
BMW X3 2025
BMW X4 2024,2025
BMW X5 2024,2025
BMW X6 2024,2025
BMW X7 2024,2025
BMW XM 2024,2025
On the main door seal, detachment behaviorcan be detected at the sealing joint . Over time, the seal gradually and increasinglydetaches which can cause it to- Dangle Become visible to the customer Prevent the door from closing properly
MC-11030306-0001.pdf
SIB 65 07 26 (2026-03-17)
BMW 230I 2026
BMW X1 2026
BMW X2 2026
BMW X3 2026
ELECTRICAL SYSTEM
The following message is displayed on the central information display (CID): “Storage space running out”.Afterwards, apps can no longer be updated, and additional content can no longer be loaded.
MC-11030311-0001.pdf
SIB 63 07 25 (2026-03-17)
BMW 230I 2025
BMW X5 2024,2025,2026
EXTERIOR LIGHTING
The check control message(s) for the (brakelights, taillights, side lights, turn indicator,daytime driving lights) taillamps (highlightedin orange in the photo) is intermittentlydisplayed. Possible fault codes entries 80801E- LED driver: Communicationfaulty 80819E- LED driver: Communicationfaulty 80831E- LED driver: Communicationfaulty 80849E- LED driver: Communicationfaulty
MC-11030308-0001.pdf
SIB 65 08 26 (2026-03-16)
BMW 330I XDRIVE 2025
BMW 430I 2025
BMW 530I XDRIVE 2025
BMW 740I 2025
BMW IX 2025
BMW X1 2025
BMW X2 2025
BMW X3 2025
BMW X5 2025
BMW X6 2025
BMW X7 2025
BMW XM 2025
ELECTRICAL SYSTEM
After the software update to version …25-07-5XX, existing activation points for the “Automate My Habits”function no longer work.
MC-11030312-0001.pdf
SIB 65 04 26 (2026-03-16)
BMW 430I 2025
BMW 840I 2025
BMW Z4 M40I 2025
UNKNOWN OR OTHER
Customers may report issues with the alarm system not functioning correctly. These concerns may includeone or more of the following: Missing confirmation sound (function cannot be selected or deselected in the Central InformationDisplay (CID) menu). Alarm system deactivated (interior mirror light off). Alarm does not function. DWA LED without function after locking (no flashing/flashing). Acoustic acknowledgement is unavailable or cannot be enabled/disabled via the CID menu underdoors/windows. Tilt alarm sensor “SINE” cannot be reached via diagnostics.
MC-11030310-0001.pdf
SIB 52 01 26 (2026-03-09)
BMW X7 2024,2025,2026
SEATS
The customer brings vehicle in with one or both of the second row 60/40 split seats in the folded position.The seat does not respond to any requests from the second seat row seat switch button(s).
MC-11030063-0001.pdf
SIB 01 03 25 (2026-03-06)
STRUCTURE: BODY
The Radiator Grilles Lower Active Air Flap Assembly limited warranty for defects in materials and/or workmanship has been extended to 15 years / 150,000 miles as determined from the original first in-service / delivery date.
MC-11030060-0001.pdf
SIB 12 05 23 (2026-03-06)
BMW I5 2024
BMW I7 2023,2024
ELECTRICAL SYSTEM, POWER TRAIN
The customer states there is a Drivetrain Malfunction message displayed in the instrument cluster. In addition, the following fault memory entries are saved in the CCU (Combined Charging Unit) 0317F2 - High-voltage system, insulation fault detected: when switch contactors are closed. 0317F1 - High-voltage system, insulation resistance below warning threshold: when switch contactors are closed. The fault memory entries (isolation faults) can occur both individually and in combination and must be traced back to the eDrive motor based on the ISTA test procedure. If ISTA test procedure lists possible cause of fault as; A metal chip is found behind the brush module (between the brush module and the end shield of the electrical machine). Repair required. Refer to service solution no. 20000794435083 in Aftersales Information Research (AIR). Follow information in the Procedure section below.
MC-11030059-0001.pdf
SIB 51 05 26 (2026-03-05)
BMW IX 2024,2025
STRUCTURE: BODY
A “groaning” noise may be heard when closing the tailgate.
MC-11030055-0001.pdf
SIB 61 03 26 (2026-03-05)
BMW 550E XDRIVE 2025
BMW 750E XDRIVE 2025
BMW M5 2026
BMW XM 2025
ELECTRICAL SYSTEM
Several complaints are possible: Vehicle does not start Gear cannot be engaged Various Check Control Messages Malfunction indicator lamp (MIL) on Several Check Control messages are possible: “It is possible to continue driving. High-voltage system.” “You can continue driving. Drivetrain.” “Restart not possible. Drivetrain fault.” “Call Roadside Assistance. Drivetrain failure.” “Information: Total error of vehicle.” The following fault memory entries are stored in the CCU: D796D9 - Message (- 0x91) not up-to-date, receiver CCU, transmitter EME D796DC - No message (- 0x91), receiver CCU, transmitter EME D796D8 - No message (- 0x91), receiver CCU, transmitter EME Other fault codes below may be stored in the EGS BA09B8 – Inverter, Voltage Sensor, 5V HV AUX: Out of range or open connection detected BA0A45 – ECU internal: Internal error of the synchronous serial data bus. Additional fault memory entries are possible. Similar fault memory entries indicating a missing EMEmessage (Traction E-Machine Electronic) can also be stored in other control units.
MC-11030054-0001.pdf
SIB 61 19 25 (2026-03-04)
BMW 750E 2023,2024
BMW M5 2025,2026
BMW X5 2024,2025
ELECTRICAL SYSTEM
The malfunction indicator lamp (MIL) is triggered by the erroneous fault code 031BFC- AC charging,charging electronics 2, internal fault: No internal capacitor discharge stored in the CCU. However, AC charging is operating as designed without a charging concern or issue. Affected PHEV vehicles have the CCU-03 (7.4 kW / 11 kW) with I-levels from …24-07-500 to …25-11-5xx.
MC-11030053-0001.pdf
SIB 61 23 25 (2026-03-04)
BMW M5 2025,2026
BMW X5 2025
BMW XM 2025
BMW XM LABEL 2026
ELECTRICAL SYSTEM
The malfunction indicator lamp (MIL) is triggered and 0318E2 AC charging, charging electronics 1,component protection: Overload current on AC side fault may be stored during AC charging Level 1(120 VAC). Note: Despite the fault memory entry (and the malfunction indicator lamp), the AC charging process willcontinue operating as designed and there is no related drivability complaint. Affected PHEV (plug-in hybrid electric vehicle) vehicles with CCU-03 (7.4 kW combined charging unit).
MC-11030051-0001.pdf
SIB 61 22 25 (2026-03-03)
BMW M5 2025,2026
BMW X5 2025
BMW XM 2025
ELECTRICAL SYSTEM
Malfunction indicator lamp (MIL) is triggered by the erroneous fault code(s) BA0023 - Control unit: internalfault (software group fault) In addition, the BA0008 - CCU, internal coolant temperature sensor:Signal implausible faults may be stored in the CCU memory. However, AC charging is still operating as designed, without any related drivability complaints. Affected PHEV vehicles have the CCU-03 (7.4 kW / 11 kW) with I-levels from 24-07-500 to 25-11-5xx.
MC-11030052-0001.pdf
SIB 33 01 26 (2026-03-02)
BMW X1 2023,2024
BMW X2 2023,2024
SUSPENSION, WHEELS
1. Noise complaint: Humming or clicking type noise in the speed range of 15 – 65 mph can be heard from the rear axle. Seeattached video “V33 01 26 Humming” and “V33 02 26 Clicking” The noise may be amplified depending on road speed. Or 2. Fault memory entry: Customer has Dynamic Stability Control malfunction indicator lamp and/or related Check Control Message. The following fault codes are found in the Integrated Brake module fault memory: 4809B7: Wheel speed sensor - rear left - tooth missing 4809C2: Wheel speed sensor - rear right - tooth missing 480AB4: Wheel speed sensor - rear right – noise monitoring 480AAD: Wheel speed sensor - rear left – noise monitoring
MC-11030056-0001.pdf
SIB 71 01 26 (2026-03-02)
BMW ALPINA XB7 2026
UNKNOWN OR OTHER
Delivery Stop - VIN Label
MC-11029099-0001.pdf
SIB 17 01 24 (2026-02-25)
BMW I5 2024,2025
BMW I5 EDRIVE40 2024
BMW IX 2021,2022,2023,2024,2025
ENGINE, ENGINE AND ENGINE COOLING
There is coolant leaking from under the car Low heater output Possible Check Control message “Drive, you can continue driving” (ID49) Possible fault codes stored in these BEV vehicles: 224163 – Electric auxiliary heater for the high-voltage battery unit: Undervoltage or internal communication fault 8049AA - Coolant level sensor, expansion tank: Coolant level low or short circuit to ground or line disconnection 80124F – Electric auxiliary heater: Communication in electric auxiliary heater faulty 224F60 - Coolant level sensor, expansion tank: Coolant level low or short circuit to ground or line disconnection 224111 - Cooling system for power electronics: Coolant loss detected 224107 - Cooling system for high-voltage battery unit, component protection: Detection of coolant loss
MC-11029046-0001.pdf
SIB 51 04 26 (2026-02-24)
BMW X5 2024
BMW X7 2024
STRUCTURE: BODY
A slight depression or outline (circled) may bevisible on the top passenger side of theinstrument panel.
MC-11029069-0001.pdf
SIB 33 01 25 (2026-02-23)
SUSPENSION
“Rattling” noises heard from the area of the luggage compartment when driving over a rough road surface.
MC-11029068-0001.pdf
SIB 31 03 26 (2026-02-23)
BMW X5 2024
BMW X6 2024
BMW X7 2024
SUSPENSION
Various external influences can cause premature aging of the tension strut hydro-mount elastomer; which can lead to cracks in the material, and leakage.
MC-11029047-0001.pdf
SIB 61 01 26 (2026-02-20)
BMW 230I 2025
BMW 530I 2025
BMW 740I 2025
BMW IX 2025
BMW X1 2025
BMW X2 2025
BMW X3 2025
BMW X5 2025
BMW X6 2025
BMW X7 2025
ELECTRICAL SYSTEM
During vehicle start-up the Secure Element (SE) of the BCP may fail causing communication errors. TheCheck Control message “Drive carefully. Driving stabilisation.” will appear. In addition, the fault memoryentries below will be stored within 40 seconds of each other. ACSM: 02010A - Coding: Coding data not qualified VIP: 02390A - VIP control unit: Coding data not released, signature IB: 02290A - DSC control unit: Coding data not released, signature HKFM: 020D0A - HKFM: Coding data are not qualified
MC-11029070-0001.pdf
RECALL 26V096000 (2026-02-19)
Affecting 58713 total vehicles built between 2024-06-18 and 2025-04-09
BMW 550E XDRIVE 2025,2026
BMW 750E XDRIVE 2024,2025
BMW I5 EDRIVE40 2024,2025,2026
BMW I5 M60 XDRIVE 2024,2025
BMW I5 XDRIVE40 2025,2026
BMW I7 EDRIVE50 2024,2025
BMW I7 XDRIVE60 2023,2024,2025
BMW M5 2025,2026
ELECTRICAL SYSTEM: WIRING
BMW of North America, LLC (BMW) is recalling certain 2025 M5 Sportswagon, 2025-2026 M5, 2024-2025 750e xDrive, 2025-2026 550e xDrive, 2023-2025 I7, 2023-2025 7 Series, 2024-2026 i5, and 5 Series vehicles. The electrical wiring harness for the air conditioning system may become damaged during replacement of the cabin air filter.
RCRIT-26V096-5013.pdf
RCRIT-26V096-1695.pdf
RCRIT-26V096-5504.pdf
RCRIT-26V096-2065.pdf
SIB 65 03 26 (2026-02-17)
BMW 230I 2025
BMW X1 2025
BMW X2 2025
BMW X3 2025
ELECTRICAL SYSTEM
In Augmented View, the arrows are rotated by 180° (shown inverted below) when displayed on the CentralInformation Display (CID).
MC-11028926-0001.pdf
SIB 51 03 26 (2026-02-17)
BMW X1 2025
BMW X2 2025
BMW X3 2025
SUSPENSION
While driving on rough surfaces, a “creaking” noise can be heard from the B-pillar trim panels.
MC-11028923-0001.pdf
SIB 12 03 24 (2026-02-12)
BMW X1 2024,2025
BMW X2 2024,2025
The Engine Malfunction Warning is illuminated, and the following fault code is stored in the DME- FC 034AEF Exhaust Cold Start, Not Controllable
MC-11028920-0001.pdf
SIB 65 27 25 (2026-02-11)
BMW 230I 2025,2026
BMW 330I 2026
BMW 430I 2025,2026
BMW 530I 2025,2026
BMW 740I 2025,2026
BMW IX 2025
BMW X1 2025,2026
BMW X2 2026
BMW X3 2025,2026
BMW X5 2025,2026
BMW X6 2025,2026
BMW X7 2025,2026
BMW XM 2025
BMW XM LABEL 2026
ELECTRICAL SYSTEM
The vehicle may experience various operational issues with the infotainment system such as: Resets of the head unit Delayed start-up of the head unit (longer than 30 seconds) Failed start-up of the head unit Sporadic or permanent problems with navigation Sporadic or permanent Bluetooth connection problems Sporadic or permanent audio problems Sporadic or permanent speech / IPA (international phonetic alphabet) problems Missing displays, radio stations, camera images or applications
MC-11028927-0001.pdf
SIB 51 14 24 (2026-02-09)
BMW 530I 2024,2026
BMW M5 2026
STRUCTURE: BODY
The hood is difficult to close, or may not close
MC-11028924-0001.pdf
SIB 11 01 26 (2026-02-06)
BMW M2 CS 2026
BMW M3 2026
BMW M4 2026
ENGINE
Delivery Stop - Bearing Shell
MC-11029098-0001.pdf
InVeh-InApp-Comm (2026-02-05)
BMW 330I 2019
BMW Z4 2019
SUSPENSION
It was found that the rubber mounts of the wishbone or the tension strut were not correctly pressed in due to a manufacturing fault at the supplier's end. This can lead to an acoustic abnormality in the vehicle.
MC-11029010-0001.pdf
BMW I4 2023
BMW I7 2023
BMW IX 2023
POWER TRAIN
A manufacturing defect in a bearing of the electronic drive unit could result in bearing damage. This is caused by an unusual acoustic signal in the area of the drive unit. The bearing could fail completely at a later stage, which will be displayed to you by means of a red Check Control message. In this case, the driver is asked to call BMW Roadside Assistance.
MC-11029009-0001.pdf
BMW X7 2022
EXTERIOR LIGHTING
Residues from the production process may be present on the Frontal Light Electronics circuit board. This could result in the failure of a lighting function (e.g. daytime driving lights, low-beam headlight, turn indicators) on the affected side in the front area. In the event of a fault, you will be informed by a Check Control message. The front light module will be replaced.
MC-11029008-0001.pdf
InVehicle-InApp-Comm (2026-02-05)
BMW X3 2025
STEERING
The steering gear, which transmits the rotational movement of the steering wheel to the front wheels, must be replaced. Two sensors record the driver's steering requirements and may be faulty. The driver is notified of a fault by a Check Control message on the Central Display and a minimally changed steering feel.
MC-11029006-0001.pdf
In-Vehicle-InApp-Comm (2026-02-05)
BMW 530I 2024,2025
STRUCTURE: BODY
The water drain hose of the slide/tilt sunroof must be checked and, if necessary, re-attached. If the front left water drain hose is not connected, water can enter the footwell via the A-pillar and the carpet on the driver's side can soak up the water that has entered.
MC-11029005-0001.pdf
SIB 31 01 26 (2026-02-04)
BMW 430I 2024
BMW IX 2024
BMW X1 2024
BMW X2 2024
BMW X3 2024
BMW X4 2024
BMW Z4 2023
SUSPENSION
When driving over an uneven road surface, a “thumping” noise can be heard from the front axle. Seeattached video V 31 01 26. Under certain weather conditions, a “groaning” noise may be heard during steering movements
MC-11028921-0001.pdf
RECALL 26V056000 (2026-02-02)
Affecting 87394 total vehicles built between 2020-12-14 and 2022-12-14
BMW 230I 2022,2023
BMW 330I 2021,2022,2023,2024
BMW 530I 2024
BMW X3 2021,2022,2023
BMW X4 2021,2022,2023
BMW Z4 2021,2022
ELECTRICAL SYSTEM: STARTER ASSEMBLY
BMW of North America, LLC (BMW) is recalling certain 2021-2023 Toyota Supra, 2022-2023 2 Series Coupe, 2021-2024 5 Series (xDrive), 2021-2022 Z4, 2022-2024 4 Series (Gran Coupe), 2021-2024 4 Series (Convertible and xDrive Convertible), 2021-2023 4 Series (Coupe), 2021-2024 3 Series, 2021-2023 X4, 2021-2024 X3 vehicles. Please see the recall report for a complete list of all models. The engine starter may overheat and catch fire due to wear on an internal component.
RCRIT-26V056-2459.pdf
SIB 54 01 26 (2026-01-30)
BMW X6 2024,2025,2026
STRUCTURE: BODY
A “rattling” noise may be heard from the rear portion of the headliner when traveling over rough surfaces.
MC-11027997-0001.pdf
SIB 63 01 26 (2026-01-29)
BMW 230I 2026
EXTERIOR LIGHTING
Delivery Stop Rear Lights
MC-11027998-0001.pdf
SIB 52 07 25 (2026-01-28)
BMW 530I 2025
BMW M5 2025
STRUCTURE: BODY
The decorative trims on the head restraints of the driver’s seat and front passenger seat cause groaning noises on any route, at any temperature, even in a slightly reclined position.
MC-11027994-0001.pdf
SIB 28 01 25 (2026-01-27)
BMW X1 2024,2025,2026
BMW X2 2024,2025,2026
POWER TRAIN
SITUATION A Check Control message (CCM) displays for “Transmission oil service required” (ID 2120). This warning will typically trigger based on one of the following that applies: From 60,000 miles (~95,000 km) to 78,000 miles (~125,000 km), or After six (6) years: The “six years” time interval is determined the production date of the vehicle. It is not based on the day/date of the first registration, or the completion date of the pre-delivery check (PDI). If the vehicle is driven more than approx. 1900 miles (~3,000 km) after the first CCM, then a secondmessage will be display for “Transmission fault!” (ID 368). Note: If this service appears to have prematurely displayed as due, please follow standard technical reporting procedures before proceeding.
MC-11027985-0001.pdf
InVehicle-InApp-Comm (2026-01-23)
BMW X3 2024
BMW X4 2024
BMW X5 2024
BMW X6 2024
AIR BAGS
The ACSM control unit, which controls the driving safety and driving dynamics sensor system, may be faulty. Cracks could have formed on the printed circuit board during production. In very rare cases, the crack can enlarge due to mechanical load and lead to failure of the control unit. In this case, the driver will be informed accordingly by various warning displays about the failure and deactivation of the driving safety functions as well as restricted driving dynamics functions.
MC-11028296-0001.pdf
BMW X5 2025
BMW X6 2025
POWER TRAIN
The right rear drive shaft may not have been manufactured correctly during production and may break. In the event of a fault, you will hear significant noises in the area of the rear axle and the driving performance will be noticeably reduced. At the same time, warning lights and Check Control messages will be shown on the Central Display.
MC-11028294-0001.pdf
InVehicle-InApp-Comm (2026-01-22)
BMW 530I 2025
SERVICE BRAKES
Service Action: Left Side EMF (Parking Brake Actuator)
MC-11028276-0001.pdf
SIB 51 19 24 (2026-01-22)
BMW 530I 2024,2025
BMW 740I 2024,2025
BMW M5 2025
BMW X3 2025
VISIBILITY/WIPER
There is a matte “veil” or milky stain on theexterior mirror glass.
MC-11027991-0001.pdf
SIB 65 01 26 (2026-01-22)
BMW X3 2025
UNKNOWN OR OTHER
The customer returns after taking delivery of anew G45 X3 SAV, with a piece of the air bagwarning hang tag stuck between the centraldisplay screen upon attempting the tag’sremoval. The remaining portion of the tag is ofinsufficient length to extract it.
MC-11027775-0001.pdf
SIB 32 01 26 (2026-01-22)
BMW X3 2025
STEERING
When turning left, a “creaking” noise may be heard from the EPS when near the steering wheel end stop.The noise occurs at speeds less than 10 mph.
MC-11027764-0001.pdf
SIB 01 01 22 (2026-01-21)
BMW X6 2019
(plus 31 other models)
COMMUNICATION, ENGINE, EQUIPMENT: OTHER: OWNERS/SERVICE/OTHER MANUAL
N63TU1 CLASS ACTION SETTLEMENT SVC CAMPAIGN: OIL CONSUMPTION DIAGNOSIS/REPAIR
MC-11028000-0001.pdf
SIB 51 02 26 (2026-01-21)
BMW X3 2025,2026
STRUCTURE: BODY
The center console armrest unlock button(arrow) pops out when attempting to open,and/or when closing the center consolearmrest
MC-11027987-0001.pdf
SIB 31 02 26 (2026-01-17)
BMW X3 2025
SUSPENSION
When driving over a bump (compression and rebound), a “click”-type noise may occur in the area of thefront axle. The noise can be heard on the control arm rubber mount under torsional load, and a relative movement ofthe inner core can also be seen.
MC-11027762-0001.pdf
SIB 16 02 25 (2026-01-17)
BMW 530I 2024
FUEL/PROPULSION SYSTEM
The assembly cover on the left side of the fuel tank may not have been properly plastic welded. Thiscould lead to a smell of fuel after refueling or service engine soon light (MIL) for an evaporative leakin the fuel system.
MC-11027759-0001.pdf
SIB 65 02 26 (2026-01-16)
BMW X1 2025
BMW X2 2025
BMW X3 2025
ELECTRICAL SYSTEM
While using BMW Intelligent Personal Assistant, the activation word (“Hey BMW”) must be reactivated afterevery terminal change, BMW Remote Software Upgrade; or customer profile change. Additionally, after a BMW Remote Software Upgrade, the setup process for the voice assistant must be runagain. This was not the case previously.
MC-11027776-0001.pdf
SIB 51 19 25 (2026-01-09)
BMW 530I 2025
BMW M5 2025
STRUCTURE: BODY
When driving vehicle over rough roads, a rattle sound emanates from the left footwell panel.
MC-11027768-0001.pdf
SIB 24 02 25 (2026-01-09)
BMW X5 2025,2026
BMW X6 2025,2026
BMW X7 2025,2026
The threaded connection at the 48 power electronics (EME 48) may not have been properly secured. Further loosening of the connection could lead to a no-start or breakdown .
MC-11027760-0001.pdf
SIB 41 07 25 (2026-01-08)
BMW 330I 2020,2021,2022,2023,2024,2025
BMW M2 2023,2024
BMW M4 2021,2022,2023,2024,2025
(plus 3 other models)
STRUCTURE: BODY
While driving on a smooth and/or unevenroad, a “cracking” sound is heard from therear wheel arch area (highlighted in orange) on either the right or left side.
MC-11027766-0001.pdf
SIB 51 01 26 (2026-01-06)
BMW X1 2025
BMW X3 2025
BMW X5 2025
BMW X6 2025
BMW X7 2025
UNKNOWN OR OTHER
A reference label for the tailgate SmartOpener (SMO) function (aka “touchless open,or “kick to open”) was mistakenly applied tothe bottom edge of the tailgate trim panel(either of the general locations circled) duringvehicle production.
MC-11027767-0001.pdf
SIB 66 13 23 (2026-01-05)
FORWARD COLLISION AVOIDANCE, FORWARD COLLISION AVOIDANCE: AUTOMATIC EMERGENCY BRAKING, FORWARD COLLISION AVOIDANCE: WARNINGS
Various Check Control messages (CCM) can be displayed to the customer, which indicate a restrictedfunction or an unavailability of the driver assistance systems or driver assistance functions. During the diagnosis, the following fault memory entries are entered individually or in combination: 800AC4 - Camera calibration failed 800AC8 - Permanent calibration error 800A24 - Temporary software fault 800ABE - KAFAS camera: Field of view permanently faulty This only affects vehicles with the following optional equipment: 5AU Driving AssistantProfessional.
MC-11026969-0001.pdf
SIB 61 24 25 (2026-01-03)
BMW 530I 2025
BMW 740I 2025
ELECTRICAL SYSTEM
A limited number of 48 (V) volt vehicle batteries may have been damaged during the manufacturing process;this could lead to a premature battery failure. The 48 V battery may fail, triggering a corresponding Check Control message.
MC-11027774-0001.pdf
SIB 54 06 25 (2026-01-03)
BMW 530I 2024,2025
BMW I5 2024,2025
STRUCTURE: BODY
Through quality checks, it has been detected that the front left water drain hose for the slide/tilt sunroof isnot connected.
MC-11027770-0001.pdf
SIB 31 01 22 (2026-01-03)
BMW X1 2023,2024
BMW X2 2023,2024
BMW X3 HYBRID 2021
BMW X6 2019,2020,2021,2022,2023,2024
BMW X6 M 2019,2020
BMW XB7 2021
(plus 8 other models)
SUSPENSION, WHEELS
During inspection and/or diagnosis there is noticeable dirt/grease buildup on the axles near the inner and/orouter CV boots.
MC-11027761-0001.pdf
SIB 11 04 25 (2026-01-03)
BMW X5 2024,2025
BMW X6 2024,2025
BMW X7 2024,2025
ENGINE
Due to an assembly error the upper oil pan screws may not have been torqued correctly.
MC-11027758-0001.pdf
RECALL 25V906000 (2025-12-29)
Affecting 1 total vehicles built between 2025-08-28 and 2025-08-28
BMW I4 EDRIVE40 2025
ELECTRICAL SYSTEM: PROPULSION SYSTEM: CABLES
BMW of North America, LLC (BMW) is recalling one 2025 I4 EDRIVE40 vehicle. The connection between the positive battery cable and the rear power distributor may become loose.
RCRIT-25V906-3269.pdf
SIB 64 09 25 (2025-12-22)
BMW I5 2024,2025
ELECTRICAL SYSTEM
A faulty electric auxiliary heater may have been installed in the certain vehicles. This could result in thefailure of the electric auxiliary heater, utilized for the vehicle interior.
MC-11026956-0001.pdf
SIB 64 13 25 (2025-12-18)
BMW 330I 2024,2025,2026
BMW 430I XDRIVE 2024,2025,2026
BMW XM 2024,2025
BMW Z4 M40I 2025,2026
ELECTRICAL SYSTEM
When performing a vehicle test, diagnostic trouble code “ 8013FE Software run time error” is found in theIHKA module. If this fault is set for two consecutive life cycles, it will turn on the check engine light on vehicles with an I-level lower than 24-11-570. This fault memory entry does not cause an impairment of functionality of the automatic air conditioningsystem.
MC-11026960-0001.pdf
SIB 51 17 25 (2025-12-18)
BMW M5 2026
UNKNOWN OR OTHER
The rear tow hook cover cannot be reinstalled after it has been removed.
MC-11026951-0001.pdf
SIB 34 09 25 (2025-12-17)
BMW 430I 2024,2025,2026
BMW M2 2024
BMW M3 2024,2025,2026
BMW M4 2024,2025,2026
SERVICE BRAKES
There may be an internal leakage in the brake fluid expansion tank (aka brake fluid reservoir). In the rarecase of a leak, the filling level sensor might malfunction over a relatively long period of time.
MC-11026950-0001.pdf
SIB 64 11 25 (2025-12-16)
UNKNOWN OR OTHER
Insufficient cooling power in the passenger area. The following faults may be stored: 0380CA - Malfunction or electrical fault of the heat pump circuit expansion valve detected E70C51 - Heat pump circuit changeover valve is not responding E70C44 - Heat pump circuit expansion valve is not responding
MC-11026957-0001.pdf
SIB 11 10 25 (2025-12-12)
BMW 330I 2025
BMW 430I 2025
BMW 530I 2025
BMW X3 2025
BMW X4 2025
BMW Z4 M40I 2025
ENGINE
Coolant is leaking from the oil filter housing.
MC-11026946-0001.pdf
RECALL 25V857000 (2025-12-11)
Affecting 36922 total vehicles built between 2024-08-14 and 2025-10-20
BMW X3 2025,2026
STEERING: LINKAGES: DRAG: POWER ASSIST SYSTEM, STEERING: STEERING CONTROL MODULE
BMW of North America, LLC is recalling certain 2025-2026 X3 vehicles. While the vehicle is stationary, unexpected steering wheel movement (rotation) may occur.
RCRIT-25V857-3641.pdf
RCRIT-25V857-9760.pdf
RCRIT-25V857-4081.pdf
SIB 65 28 25 (2025-12-10)
BMW 230I 2026
BMW 330I 2026
BMW 430I 2026
BMW 530I 2026
BMW 740I 2026
BMW IX 2025
BMW X1 2026
BMW X2 2026
BMW X5 2026
BMW X6 2026
BMW X7 2026
BMW XM 2025
ELECTRICAL SYSTEM
The vehicle may experience various operational issues with the Multifunction Display such as: Intermittent black screen Permanent black screen Intermittent head unit functions not displayed (i.e., Navigation screen only is black)
MC-11026964-0001.pdf
RECALL 25V837000 (2025-12-08)
Affecting 25 total vehicles built between 2025-11-15 and 2025-11-15
BMW X5 2026
BMW X6 2026
BMW X7 2026
AIR BAGS: CRITICAL FASTENERS
BMW of North America, LLC (BMW) is recalling certain 2026 X6, X7, X5, and X5 Plug-In Hybrid vehicles. The instrument panel may have been manufactured incorrectly and prevent the passenger-side air bag from deploying properly.
RCRIT-25V837-0097.pdf
ReleaseNotes_2511_US_BMW (2025-12-02)
BMW 330I 2026
This communication contains the Release Notes for the BMW 2025-11 Remote Software Upgrade.
MC-11026705-0001.pdf
SIB 06 62 25 (2025-12-01)
BMW 230I 2026
STRUCTURE: BODY
LEFT TRUNK LID HINGE RETURN
MC-11027010-0001.pdf
SIB 12 14 25 (2025-12-01)
BMW I4 EDRIVE35 2025
BMW I4 EDRIVE40 2025,2026
BMW I4 M50 2024
BMW I4 M50 XDRIVE 2025
BMW I4 M60 2026
ELECTRICAL SYSTEM, POWER TRAIN, STEERING
In certain driving situations there can be a loss of traction or wheel slip followed by a throttle or torque requirement that can potentially damage the axle shafts. Damage of the drive shaft can cause it to break.
MC-11025830-0001.pdf
SIB 65 27 24 (2025-11-25)
BMW X5 2021,2022,2023,2024,2025
BMW X6 2021,2022,2023,2024,2025
BMW X7 2021,2022,2023,2024,2025
AIR BAGS
A check control message (CCM) for the restraint system (Air bag) appears. In the instrument cluster, the redair bag warning light lights up permanently. One of the following fault codes is stored in the ACSM (air bag control unit): 930949 - Knee airbag, driver: Short circuit to negative terminal 93094F - Knee airbag, front passenger: Short circuit to negative terminal 93094C - Knee airbag driver's side: Resistance too great 930952 - Knee airbag, front passenger: Resistance too great
MC-11025835-0001.pdf
SIB 62 04 25 (2025-11-21)
BMW X5 2026
BMW X6 2026
BMW X7 2026
STRUCTURE: BODY
DELIVERY STOP: INSTRUMENT PANEL
MC-11025833-0001.pdf
SIB 54 03 25 (2025-11-20)
BMW X1 2025
STRUCTURE: BODY
Contamination on the outer track(s) of thes unroof cassette. This can occur on either one or both side of the sunroof cassette.
MC-11025677-0001.pdf
SIB 64 05 25 (2025-11-14)
BMW X3 2025,2026
ELECTRICAL SYSTEM, STRUCTURE: BODY, UNKNOWN OR OTHER
1. The customer states that the output air from one of the vehicle vent assemblies doesn’t match the desiredtemperature, will change temperature opposite of climate settings. 2. The customer states that the output air from one of the vehicle vent assemblies doesn’t match the desired temperature, nor change from Hot/Cold.
MC-11025683-0001.pdf
SIB 16 01 24 (2025-11-12)
BMW 530I 2025
BMW 740I 2025
BMW X1 2024,2025
BMW X5 2024,2025
BMW X6 2024,2025
BMW X7 2024,2025
ELECTRICAL SYSTEM, FUEL SYSTEM, GASOLINE
RSU availability. The engine cranks but will not start.
MC-11025670-0001.pdf
SIB 12 11 25 (2025-11-12)
BMW 530I 2024,2025
BMW 740I 2024,2025
One or both of the following faults stored in the DME: 034AA5 - Mixture control bank 1, lambda regulation, mixture too lean 034AA8 - Mixture control bank 1, lambda adaptation, mixture too rich And additionally with the faults above, these affected vehicles may have one or more of the followingirregular combustion-related faults also stored: 033812 033813 033814 033815 033816 033817 033818 033819
MC-11025668-0001.pdf
SIB 63 10 25 (2025-11-10)
BMW 530I 2024,2025
BMW I5 2024,2025
EXTERIOR LIGHTING
RSU availability. The ambient lighting color cannot be saved permanently. The personalized color of the ambient lighting resets after the vehicle has gone to sleep.
MC-11025685-0001.pdf
SIB 61 29 24 (2025-11-07)
BMW X5 2024,2025
BMW X6 2024,2025
BMW X7 2024,2025
BMW XM 2024,2025
ELECTRICAL SYSTEM
RSU availability. Due to a software error in the BCP, the Calibration Identification Number (CAL ID) and the Calibration Verification Number (CVN) of the vehicle are not stored correctly. They are generated with eachprogramming session and are used to identify official BMW software.
MC-11025678-0001.pdf
SIB 36 02 25 (2025-11-06)
BMW X2 2024,2025
BMW X3 2026
BMW X4 2026
BMW X5 2026
BMW X6 2026
BMW X7 2026
BMW XM LABEL 2026
STEERING, WHEELS
The wheel bearing and the brake disc are not correctly aligned; are not concentric (circled). When applicable work is being performed, it is therefore difficult to remove the wheel bolts from, or fasten them into the wheel bearing hub.
MC-11025672-0001.pdf
SIB 12 02 24 (2025-10-31)
BMW 740I 2023,2024
BMW X5 2022,2023,2024
BMW X6 2022,2023,2024
BMW XM 2023,2024
RSU availability. VOLUNTARY EMISSIONS RECALL 24E-A02: VALVETRONIC
MC-11024709-0001.pdf
SIB 61 28 24 (2025-10-29)
BMW X5 2024
BMW X6 2024
BMW X7 2024
BMW XM 2024
ELECTRICAL SYSTEM
RSU availability. Due to a software error in the BCP, the Calibration Identification Number (CAL ID) and the CalibrationVerification Number (CVN) of the vehicle are not stored correctly. They are generated with eachprogramming session and are used to identify official BMW software.
MC-11024716-0001.pdf
SIB 51 09 25 (2025-10-29)
Oxidation/corrosion on the tailgate latch electrical connector and/or mechanical cable. This is caused by pressure washing the tailgate for a long period of time at close distance, resulting in water entering the vehicle through the gaps of the tailgate.
MC-11024711-0001.pdf
RECALL 25V717000 (2025-10-22)
Affecting 1024 total vehicles built between 2025-07-30 and 2025-09-27
BMW X1 2026
BMW X2 2026
SEAT BELTS: REAR/OTHER: RETRACTOR
BMW of North America, LLC is recalling certain 2026 2 Series Gran Coupe, X1, X2, and Mini Countryman S ALL4 vehicles. The housing pin in the rear (left and/or right) seat belt retractors may have been damaged during production, resulting in the retractor not locking the seat belt as intended. As such, these vehicles fail to comply to Federal Motor Vehicle Safety Standard number 209, "Seat Belt Assemblies."
RCRIT-25V717-4381.pdf
SIB 61 21 25 (2025-10-21)
ELECTRICAL SYSTEM
RSU availability. It is possible the State of Health (SoH) of the high-voltage (HV) battery is displayed incorrectly to the customer. The value is continuously displayed as 100% regardless of the actual ageing of the HV battery.
MC-11024715-0001.pdf
SIB 61 20 25 (2025-10-21)
BMW I5 2025
ELECTRICAL SYSTEM
MC-11024714-0001.pdf
SIB 65 25 25 (2025-10-10)
BMW 230I 2025
BMW 330I 2025
BMW 430I 2025
BMW 530I 2025
BMW 740I 2025
BMW X5 2025
BMW X6 2025
BMW X7 2025
BMW XM 2025
ELECTRICAL SYSTEM
After the software update to I-level version …25-07-530, the Alexa app may disappear from the App Menu in the head unit (HU-H5).
MC-11024727-0001.pdf
SIB 65 24 25 (2025-10-09)
BMW 230I 2025
BMW X1 2025
BMW X2 2025
BMW X3 2025
ELECTRICAL SYSTEM
After the software update to version …25-07-5XX, currently connected Bluetooth devices are not able to automatically reconnect to the head unit 6 (HU-H6).
MC-11024342-0001.pdf
SIB 65 23 25 (2025-10-09)
BMW 230I 2025
BMW X1 2025
BMW X2 2025
BMW X3 2025
ELECTRICAL SYSTEM
Occasionally the SiriusXM (aka SXM) Satellite Radio may be unavailable in the head unit 6 (HU-H6).
MC-11024341-0001.pdf
SIB 54 05 25 (2025-10-08)
BMW X3 2024
BMW X4 2024
STRUCTURE: BODY
A “popping” sound is heard coming from the Roof/B-pillar area when driving over small driveway curbs.
MC-11024340-0001.pdf
RECALL 25V671000 (2025-10-08)
Affecting 3 total vehicles built between 2025-07-15 and 2025-08-06
BMW X4 2026
BMW X6 2026
VISIBILITY: WINDSHIELD: CRITICAL FASTENERS
BMW of North America, LLC (BMW) is recalling certain 2026 X4 and X6 vehicles. The windshield may not be sealed properly, allowing water to enter the power distribution box or electronic control unit.
SIB 84 06 25 (2025-10-03)
BMW 330I 2024,2025
BMW 530I 2024,2025
BMW IX 2024,2025
BMW M3 2023,2024,2025
BMW M5 2025
BMW X3 2023,2024
BMW X3 2025
BMW XM 2023
ELECTRICAL SYSTEM
In some situations, an emergency call may be triggered in the vehicle without either the customer pressing the SOS Call button, or an airbag deployment event. In some cases, the customer may not even be inside the vehicle.
MC-11024211-0001.pdf
SIB 65 22 25 (2025-10-03)
BMW X3 2025
ELECTRICAL SYSTEM
While using the BMW Intelligent Personal Assistant (IPA) to initiate a phone call to a specific contact, eitheranother contact is dialed, or the IPA cannot locate the requested contact.
MC-11024210-0001.pdf
SIB 51 03 25 (2025-10-02)
BMW 530I 2024
STRUCTURE: BODY
The front and/or rear doors only close if increased force is exerted, or with increased closing speed.
MC-11024206-0001.pdf
SIB 51 13 25 (2025-09-29)
STRUCTURE: BODY
There are two possible situations: When opening either the front and/or rear door, the door window glass does not lower (short drop). When closing either the front and/or rear door, the door window glass does not roll up into the seal but rests outsidethe seal.
MC-11024207-0001.pdf
RECALL 25V644000 (2025-09-26)
Affecting 145102 total vehicles built between 2018-03-20 and 2025-02-11
BMW 340I 2020
BMW X5 2019,2020
BMW X6 2020
BMW X7 2019,2020
BMW of North America, LLC (BMW) is recalling certain 2020 340I, X6, 2020-2025 840I, 2020-2022 740LI, 2019-2020 X7, and X5 vehicles. After repeated attempts, the starter motor may overheat from an electrical overload.
RCRIT-25V644-4636.pdf
RECALL 25V643000 (2025-09-26)
Affecting 4 total vehicles
BMW 430I 2026
BMW M4 2026
ELECTRICAL SYSTEM: 12V/24V/48V BATTERY: CABLES, ELECTRICAL SYSTEM: WIRING: POWER DISTRIBUTION MODULE/IPDM
BMW of North America, LLC (BMW) is recalling certain 2026 M4 and 430i vehicles. The positive battery cables may not be properly connected to the power distribution box, resulting in an engine stall and a fire.
RECALL 25V636000 (2025-09-24)
Affecting 199674 total vehicles
BMW 230I 2022
BMW 430I 2021,2022
BMW 430I CONVERTIBLE 2021,2022
BMW X3 2020,2021,2022
BMW X4 2020,2021,2022
ELECTRICAL SYSTEM: STARTER ASSEMBLY: RELAY
BMW of North America, LLC (BMW) is recalling certain 2019-2021 BMW 330i, 2019-2022 BMW Z4, 2020-2022 BMW 530i, X3, X4, Toyota Supra, 2021-2022 BMW 430i, 430i Convertible, and 2022 BMW 230i vehicles. The engine starter relay may corrode, causing the relay to overheat and short circuit.
RCRIT-25V636-7824.pdf
RCRIT-25V636-7118.pdf
SIB 61 18 25 (2025-09-23)
BMW X3 2025
ELECTRICAL SYSTEM
Delivery Stop - Wiring Harness
MC-11024209-0001.pdf
SIB 01 17 24 (2025-09-19)
BMW M8 2020,2021
BMW M850I 2020,2021
ENGINE, FUEL/PROPULSION SYSTEM
The Fuel Injector Condition-Specific Repair Coverage Program applies to qualifying repairs for the required replacement of one or more the fuel injectors which were determined to have failed due to a buildup of external corrosion in the engine’s center fuel injector bore area that resulted after this location was periodically contaminated by engine coolant residue over time. This special program’s coverage is 15 years / 150,000 miles as determined from the vehicle's original in-service / first delivery date.
MC-11024203-0001.pdf
SIB 34 08 25 (2025-09-18)
BMW 530I 2024,2025
BMW 740I 2024,2025
BMW M5 2025
BMW X3 2024
BMW X3 2025
BMW X6 2024,2025
BMW XM 2024,2025
ELECTRICAL SYSTEM
Starting from I-level …24-07-500, it is possible that the Automatic Hold function is not automatically storedfor the next journey. The function must be activated again by the driver at the beginning of every trip. After asoftware update to 25-03-500 and higher, this occurs more frequently.
MC-11024205-0001.pdf
SIB 63 08 25 (2025-09-18)
EXTERIOR LIGHTING
The front interior reading light(s) (arrows) willrandomly turn ON and OFF while driving. The reading lights are normally activated by touching the small icons (circled).
MC-11023253-0001.pdf
This is an automated post created with code written by a human.
08-27-2025
Super useful! Thank you for putting this together!
08-27-2025
Bit of a dummy question
but I’m guessing this is only for that region correct ?
Not covers Australia I guess ?
Also is this like a recall list or things it can be claimed ?
08-27-2025
Yes, BMW provides service bulletins and recall information to a government agency in the USA. That dataset is public, so I'm building the lists from that data without getting in trouble with BMW IP lawyers.
There is a mix of "manufacturer communications" and safety recalls, both of which will have corresponding service bulletins or other documentation.
So while this isn't directly applicable to other regions, you can imagine that issues reported here could affect same models in other parts of the world (e.g. the cluster that was the integrated brake recall).
You may not have the same warranty/recall policies, but the same defect may apply to your vehicle. So it still offers some insight into issues you may encounter.
08-28-2025
This is great, thanks for compiling, might come in handy even in other countries as a reference point when dealing with dealerships and getting them to be more accountable.
08-28-2025
Nice reference for anyone interested. Thats a lot of work to pull it all together :cool:
09-03-2025
SIB 11 07 25 (2025-08-28)
BMW 740I 2025
ENGINE
Due to an assembly error, the valvetrain could have a mechanical failure.
MC-11022356-0001.pdf
SIB 51 02 25 (2025-08-26)
BMW IX 2021,2022,2023,2024,2025,2026
STRUCTURE: BODY
While driving on a smooth and/or uneven road, a “clicking” sound is heard from the driver’s footwell area.
MC-11022358-0001.pdf
SIB 12 11 25 (2025-08-26)
BMW 740I 2025
ELECTRICAL SYSTEM
A 740i Sedan, 740i xDrive Sedan (B58N - ICEV), or a 750e xDrive Sedan (XB1N - PHEV) may have one orboth of the following faults stored in the DME: 034AA5 - Mixture control bank 1, lambda regulation, mixture too lean 034AA8 - Mixture control bank 1, lambda adaptation, mixture too rich And additionally with the faults above, these affected vehicles may have one or more of the followingirregular combustion-related faults also stored: 033812 033813 033814 033815 033816 033817 033818 033819
MC-11022357-0001.pdf
SIB 63 06 25 (2025-08-26)
BMW X5 2022,2023,2024,2025
ELECTRICAL SYSTEM
The headliner light partially/does not illuminate.
MC-11022360-0001.pdf
SIB 64 08 25 (2025-08-26)
ELECTRICAL SYSTEM
A faulty electric auxiliary heater may have been installed in the certain vehicles. This could result in the failure of the electric auxiliary heater, utilized for the vehicle interior.
MC-11022361-0001.pdf
SIB 64 09 25 (2025-08-26)
BMW I5 2024,2025
ELECTRICAL SYSTEM
MC-11022362-0001.pdf
09-05-2025
RECALL 25V556000 (2025-08-27)
Affecting 1406 total vehicles
BMW X5 2026
BMW X7 2026
BMW of North America, LLC (BMW) is recalling certain 2026 X5 Plug-in Hybrid, X5, and X7 vehicles. The windshield may not be sealed properly, which can allow water to enter the power distribution box or electronic control unit.
09-06-2025
SIB 51 22 24 (2025-08-30)
BMW 330I 2024,2025
BMW 530I 2024,2025
BMW X1 2024,2025
BMW X2 2024,2025
BMW X3 2024,2025
BMW X4 2024,2025
BMW X5 2024,2025
BMW X6 2024,2025
BMW X7 2024,2025
BMW XM 2024
UNKNOWN OR OTHER
On the main door seal, detachment behavior can be detected in the sealing joint area. Overtime, the sealing material continues to detach more and more, which can cause the seal to dangle and become visible to the customer.
MC-11022857-0001.pdf
SIB 52 10 25 (2025-08-29)
BMW X7 2024,2025
SEATS
The electric actuator for the third row (3SR) seat changed design and part number, and is used in productionvehicles as of March 28, 2025. There are two such actuators at this seat row, one for the left seating position; and one for the right
MC-11022864-0001.pdf
SIB 64 05 25 (2025-08-28)
BMW X3 2025
STRUCTURE: BODY
1-Customer states that the output air from one of the vehicle vent assemblies doesn’t match the desired temperature, will change temperature opposite of climate settings. 2-Customer states that the output air from one of the vehicle vent assemblies doesn’t match the desired temperature, nor change from Hot/Cold.
MC-11022865-0001.pdf
SIB 65 20 25 (2025-08-26)
BMW 230I 2025
BMW 330I 2025
BMW 430I 2025
BMW 530I 2025
BMW 740I 2025
BMW M3 2025
BMW M4 2025
BMW M5 2025
BMW X3 2025
BMW X5 2025
BMW X6 2025
BMW X7 2025
BMW XM 2025
ELECTRICAL SYSTEM
After replacing the Multifunctional Display (MFD), the Central Information Display (CID) is black. Thebacklight of the CID is illuminated, and touch function does register an audible sound.
MC-11022855-0001.pdf
SIB 65 19 25 (2025-08-26)
BMW 330I 2025
BMW 430I 2025
BMW 530I 2025
BMW 740I 2025
BMW IX 2025
BMW M3 2025
BMW M4 2025
BMW X5 2025
BMW X6 2025
BMW X7 2025
BMW XM 2025
ELECTRICAL SYSTEM
Central Information Display (CID) in the vehicle is black or only displays “BMW”. The head unit (HU-H5) is not responding in ISTA. Additionally, the Receiver Audio Module (RAM), Instrument Cluster (KOMBI) and Telematic Module 4 (TCB4) may not be responding in ISTA.
MC-11022856-0001.pdf
SIB 06 44 25 (2025-08-22)
BMW X5 2025
BMW X6 2025
BMW X7 2025
UNKNOWN OR OTHER
Tension Strut Return
MC-11022870-0001.pdf
SIB 41 04 24 (2025-08-20)
BMW 330I 2025
BMW 430I 2025
BMW 530I 2025
BMW 740I 2025
BMW IX 2025
BMW M3 2025
BMW M4 2025
BMW M5 2025
BMW X3 2025
BMW X4 2025
BMW X5 2025
BMW X6 2025
BMW X7 2025
BMW Z4 M40I 2025
STRUCTURE: BODY
A groaning sound from the front of the vehicle while driving can be heard, particularly while cornering. The groaning sound can be heard in the A-pillar/instrument panel area.
MC-11022859-0001.pdf
SIB 11 05 25 (2025-08-19)
BMW 740I 2025
BMW M5 2025
BMW X5 2025
BMW X6 2025
BMW X7 2025
ENGINE
MC-11022863-0001.pdf
SIB 06 43 25 (2025-08-19)
BMW 330I 2025
BMW 430I 2025
BMW 530I 2025
BMW X1 2025
BMW X2 2025
BMW X3 2025
BMW X4 2025
BMW X6 2025
BMW Z4 M40I 2025
ENGINE
Oil Line Return
MC-11022869-0001.pdf
SIB 01 05 20 (2025-08-15)
BMW 328D 2014,2015,2016,2017,2018
BMW 525D XDRIVE 2014
BMW 535D 2014,2015,2016
BMW 740LD 2015
BMW X3 2014,2015,2016,2017,2018
BMW X5 2014,2015,2016,2017,2018
ENGINE
N47/N57 DIESEL ENGINE EGR COOLER REVISED EXT LTD WTY(ELW) COVERAGE/PROCEDURE
MC-11022852-0001.pdf
SIB 06 42 25 (2025-08-06)
BMW 228I 2014
BMW X7 2024
STRUCTURE: BODY
Bowden Cable Outer Return
MC-11022867-0001.pdf
09-08-2025
I have the same steering clicking on the G82! This really helps because everybody was stumped on that. Also commenting just to be able to save this thread and find it again easier haha. Hopefully this will help narrow it down at the dealership. Thanks!
09-16-2025
SIB 64 10 25 (2025-09-09)
BMW 230I 2025
BMW X3 2025
ELECTRICAL SYSTEM
After programming the vehicle via ISTA/RSU to25-07-5xx, the temperature display at thebottom of the Central Information Display (CID)may display the incorrect color for thetemperature setting (i.e., the color shows redwhen the air conditioning is active (circled),instead of the intended blue). Also, some of the ambient lighting strips mayno longer function properly.
MC-11023117-0001.pdf
SIB 63 09 25 (2025-09-09)
BMW 230I 2025
BMW X3 2025
ELECTRICAL SYSTEM
After programming the vehicle via ISTA/RSUto 25-07-5xx, some of the interior ambientlighting strips (examples circled) may nolonger function properly
MC-11023118-0001.pdf
SIB 64 05 25 (2025-09-08)
BMW X3 2025
ELECTRICAL SYSTEM
1. The customer states that the output air from one of the vehicle vent assemblies doesn’t match the desired temperature, will change temperature opposite of climate settings. 2. The customer states that the output air from one of the vehicle vent assemblies doesn’t match the desired temperature, nor change from Hot/Cold.
MC-11023116-0001.pdf
09-21-2025
RECALL 25V616000 (2025-09-17)
Affecting 1571 total vehicles
BMW X1 2025,2026
BMW X2 2025,2026
SEAT BELTS: FRONT: RETRACTOR
BMW of North America, LLC is recalling certain 2025-2026 X1 and X2, MINI Cooper Convertible, MINI Cooper, Mini Countryman S ALL4, and 2025 MINI Countryman SE ALL4 vehicles. The torsion bar in both front seat belt retractors may have been damaged during production.
09-22-2025
SIB 11 05 25 (2025-09-18)
BMW 740I 2025
BMW M5 2025
BMW X5 2025,2026
BMW X6 2025
BMW X7 2025,2026
ENGINE
MC-11023247-0001.pdf
SIB 52 12 25 (2025-09-18)
SEATS
A clicking noise can be heard from one or both front seat backrests. This noise is heard when leaning against the backrest of the seat or while the vehicle is cornering.
MC-11023249-0001.pdf
EXTERIOR LIGHTING
SIB 33 03 25 (2025-09-03)
POWER TRAIN
The rear right driven half-shaft (aka output shaft/driven shaft) may not have been manufactured correctly during production and may break. In the event of a failure, there could be significant noises in the area of the rear axle and the driving performance will be noticeably reduced.
MC-11023120-0001.pdf
SIB 32 08 25 (2025-09-03)
BMW 530I 2024,2025
BMW 740I 2024,2025
BMW IX 2024,2025,2026
BMW M5 2025
STEERING
When the steering column is adjusted inwards towards the instrument cluster, the noise may occur near thelimit position.
MC-11023248-0001.pdf
SIB 61 15 25 (2025-09-03)
ELECTRICAL SYSTEM
SITUATION The power windows and exterior mirrors do not function on the driver and/or passenger side. The fault occurs on either driver or on the passenger side. It does not occur on both sides at the same time.
MC-11023250-0001.pdf
SIB 63 07 25 (2025-09-03)
BMW 230I 2025
EXTERIOR LIGHTING
MC-11023252-0001.pdf
09-26-2025
Affecting 196355 total vehicles
BMW 230I 2022
BMW 430I 2021,2022
BMW 530I 2020,2021,2022
10-10-2025
BMW X3 2025
ELECTRICAL SYSTEM
BMW 330I 2024,2025
BMW 530I 2023,2024,2025
BMW M5 2025
BMW X3 2023,2024,2025
BMW XM 2023
ELECTRICAL SYSTEM
BMW 530I 2023,2024
STRUCTURE: BODY
STRUCTURE: BODY
BMW X3 2025
ELECTRICAL SYSTEM
BMW 750I 2015,2020
BMW 750LI 2020
BMW 850I 2019
BMW B7 ALPINA 2020,2021
BMW M5 2018
BMW M550I 2019,2020,2021
BMW M8 2020,2021
BMW M8 GRAN COUPE 2020
BMW M850I 2019,2020,2021
SIB 32 09 25 (2025-09-18)
BMW X3 2025
STEERING
Delivery Stop - Steering Gear
MC-11024204-0001.pdf
BMW 530I 2024,2025
BMW 740I 2024,2025
BMW M5 2025
BMW X3 2024,2025
BMW X6 2024,2025
BMW XM 2024,2025
ELECTRICAL SYSTEM
SIB 51 22 22 (2025-09-17)
BMW 228I 2020,2021,2022
BMW 430I 2021,2022,2023,2024,2025
BMW I4 2022,2023
BMW M235I 2020,2021,2022
BMW M3 2021,2022,2023,2024,2025
BMW M440I 2021,2022
LATCHES/LOCKS/LINKAGES: HOOD: LATCH, STRUCTURE: BODY
Hood lever is pulled twice but the hood only achieves the pre-latch position on both sides.
MC-11024208-0001.pdf
10-11-2025
SIB 06 54 25 (2025-10-07)
BMW M3 2025
BMW M4 2025
ENGINE
Evaporator Pipe Return
MC-11024236-0001.pdf
SIB 06 53 25 (2025-10-02)
BMW X3 2024
BMW X4 2024
STRUCTURE: BODY
Front Bumper Trim Return
MC-11024234-0001.pdf
SIB 06 52 25 (2025-10-01)
BMW 230I 2025
BMW 330I 2025
BMW 430I 2025
Supply Module Return
MC-11024232-0001.pdf
SIB 06 51 25 (2025-09-24)
BMW 740I 2025
STRUCTURE: BODY
Compartment Trim Return
MC-11024231-0001.pdf
SIB 06 50 25 (2025-09-22)
BMW 230I 2025
BMW X1 2025
BMW X2 2025
SUSPENSION
Rear Axle Return
MC-11024230-0001.pdf
SIB 06 48 25 (2025-09-10)
BMW 740I 2025
BMW M5 2025
BMW X5 2025
BMW X6 2025
BMW X7 2025
BMW XM 2025
ENGINE
Oil Drain Plug Return
MC-11024228-0001.pdf
SIB 06 46 25 (2025-09-05)
BMW X6 2024,2025
SUSPENSION
Control Arm Return
MC-11024225-0001.pdf
10-15-2025
BMW X4 2026
BMW X6 2026
10-17-2025
BMW 230I 2025
BMW X1 2025
BMW X2 2025
BMW X3 2025
ELECTRICAL SYSTEM
BMW 230I 2025
BMW X1 2025
BMW X2 2025
BMW X3 2025
ELECTRICAL SYSTEM
BMW X3 2024
BMW X4 2024
STRUCTURE: BODY
10-29-2025
BMW 228I GRAN COUPE 2026
BMW 228I XDRIVE GRAN COUPE 2026
BMW M235I XDRIVE GRAN COUPE 2026
BMW X1 2026
BMW X2 2026
11-04-2025
BMW 740I 2021,2022,2023,2024
BMW XM 2023,2024
SIB 32 09 25 (2025-10-31)
BMW X3 2025
STEERING
Check Control message and a significant change in steering feel .
MC-11024710-0001.pdf
SIB 66 13 23 (2025-10-29)
FORWARD COLLISION AVOIDANCE, FORWARD COLLISION AVOIDANCE: WARNINGS
Various Check Control messages (CCM) can be displayed to the customer, which indicate a restricted function or an unavailability of the driver assistance systems or driver assistance functions. During the diagnosis, the following fault memory entries are entered individually or in combination: 800AC4 - Camera calibration failed 800AC8 - Permanent calibration error 800A24 - Temporary software fault 800ABE - KAFAS camera: Field of view permanently faulty This only affects vehicles with the following optional equipment: 5AU Driving AssistantProfessional.
MC-11024718-0001.pdf
BMW X5 2024
BMW X6 2024
BMW X7 2024
BMW XM 2024
ELECTRICAL SYSTEM
SIB 61 19 25 (2025-10-29)
BMW 550E 2025
BMW 750E 2023,2024,2025
BMW M5 2025
BMW X5 2024,2025
BMW XM 2023,2024,2025
ELECTRICAL SYSTEM
RSU availability. The malfunction indicator lamp (MIL) is triggered by the erroneous fault code 031BFC- AC charging,charging electronics 2, internal fault: No internal capacitor discharge stored in the CCU. However, AC charging is operating as designed without a charging concern or issue. Affected PHEV vehicles have the CCU-03 (7.4 kW / 11 kW) with I-levels from 24-07-500 to 25-11-5xx
MC-11024713-0001.pdf
SIB 61 29 24 (2025-10-28)
BMW X5 2024
BMW X6 2024
BMW X7 2024
BMW XM 2024
ELECTRICAL SYSTEM
RSU availability. Due to a software error in the BCP, the Calibration Identification Number (CAL ID) and the CalibrationVerification Number (CVN) of the vehicle are not stored correctly. They are generated with each programming session and are used to identify official BMW software.
MC-11024717-0001.pdf
BMW 550E 2025
BMW I5 2025
ELECTRICAL SYSTEM
BMW IX 2026
ELECTRICAL SYSTEM
SIB 06 55 25 (2025-10-13)
BMW 230I 2022
BMW X1 2022
BMW X2 2022
UNKNOWN OR OTHER
Gasket Set Return
MC-11024733-0001.pdf
BMW 230I 2025
BMW 330I 2025
BMW 430I 2025
BMW 530I 2025
BMW 740I 2025
BMW X5 2025
BMW X6 2025
BMW X7 2025
BMW XM 2025
ELECTRICAL SYSTEM
